PavelH Posted 7 hours ago Posted 7 hours ago Used HW and SW: Odroid N2+ 4GB with 32 GB eMMC Sandisk 32 GB SD card SW: Armbian_25.5.1_Odroidn2_bookworm_current_6.12.28_minimal.img If I write the image to the SD card (using Balena Etcher), the system boots up and works fine. If I write the image in the same way to the eMMC using an adapter (with Balena Etcher), the system does not boot – only the red LED stays on. Booting via SD card with system and boot files transferred to eMMC using armbian-install also doesn't work. The system fails to boot again. The switch on the N2+ is in the correct position. The eMMC module is functional – if I write CoreELEC or Android images to it, everything works and the system boots correctly. Similar experiences have been described on the forum in the past. Is there any up-to-date procedure to resolve this? Thank you for all the advice and help. 0 Quote
Werner Posted 7 hours ago Posted 7 hours ago 10 minutes ago, PavelH said: the system does not boot https://debug.armbian.de 0 Quote
