AaronNGray Posted 23 hours ago Posted 23 hours ago `ls /dev` is not showing mmcblk1. I have Armbian Ubuntu install that may have been messed around with and is not showing /dev/mmcblk1, where as a fresh uSCDCard install is. 0 Quote
Werner Posted 21 hours ago Posted 21 hours ago Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
AaronNGray Posted 9 hours ago Author Posted 9 hours ago Quote PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u How does this work ? 0 Quote
Werner Posted 8 hours ago Posted 8 hours ago Open a terminal, type the command in question, provide us the output. 0 Quote
AaronNGray Posted 4 hours ago Author Posted 4 hours ago @Werner https://paste.armbian.de/wikedaqena I have ordered a couple of 3.3/5v UART USB adapters. I used to have an old 5V old. Thanks ! 0 Quote
laibsch Posted 56 minutes ago Posted 56 minutes ago You do have a mmcblk0, why do you think there should be a mmcblk1? 0 Quote
AaronNGray Posted 46 minutes ago Author Posted 46 minutes ago mmcblk1 should be the uSDcard it is on Nobel and Bookworm, it was there before I got hacked. 0 Quote
