Archont Posted October 14, 2017 Posted October 14, 2017 Hello, Recently I found that audio stopped working on my Banana. Last time (3 months ago) I was using shairport to stream audio over LAN and all was working just fine. Now I see that somehow information about audio card was removed: root@bananapi:~# alsamixer cannot open mixer: No such file or directory root@bananapi:~# cat /etc/asound.conf cat: /etc/asound.conf: No such file or directory I already try apt-get update && apt-get upgrade && apt-get dist-upgrade. My system information: root@bananapi:~# uname -a Linux bananapi 4.9.12-sunxi #4 SMP Thu Feb 23 19:46:51 CET 2017 armv7l GNU/Linux root@bananapi:~# lsmod Module Size Used by dm_mod 75191 0 md_mod 86434 0 realtek 2583 0 root@bananapi:~# cd /boot/ root@bananapi:/boot# ls armbianEnv.txt boot.bmp boot.scr dtb dtb.old script.bin uInitrd vmlinuz-4.11.6-sunxi bin.old boot.cmd config-4.11.6-sunxi dtb-4.11.6-sunxi initrd.img-4.11.6-sunxi System.map-4.11.6-sunxi uInitrd-4.11.6-sunxi zImage root@bananapi:~# dpkg-query -l 'linux*' Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-=================================-=====================-=====================-======================================================================== ii linux-base 3.5 all Linux image base package ii linux-dtb-next-sunxi 5.32 armhf Linux DTB, version 4.11.6-sunxi un linux-firmware <none> <none> (no description available) un linux-firmware-image-next-sunxi <none> <none> (no description available) un linux-headers <none> <none> (no description available) un linux-headers-686-pae <none> <none> (no description available) un linux-headers-amd64 <none> <none> (no description available) un linux-headers-generic <none> <none> (no description available) ii linux-headers-next-sunxi 5.32 armhf Linux kernel headers for 4.11.6-sunxi on armhf un linux-image <none> <none> (no description available) un linux-image-2.6 <none> <none> (no description available) ii linux-image-next-sunxi 5.32 armhf Linux kernel, version 4.11.6-sunxi un linux-initramfs-tool <none> <none> (no description available) ii linux-jessie-root-next-bananapi 5.31 armhf Armbian tweaks for jessie on bananapi (next branch) un linux-kernel-headers <none> <none> (no description available) un linux-kernel-log-daemon <none> <none> (no description available) ii linux-libc-dev:armhf 3.16.43-2+deb8u5 armhf Linux support headers for userspace development un linux-modules-4.11.6-sunxi <none> <none> (no description available) ii linux-u-boot-bananapi-next 5.31 armhf Uboot loader 2017.05
Igor Posted November 10, 2017 Posted November 10, 2017 Try this. Switch to beta, update and enable audio codec (armbian-config -> system -> hardware configuration) Note that switching to beta repository might break the system - its untested area.
Archont Posted November 11, 2017 Author Posted November 11, 2017 Switching to beta was successfull, but during entering 'hardware configuration' I get errors from grep (Try 'grep --help' for more information) and afer that window with enable/disable is empty (see atachement). Any idea why this happens?
Igor Posted November 11, 2017 Posted November 11, 2017 44 minutes ago, Archont said: Any idea why this happens? Probably some armbian-config dependencies must be missing but IIRC you need to start with a new image because overlays need also new boot script. We plan to rebuild images for A10/A20 next week. There this should work and if not, we will try to resolve the problem. Wait.
zador.blood.stained Posted November 11, 2017 Posted November 11, 2017 It shouldn't be related to overlays - BPi has analog sound enabled for almost 2 years. What strange is that /boot lists kernel 4.11, uname -r lists kernel 4.9 and lsmod output is too empty - there should be a lot more modules loaded. It could be the result of a broken SATA/USB installation or apt upgrade.
