Rikus Posted August 7, 2025 Posted August 7, 2025 Good day, I am new to using Armbian and also this is my first Raspberry PI. So Please excuse the question but can someone maybe give me advice on how to fix my Bluetooth connection. If I try to pair any Bluetooth device it keeps failing to pair. Then I have to remove the device due to it not wanting to connect. I have got Armbian OS noble kde-neon 25.5.1 installed on the Raspberry PI 5 16GB. Please help with any advice on how I can fix this. I have also never used Linux before so I would also appreciate any advice on which applications is critical to start getting into robotics or other nice projects on the Raspberry PI. Sorry for all the questions. Thanks in advice. 0 Quote
Werner Posted August 8, 2025 Posted August 8, 2025 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Rikus Posted August 8, 2025 Author Posted August 8, 2025 Thank you for being willing to help. Please see url below that I received https://paste.armbian.com/asiyogomaz 0 Quote
laibsch Posted August 8, 2025 Posted August 8, 2025 Thank you for sharing your logs. Have a look through my post where you can find lots and lots of commands I used for troubleshooting my bluetooth situation. Go ahead and share some of that information yourself and people might be able to spot the issue and guide you in the right direction. 0 Quote
