micha82 Posted August 19, 2025 Posted August 19, 2025 Armbianmonitor: https://paste.armbian.com/amalaxipeb Hi, i want to try the Gnome on Armbian with my Raspberry Setup. Pi5 with Touchdisplay2. The Display is working but without touch input. I looked through the /boot/firmware/config.txt and everything looks fine. I also tried to run Gnome on Xorg. Has someone a hint for me? 0 Quote
Igor Posted August 19, 2025 Posted August 19, 2025 Hi. Did you add / enable required overlays ? https://chatgpt.com/share/68a49507-d420-8005-a687-04d8daf0e93a It looks like kernel support is enabled. 0 Quote
micha82 Posted August 19, 2025 Author Posted August 19, 2025 Thx for your reply. Yes i tried both together. And just one. No difference. # Enable DRM VC4 V3D driver dtoverlay=vc4-kms-v3d # Enable the Touch Display 2 DSI panel dtoverlay=vc4-kms-dsi-ili9881-7inch 0 Quote
