BPI-R4, but that is probably the least of my problems.
setting up netplan, like the docs say I have to. using networkd, or trying...
renaming the eth1 interface to ethLAN, keeping lan1 as-is.
networkctl always says that eth1 or ethLAN is unmanaged.
Note that I'm using the ttyS0 serial console.
root@ratatosk:~# networkctl list
IDX LINK TYPE     OPERATIONAL SETUP
  1 lo   loopback carrier     unmanaged
  2 eth0 ether    degraded    unmanaged
  3 eth1 ether    off         unmanaged
  4 eth2 ether    off         unmanaged
  5 wan  dsa      off         unmanaged
  6 lan1 dsa      routable    configured
  7 lan2 dsa      off         unmanaged
  8 lan3 dsa      off         unmanaged
root@ratatosk:~# netplan apply
[  141.017704] mtk_soc_eth 15100000.ethernet ethLAN: renamed from eth1
[  141.068835] mtk_soc_eth 15100000.ethernet ethEXT1: renamed from eth2
  3 ethLAN  ether    off         unmanaged
  4 ethEXT1 ether    off         unmanaged
Here's my config. Note that it does in fact rename the interfaces... albeit not at boot 😑
root@ratatosk:~# cat /etc/netplan/20-ethLAN.yaml
network:
  version: 2
  renderer: networkd
  ethernets:
    ethLAN:
      match:
        macaddress: '6a:c9:72:53:13:d5'
      #set-name: ethLAN #tried with and without this
      addresses: [ "192.168.88.253/23" ]
      emit-lldp: true
      dhcp4: false
      dhcp6: false
      #ignore-carrier: true
      nameservers:
        addresses:
        - 192.168.82.55
        search:
        - tabris.net
      routes:
        #- to: 192.168.88.0/23
        #  metric: 10
        #  from: 192.168.88.253
        #  scope: link
        #  type: local
         - to: "default"
           via: "192.168.88.254"
root@ratatosk:~# cat /etc/netplan/11-lan1.yaml
network:
  version: 2
  renderer: networkd
  ethernets:
    lan1:
      match:
      addresses:
      - "192.168.88.250/23"
      nameservers:
        addresses:
        - 192.168.82.55
        search:
        - tabris.net
#      routes:
#      - to: "default"
#        via: "192.168.88.254"
note that lan1 works! ethLAN, whether named eth1 or ethLAN... does not.
I tried using renderer: NetworkManager
It then tries to restart networkd & stop NetworkManager.
but it can eventually work... but I have to sacrifice a rubber chicken [stupid manual steps like manually setting the interfaces up with ip link] each time, and they're starting to pile up.
it will *not* work at boot no matter what I do.
Did you try renaming by using udev rule?
Example:
sudo nano /etc/udev/rules.d/76-rename-wifi-by-mac.rules
SUBSYSTEM=="net", ACTION=="add", ATTR{address}=="b8:2d:28:5a:55:92", NAME="wlxb82d285a5592"
and then proceed with whatever. Both systemd-networkd and network manager should work.
rules in /etc/udev/rules.d did *nothing*. tried with 00 prefix and 99 prefix. udevadm test-builtin net_setup_link didn't mention the filepath either.
But I could make it do stuff with /etc/systemd/network/foo.link, which is what's current[ly not deleted yet from previous attempts]. Which makes it even weirder that it still won't rename at boot.
Note that the problem is a lot less the renaming and more that networkd refuses to manage the interfaces, even if I give up on renaming,
Weird. Check logs and verify matching - mac - if not changing random - is usually safest way. I haven't played under network manger lately ... perhaps there lies the problem or network devices gets up with a delay. I will try to recreate during week.
The eth0/lan1 MAC does change...
the eth1/eth2 MACs do not change. I've checked over multiple reboot cycles.
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 6a:c9:72:53:13:d5 brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 32:b0:1b:6f:4e:e9 brd ff:ff:ff:ff:ff:ff
root@ratatosk:~# uptime
 20:05:19 up 5 min,  1 user,  load average: 0.13, 0.39, 0.21
just rebooted, the MACs are stable 🐴
I could try reconfiguring the netplan config to use the name [like with lan1] instead of MAC... but that will of course mean I can't rename.
Ok, so using the match name *does* work, still makes no sense.
root@ratatosk:~# head /etc/netplan/20-ethLAN.yaml
network:
  version: 2
  renderer: networkd
  ethernets:
    eth1:
      match:
        #macaddress: '6a:c9:72:53:13:d5'
      #set-name: ethLAN
  3 eth1 ether    routable    configured
8 links listed.
making a copy of the file from /run/, changing the YAML to use MAC, then diff
root@ratatosk:~# netplan generate
root@ratatosk:~# diff -purN /run/systemd/network/10-netplan-eth1.network  /root/netplan-eth1-namematch.network
--- /run/systemd/network/10-netplan-eth1.network        2025-08-19 20:10:54.900000038 +0000
+++ /root/netplan-eth1-namematch.network        2025-08-19 20:10:36.980000037 +0000
@@ -1,5 +1,5 @@
 [Match]
-PermanentMACAddress=6a:c9:72:53:13:d5
+Name=eth1
 [Network]
 EmitLLDP=true
feels like a systemD bug ☹️
