CeeGO Posted August 28 Posted August 28 Hi, I'm trying to build for the Rock 3C so that I can minimize what goes into the kernel and system. I'm new at this and tried mostly default values (current, bookworm), except that I did minimal image instead of standard. The build failed at applying a patch. I don't know what to do with that. Can anyone help me diagnose? Also, how would I get into more details about building the image and choosing what to add/remove? Thanks! 0 Quote
laibsch Posted August 28 Posted August 28 First suggestion: try trixie or noble instead of bookworm 0 Quote
CeeGO Posted August 28 Author Posted August 28 (edited) Thank you for the reply and suggestion. I tried trixie and got the same error with the same patch. I guess I can't tell it to skip VP9? Edited August 28 by CeeGO 0 Quote
laibsch Posted August 28 Posted August 28 let me have a closer look after I successfully unsuccessfully compile this 0 Quote
Solution laibsch Posted August 28 Solution Posted August 28 a fix was just merged for Rockchip, update your repo and try again, maybe you are lucky 1 Quote
laibsch Posted August 28 Posted August 28 Yes, I am fairly confident you were experiencing one of these two https://github.com/armbian/build/pull/8554 https://github.com/armbian/build/pull/8555 1 Quote
laibsch Posted August 28 Posted August 28 Happy to report that "./compile.sh build BOARD=rock-3c BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm SHARE_LOG=yes" builds fine for me now. 1 Quote
CeeGO Posted August 29 Author Posted August 29 Looks good! Thank you. What's the best way to get start customizing the build? 0 Quote
Werner Posted August 29 Posted August 29 2 hours ago, CeeGO said: What's the best way to get start customizing the build? Easiest way is to use the customize-image.sh file in userpatches. Stuff there gets executed within chroot on the sdcard just before its closed and assembled. More advanced way is using extensions. Check extensions folder for examples. 0 Quote
CeeGO Posted August 30 Author Posted August 30 (edited) On 8/28/2025 at 9:34 PM, Werner said: Easiest way is to use the customize-image.sh file in userpatches. Stuff there gets executed within chroot on the sdcard just before its closed and assembled. More advanced way is using extensions. Check extensions folder for examples. Thanks. I'll have to look into that. I expect that's for customizing the packages installed? Edited August 30 by CeeGO 0 Quote
Werner Posted August 30 Posted August 30 Customizing image and customizing kernel are different tasks. For latter use the kernel-config command and then copy over the created config file from output to userpatches. The framework will look for custom kernel configuration files and uses them if they're detected. More details here: https://zuckerbude.org/armbian-using-kernel-config/ 0 Quote
