kevinH Posted yesterday at 04:35 PM Posted yesterday at 04:35 PM Hi, I am returning to Armbian after quite a few years. I was trying to follow guidance from nexbox-a95x-armbian and after a search found the debian & Ubunt images (https://www.armbian.com/uefi-arm64/) which I downloaded and wrote to a USB using Rufus (also balenaEtcher). I then tries to look at the FAT32 partition contents but the GPT was corrupt - tried many windows tools and Linux.I "repaired" the GPT using Linux tools but then the FAT32 filesystem was corrupt. What am I doing wrong? any help much appreciated 0 Quote
MaxT Posted yesterday at 04:55 PM Posted yesterday at 04:55 PM If I remember correctly, recently there was a similar thread on the forum re GPT corruption under windows. Not sure, but there might be some useful info.Alternatively, flashing under Linux might be an option. 0 Quote
SteeMan Posted yesterday at 05:09 PM Posted yesterday at 05:09 PM There are various recent reports of windows corrupting the partition table. 0 Quote
kevinH Posted yesterday at 08:45 PM Author Posted yesterday at 08:45 PM Well using Linux to write the USB appears to have fixed the problems. Damn Windows Thank you for the pointers, much appreciated. 0 Quote
kevinH Posted yesterday at 09:34 PM Author Posted yesterday at 09:34 PM Although writing the USB using Linux produced a good GPT the efi partition (FAT32) is unmountable and hence I cannot change anything. I tried gparted to fix it but the checkdisk failed. Hence I cannot follow the original guidance I had found. Where am I going wrong? thank again for any help 0 Quote
ccs1664 Posted 22 hours ago Posted 22 hours ago Flashing under Linux you will have many options to do it and check some problems on partitions etc. Normally, I use the Balena Etcher and dd by console. 0 Quote
SteeMan Posted 20 hours ago Posted 20 hours ago 4 hours ago, kevinH said: cannot follow the original guidance What guidance are you trying to follow? 0 Quote
kevinH Posted 14 hours ago Author Posted 14 hours ago The guidance I found is on Github, nexbox-a95x-arm https://github.com/berci9ke101/nexbox-a95x-armbianbian. I think its similar to some guidance I looked at when I first looked at Armbian and how I got Coreelec to run on my A95X box 0 Quote
SteeMan Posted 9 hours ago Posted 9 hours ago First off, I would recommend using the "psuedo official" instructions from this site: https://forum.armbian.com/topic/33676-installation-instructions-for-tv-boxes-with-amlogic-cpus And there you will find the following warning: Note: If you have previously run other distributions on the box such as coreelec the below installation will not work. You will need to restore the original android firmware before attempting the install. coreelec changes the boot environment in ways that are incompatible with these Armbian builds. 0 Quote
MaxT Posted 9 hours ago Posted 9 hours ago Disabling automount (drive letter assignment) in windows before flashing might help - probably it is mount time when windows is checking and changing partition table. 0 Quote
kevinH Posted 8 hours ago Author Posted 8 hours ago Thank you SteelMan for the pointer. Downloaded the rolling build and wrote it to my USB using balenaEtcher in Windows, the resulting USB was MBR and I could read the boot partitions contents. That's a massive improvement from using the images from https://www.armbian.com/uefi-arm64/ which were GPT and regardless of writing the USB under Windows/Linux the boot partition was unreadable. My box is probably an A95X Max (S905x2 SOC, 4G Ram, gbit ethernet & 5g wifi) so the uboot should be u-boot-s905x2-s922 All that's left is to find the best dtb Thanks for all the help 0 Quote
kevinH Posted 5 hours ago Author Posted 5 hours ago the guide has a warning: Note: If you have previously run other distributions on the box such as coreelec the below installation will not work. You will need to restore the original android firmware before attempting the install. coreelec changes the boot environment in ways that are incompatible with these Armbian builds. I have run coreelec but only ever from an SD card, I don't think the firmware has ever been changed as if I remove the SD card it boots into the original android system. Is this likely to be true or am I again missing something. 0 Quote
SteeMan Posted 4 hours ago Posted 4 hours ago You are missing something. The boot process starts with the uboot from the emmc (even if ultimately booting the SD card). And coreelec changes the uboot environment of the emmc in ways that are incompatible with with the armbian code. So you need to reflash a fresh android image if you want to use armbian as that will restore the basic state that armbian is expecting. 0 Quote
kevinH Posted 4 hours ago Author Posted 4 hours ago fair enough, no idea where i would get the right android image from for my unknown box so I guess I am stuffed putting Armbian on my box. never mind, will repurpose an old laptop when corelec updates for the s905x2 stop thanks for the help 0 Quote
