gmazrael Posted 23 hours ago Posted 23 hours ago I don't work with this board often, because it has been so stable, so I am less familiar with the boot process. I rebooted it today, and realized that it wouldn't post. I found a UART cable and grabbed this log. Can anyone point me to somewhere for it? Or would it be "easier" to just reflash the sd card? DDR V1.11 f1474cf52f cym 23/05/09-11:02:36 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:28.5%, TX Vref:21.8%,21.8% CH1 RX Vref:25.0%, TX Vref:22.8%,22.8% CH2 RX Vref:28.5%, TX Vref:22.8%,22.8% CH3 RX Vref:29.3%, TX Vref:22.8%,21.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09 (Feb 25 2024 - 00:42:52) Trying to boot from MMC1 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(2e8446f969...) + OK ## Checking uboot 0x00200000 ... sha256(528486af2f...) + OK ## Checking fdt 0x0034f598 ... sha256(906c87aa7c...) + OK ## Checking atf-2 0xff100000 ... sha256(9f75e6ec37...) + OK ## Checking atf-3 0x000f0000 ... sha256(c80587de50...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 801.437 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-662-g4acbe711b-dirty:finley.xiao, fwver: v1.44 NOTICE: BL31: Built : 16:44:24, Nov 7 2023 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 ERROR: dfs get fsp_params[0] error, 0xfead0003 != 0xfead0004 ERROR: dfs get fsp_params[1] error, 0xa2c != 0xfead0004 ERROR: dfs get fsp_params[2] error, 0xa34 != 0xfead0004 ERROR: dfs get fsp_params[3] error, 0xadc != 0xfead0004 ERROR: loader&trust unmatch!!! Please update loader if need enable dmc ERROR: current trust bl31 need match with loader ddr bin V1.13 or newer ERROR: current loader need match with trust bl31 V1.38-V1.40 INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09 (Feb 06 2025 - 03:18:03 +0000) Model: Orange Pi 5 MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 16 GiB Sysmem: init Relocation Offset: eda0e000 Relocation fdt: eb9f9250 - eb9fecb8 CR: M/C/I Using default environment DM: v2 mmc@fe2c0000: 1, mmc@fe2e0000: 0 Card did not respond to voltage select! mmc_init: -95, time 13 switch to partitions #0, OK mmc1 is current device Boot from SDcard Bootdev(scan): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Orange Pi 5 MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz No misc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 Bus usb@fcd00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fc000000 for devices... 1 USB Device(s) found scanning bus usb@fc800000 for devices... 1 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning bus usb@fcd00000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3906 bytes read in 22 ms (172.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 289 bytes read in 19 ms (14.6 KiB/s) 16738524 bytes read in 1382 ms (11.5 MiB/s) 38277632 bytes read in 3103 ms (11.8 MiB/s) 148164 bytes read in 122 ms (1.2 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16738460 Bytes = 16 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8a000 Using Device Tree in place at 0000000008300000, end 000000000838cfff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. ## reserved-memory: shmem@10f000: addr=10f000 size=100 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000) Total: 13124.390/13152.482 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.12.42-current-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP PREEMPT Fri Aug 15 10:14:14 UTC 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Xunlong Orange Pi 5 [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x000000000010f000..0x000000000010f0ff (0 KiB) nomap non-reusable shmem@10f000 [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000004ffffffff] [ 0.000000] NODE_DATA(0) allocated [mem 0x4fdf30a40-0x4fdf331bf] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000004ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 0.000000] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 0.000000] node 0: [mem 0x00000004f0000000-0x00000004ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000004ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1280 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges [ 0.000000] cma: Reserved 256 MiB at 0x00000000e0000000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 34 pages/cpu s99544 r8192 d31528 u139264 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=b879703b-1824-4faa-b2fd-447377946c85 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=54782d48-122d-bc44-b795-0bd9a0b2c55c usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=bl31-v1.44,uboot-02/06/2025 [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=54782d48-122d-bc44-b795-0bd9a0b2c55c cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4192256 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 [ 0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8. [ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 480 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [424:479] [ 0.000000] GICv3: Using MBI frame 0x00000000fe610000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 0.000000] ITS [mem 0xfe640000-0xfe65ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100440000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100450000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] ITS [mem 0xfe660000-0xfe67ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100470000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100480000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000100490000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000001004a0000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu@300[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/cpu@700[7] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000907] Console: colour dummy device 80x25 [ 0.000918] printk: legacy console [tty1] enabled [ 0.001692] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001718] pid_max: default: 32768 minimum: 301 [ 0.001793] LSM: initializing lsm=capability,yama,apparmor [ 0.001860] Yama: becoming mindful. [ 0.002067] AppArmor: AppArmor initialized [ 0.002173] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.002222] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.004702] rcu: Hierarchical SRCU implementation. [ 0.004720] rcu: Max phase no-delay instances is 1000. [ 0.004954] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.005667] EFI services will not be available. [ 0.006020] smp: Bringing up secondary CPUs ... [ 0.006582] Detected VIPT I-cache on CPU1 [ 0.006640] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 0.006656] GICv3: CPU1: using allocated LPI pending table @0x00000001004b0000 [ 0.006694] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.007331] Detected VIPT I-cache on CPU2 [ 0.007384] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 0.007400] GICv3: CPU2: using allocated LPI pending table @0x00000001004c0000 [ 0.007436] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.008086] Detected VIPT I-cache on CPU3 [ 0.008137] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 0.008152] GICv3: CPU3: using allocated LPI pending table @0x00000001004dreallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.029028] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.029264] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.029287] audit: initializing netlink subsys (disabled) [ 0.029395] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1 [ 0.029648] thermal_sys: Registered thermal governor 'fair_share' [ 0.029652] thermal_sys: Registered thermal governor 'bang_bang' [ 0.029658] thermal_sys: Registered thermal governor 'step_wise' [ 0.029662] thermal_sys: Registered thermal governor 'user_space' [ 0.029693] cpuidle: using governor menu [ 0.029788] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.029892] ASID allocator initialised with 65536 entries [ 0.029965] Serial: AMBA PL011 UART driver [ 0.035155] /vop@fdd90000: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.035180] /hdmi@fde80000: Fixed dependency cycle(s) with /vop@fdd90000 [ 0.037067] /pcie@fe190000: Fixed dependency cycle(s) with /pcie@fe190000/legacy-interrupt-controller [ 0.038925] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000 [ 0.039307] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000 [ 0.039332] /usb@fc000000: Fixed dependency cycle(s) with /phy@fed80000 [ 0.039354] /phy@fed80000: Fixed dependency cycle(s) with /i2c@fec80000/usb-typec@22/connector [ 0.044261] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.044457] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 0.044555] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.044659] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 0.044739] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.044836] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 0.044946] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.045042] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 0.045158] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.045251] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 0.045929] /hdmi@fde80000: Fixed dependency cycle(s) with /hdmi0-con [ 0.045955] /hdmi0-con: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.046846] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.046854] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.046860] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.046864] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.046869] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.046873] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.046878] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.046882] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.047467] cryptd: max_cpu_qlen set to 1000 [ 0.114290] raid6: neonx8 gen() 6673 MB/s [ 0.182377] raid6: neonx4 gen() 6624 MB/s [ 0.250449] raid6: neonx2 gen() 5590 MB/s [ 0.318521] raid6: neonx1 gen() 4434 MB/s [ 0.386598] raid6: int64x8 gen() 2945 MB/s [ 0.454669] raid6: int64x4 gen() 3097 MB/s [ 0.522737] raid6: int64x2 gen() 2585 MB/s [ 0.590817] raid6: int64x1 gen() 2128 MB/s [ 0.590821] raid6: using algorithm neonx8 gen() 6673 MB/s [ 0.658879] raid6: .... xor() 5046 MB/s, rmw enabled [ 0.658884] raid6: using neon recovery algorithm [ 0.659158] iommu: Default domain type: Translated [ 0.659164] iommu: DMA domain TLB invalidation policy: strict mode [ 0.659522] SCSI subsystem initialized [ 0.659701] u 1.340960] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 1.340967] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 1.340973] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff] (bus address [0x40000000-0x7fffffff]) [ 1.340992] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port [ 1.341008] pci 0004:40:00.0: ROM [mem 0x00000000-0x0000ffff pref] [ 1.341014] pci 0004:40:00.0: PCI bridge to [bus 01-ff] [ 1.341021] pci 0004:40:00.0: bridge window [io 0x0000-0x0fff] [ 1.341027] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff] [ 1.341035] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref] [ 1.341069] pci 0004:40:00.0: supports D1 D2 [ 1.341074] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 1.343675] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 1.343681] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 1.343768] pci 0004:41:00.0: [1987:5021] type 00 class 0x010802 PCIe Endpoint [ 1.343832] pci 0004:41:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit] [ 1.344438] pci 0004:41:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0004:40:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link) [ 1.352802] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 1.352817] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff]: assigned [ 1.352824] pci 0004:40:00.0: ROM [mem 0xf4300000-0xf430ffff pref]: assigned [ 1.352831] pci 0004:41:00.0: BAR 0 [mem 0xf4200000-0xf4203fff 64bit]: assigned [ 1.352864] pci 0004:40:00.0: PCI bridge to [bus 41] [ 1.352869] pci 0004:40:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 1.352877] pci_bus 0004:40: resource 4 [io 0x0000-0xfffff] [ 1.352882] pci_bus 0004:40: resource 5 [mem 0xf4200000-0xf4ffffff] [ 1.352888] pci_bus 0004:40: resource 6 [mem 0xa00000000-0xa3fffffff] [ 1.352893] pci_bus 0004:41: resource 1 [mem 0xf4200000-0xf42fffff] [ 1.353934] pcieport 0004:40:00.0: PME: Signaling with IRQ 44 [ 1.354071] pcieport 0004:40:00.0: AER: enabled with IRQ 45 [ 1.355494] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.355503] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 1.356061] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.356070] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 1.356653] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.356661] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 1.357460] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 1.358636] printk: legacy console [ttyS2] disabled [ 1.358743] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 52, base_baud = 1500000) is a 16550A [ 1.358836] printk: legacy console [ttyS2] enabled [ 1.528314] Serial: AMBA driver [ 1.532556] loop: module loaded [ 1.533253] Key type psk registered [ 1.534024] nvme nvme0: pci function 0004:41:00.0 [ 1.534450] nvme 0004:41:00.0: enabling device (0000 -> 0002) [ 1.534754] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg6 [ 1.535796] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7 [ 1.536659] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs3-null-pins [ 1.537468] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs2-null-pins [ 1.538267] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins [ 1.539124] rockchip-pinctrl pinctrl: pin gpio0-2 already requested by leds; cannot claim forber: xhci-hcd.0.auto [ 1.565087] hub 6-0:1.0: USB hub found [ 1.565425] hub 6-0:1.0: 1 port detected [ 1.565879] usbcore: registered new interface driver usb-storage [ 1.565976] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 1.567067] mousedev: PS/2 mouse device common for all mice [ 1.567140] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.567740] i2c_dev: i2c /dev entries driver [ 1.568266] usb usb4: Product: EHCI Host Controller [ 1.569097] usb usb4: Manufacturer: Linux 6.12.42-current-rockchip64 ehci_hcd [ 1.569734] usb usb4: SerialNumber: fc880000.usb [ 1.569763] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000 [ 1.570456] fan53555-regulator 2-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.570660] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.570917] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000 [ 1.571120] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected! [ 1.572747] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 1.573146] hub 4-0:1.0: USB hub found [ 1.573779] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 1.574054] hub 4-0:1.0: 1 port detected [ 1.574460] hwmon hwmon0: temp1_input not attached to any thermal zone [ 1.575266] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 1.576023] sdhci: Secure Digital Host Controller Interface driver [ 1.576599] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.577146] sdhci: Copyright(c) Pierre Ossman [ 1.577774] usb usb3: Product: EHCI Host Controller [ 1.578162] Synopsys Designware Multimedia Card Interface Driver [ 1.578579] usb usb3: Manufacturer: Linux 6.12.42-current-rockchip64 ehci_hcd [ 1.578872] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.579107] usb usb3: SerialNumber: fc800000.usb [ 1.579750] arm-scmi arm-scmi.1.auto: Using scmi_smc_transport [ 1.580513] hub 3-0:1.0: USB hub found [ 1.580628] arm-scmi arm-scmi.1.auto: SCMI max-rx-timeout: 30ms [ 1.580639] hub 3-0:1.0: 1 port detected [ 1.581236] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 1.583094] arm-scmi arm-scmi.1.auto: SCMI Notifications - Core Enabled. [ 1.583706] arm-scmi arm-scmi.1.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 1.588723] nvme nvme0: allocated 64 MiB host memory buffer. [ 1.589070] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.589871] hid: raw HID events driver (C) Jiri Kosina [ 1.590361] usbcore: registered new interface driver usbhid [ 1.590849] usbhid: USB HID core driver [ 1.591592] rockchip-dfi fe060000.dfi: dfi initialized, dram type: 0x8, channels: 4 [ 1.593160] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 1.594543] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available [ 1.596479] NET: Registered PF_INET6 protocol family [ 1.604938] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 1.605698] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.606348] usb usb2: Product: Generic Platform OHCI controller [ 1.606880] usb usb2: Manufacturer: Linux 6.12.42-current-rockchip64 ohci_hcd [ 1.607519] usb usb2: SerialNumber: fc840000.usb [ 1.608405] hub 2-0:1.0: USB hub found [ 1.608811] hub 2-0:1.0: 1 port detected [ 1.609599] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 1.610342] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.610987] usb usb5: Product: Generic Platform OHCI controller [ 1.611515] usb usb5: Manufacturer: Linux 6.12.42-current-rockchip64 [ 1.626421] Segment Routing with IPv6 [ 1.626780] In-situ OAM (IOAM) with IPv6 [ 1.627191] NET: Registered PF_PACKET protocol family [ 1.627644] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 1.628986] 8021q: 802.1Q VLAN Support v1.8 [ 1.629386] Key type dns_resolver registered [ 1.632685] registered taskstats version 1 [ 1.633251] Loading compiled-in X.509 certificates [ 1.639569] zswap: loaded using pool zstd/zbud [ 1.640116] Demotion targets for Node 0: null [ 1.640682] Key type .fscrypt registered [ 1.641042] Key type fscrypt-provisioning registered [ 1.642293] Btrfs loaded, zoned=yes, fsverity=yes [ 1.642768] Key type encrypted registered [ 1.643123] AppArmor: AppArmor sha256 policy hashing enabled [ 1.658124] WCN: marlin_init entry! [ 1.658579] of_cfs_init [ 1.658808] of_cfs_init: OK [ 1.675629] clk: Disabling unused clocks [ 1.676450] PM: genpd: Disabling unused power domains [ 1.678098] Freeing unused kernel memory: 5312K [ 1.678563] Run /init as init process [ 1.982323] typec_fusb302 6-0022: No cable types defined, using default cables [ 1.988807] rockchip-vop2 fdd90000.vop: Adding to iommu group 0 [ 1.989157] rtc-hym8563 6-0051: no valid clock/calendar values available [ 1.989716] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 1.990163] rtc-hym8563 6-0051: registered as rtc0 [ 1.990475] rk_gmac-dwmac fe1c0000.ethernet: IRQ sfty not found [ 1.991638] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 1.991898] rtc-hym8563 6-0051: no valid clock/calendar values available [ 1.992456] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 1.992972] rtc-hym8563 6-0051: hctosys: unable to read the hardware clock [ 1.993282] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops [rockchipdrm]) [ 1.993616] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 1.994838] dwhdmiqp-rockchip fde80000.hdmi: registered DesignWare HDMI QP I2C bus driver [ 1.995054] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 1.995529] rockchip-drm display-subsystem: bound fde80000.hdmi (ops dw_hdmi_qp_rockchip_ops [rockchipdrm]) [ 1.996240] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0x10 [ 1.997160] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 1.997742] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 2.004473] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 2.005264] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 2.005911] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 2.006373] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 2.006470] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 2.007037] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 2.007522] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 7 [ 2.007530] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 2.008270] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 2.008896] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 2.009543] xhci-hcd xhci-hcd.3.auto: irq 88, io mem 0xfc000000 [ 2.010400] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 2.010958] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 2.011423] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.011904] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 8 [ 2.011917] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 2.012395] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 2.012406] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 2.013153] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.013794] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 2.014416] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.014427] rk_gmac-dwmac fe1c0000.ethernet: SPH feature enabled [ 2.014995] usb usb7: Product: xHCI Host Controller [ 2.015007] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 2.015626] usb usb7: Manufacturer: Linux 6.12.42-current-rockchip64 xhci-hcd [ 2.019731] usb usb7: SerialNumber: xhci-hcd.3.auto [ 2.020451] hub 7-0:1.0: USB hub found [ 2.020799] hub 7-0:1.0: 1 port detected [ 2.159805] Console: switching to colour frame buffer device 160x45 [ 2.175587] rk_gmac-dwmac fe1c0000.ethernet end0: renamed from eth0 [ 2.196355] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 2.213113] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.213953] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12 [ 2.214762] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.215469] usb usb8: Product: xHCI Host Controller [ 2.215948] usb usb8: Manufacturer: Linux 6.12.42-current-rockchip64 xhci-hcd [ 2.216645] usb usb8: SerialNumber: xhci-hcd.3.auto [ 2.217493] hub 8-0:1.0: USB hub found [ 2.217879] hub 8-0:1.0: 1 port detected [ 2.219226] typec_fusb302 6-0022: No cable types defined, using default cables [ 12.258507] typec_fusb302 6-0022: No cable types defined, using default cables [ 12.271017] platform adc-keys: deferred probe pending: platform: supplier fec10000.adc not ready [ 12.279203] platform fec10000.adc: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/pldo-reg1 [ 12.287827] platform vcc-3v3-sd-s0-regulator: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/dcdc-reg8 [ 12.296656] i2c 6-0022: deferred probe pending: typec_fusb302: cannot register tcpm port [ 12.305122] platform fe2c0000.mmc: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/pldo-reg5 [ 18.708830] random: crng init done 0 Quote
Werner Posted 13 hours ago Posted 13 hours ago 10 hours ago, gmazrael said: found a UART cable and grabbed this log. Very good. First make sure you are actually having the 5B and not the 5 model. The reason I'm asking is in the logs is always model 5 and not 5B as supposed to. Did you adjust the dtb to use 5b one just like mentioned at the download page? 0 Quote
gmazrael Posted 7 hours ago Author Posted 7 hours ago I checked armbianEnv.txt and it says rockchip5, to triple check, I checked the site I bought it from, also says 5. So I believe I mislabeled the post as 5b, but it is a 5. 0 Quote
