Bino Oetomo Posted June 6, 2015 Posted June 6, 2015 Hi AllI use Cubieboard2_Debian_3.8_wheezy_3.4.107.raw for my Cubie2 (2012-09-09).Looking at [uart_para3] in the fex (created with bin2fex after nand install) [uart_para3] uart_used = 1 uart_port = 3 uart_type = 4 uart_tx = port:PH00<4><1><default><default> uart_rx = port:PH01<4><1><default><default> uart_rts = port:PH02<4><1><default><default> uart_cts = port:PH03<4><1><default><default> I check if the pins is used by other 'function'And found that it used by lcd1_para [lcd1_para] ...snip... lcdd0 = port:PH00<2><0><default><default> lcdd1 = port:PH01<2><0><default><default> lcdd2 = port:PH02<2><0><default><default> lcdd3 = port:PH03<2><0><default><default> lcdd4 = port:PH04<2><0><default><default> lcdd5 = port:PH05<2><0><default><default> lcdd6 = port:PH06<2><0><default><default> lcdd7 = port:PH07<2><0><default><default> lcdd8 = port:PH08<2><0><default><default> lcdd9 = port:PH09<2><0><default><default> lcdd10 = port:PH10<2><0><default><default> lcdd11 = port:PH11<2><0><default><default> lcdd12 = port:PH12<2><0><default><default> lcdd13 = port:PH13<2><0><default><default> lcdd14 = port:PH14<2><0><default><default> lcdd15 = port:PH15<2><0><default><default> lcdd16 = port:PH16<2><0><default><default> lcdd17 = port:PH17<2><0><default><default> lcdd18 = port:PH18<2><0><default><default> lcdd19 = port:PH19<2><0><default><default> lcdd20 = port:PH20<2><0><default><default> lcdd21 = port:PH21<2><0><default><default> lcdd22 = port:PH22<2><0><default><default> lcdd23 = port:PH23<2><0><default><default> lcdclk = port:PH24<2><0><default><default> lcdde = port:PH25<2><0><default><default> lcdhsync = port:PH26<2><0><default><default> lcdvsync = port:PH27<2><0><default><default> I disabled the LCD1But where is that PH00 on the Extention Port ?Is there any docs on PortName to Extention-Port-PIN mapping ?Sincerely-bino-
Igor Posted June 6, 2015 Posted June 6, 2015 It's not necessary that it's on the extension port. http://docs.cubieboard.org/cubieboard1_and_cubieboard2_gpio_pin
Bino Oetomo Posted June 6, 2015 Author Posted June 6, 2015 I really appreciate your very fast respons It's not necessary that it's on the extension port. http://docs.cubieboard.org/cubieboard1_and_cubieboard2_gpio_pin From that doc, there is no lcd1-D0.Is that mean that PH00 is not on ExtentionPort (and so there is no chance to get uart3)?Sincerely-bino-
