Cubie2 A20 Fex : UART3
Bino Oetomo
Hi All
I use Cubieboard2_Debian_3.8_wheezy_3.4.107.raw for my Cubie2 (2012-09-09).
Looking at [uart_para3] in the fex (created with bin2fex after nand install)
[uart_para3]
uart_used = 1
uart_port = 3
uart_type = 4
uart_tx = port:PH00<4><1><default><default>
uart_rx = port:PH01<4><1><default><default>
uart_rts = port:PH02<4><1><default><default>
uart_cts = port:PH03<4><1><default><default>
I check if the pins is used by other 'function'
And found that it used by lcd1_para
[lcd1_para]
...snip...
lcdd0 = port:PH00<2><0><default><default>
lcdd1 = port:PH01<2><0><default><default>
lcdd2 = port:PH02<2><0><default><default>
lcdd3 = port:PH03<2><0><default><default>
lcdd4 = port:PH04<2><0><default><default>
lcdd5 = port:PH05<2><0><default><default>
lcdd6 = port:PH06<2><0><default><default>
lcdd7 = port:PH07<2><0><default><default>
lcdd8 = port:PH08<2><0><default><default>
lcdd9 = port:PH09<2><0><default><default>
lcdd10 = port:PH10<2><0><default><default>
lcdd11 = port:PH11<2><0><default><default>
lcdd12 = port:PH12<2><0><default><default>
lcdd13 = port:PH13<2><0><default><default>
lcdd14 = port:PH14<2><0><default><default>
lcdd15 = port:PH15<2><0><default><default>
lcdd16 = port:PH16<2><0><default><default>
lcdd17 = port:PH17<2><0><default><default>
lcdd18 = port:PH18<2><0><default><default>
lcdd19 = port:PH19<2><0><default><default>
lcdd20 = port:PH20<2><0><default><default>
lcdd21 = port:PH21<2><0><default><default>
lcdd22 = port:PH22<2><0><default><default>
lcdd23 = port:PH23<2><0><default><default>
lcdclk = port:PH24<2><0><default><default>
lcdde = port:PH25<2><0><default><default>
lcdhsync = port:PH26<2><0><default><default>
lcdvsync = port:PH27<2><0><default><default>
I disabled the LCD1
But where is that PH00 on the Extention Port  ?
Is there any docs on PortName to Extention-Port-PIN mapping ?
Sincerely
-bino-
