OpenglMan Posted October 25, 2017 Posted October 25, 2017 Hello, I have just built an image with the default parameters of the Lime A20 board. It seems that the system does not detect any sound card. aplay -l aplay: device_list:268: no soundcards found... uname -a Linux lime 4.13.6-sunxi lsmod Module Size Used by cfg80211 376832 0 rfkill 20480 1 cfg80211 sun4i_gpadc_iio 16384 0 evdev 20480 1 at24 16384 0 sun4i_ts 16384 0 sun4i_gpadc 16384 0 nvmem_sunxi_sid 16384 0 sun4i_ss 24576 0 uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq As you can see above, there is no module related to sound. If i use the same SD card with this image built in a Cubieboard2, i get the same error. Any advice would be greatly appreciated, Thanks in advance.
Igor Posted October 25, 2017 Posted October 25, 2017 If a board does not have an audio connector that is almost always disabled in board DT by default. I am not sure if audio is possible to enable with overlay, but check it:https://docs.armbian.com/User-Guide_Allwinner_overlays/
OpenglMan Posted October 25, 2017 Author Posted October 25, 2017 Thank you Igor, I will check this information about Device Tree overlays
OpenglMan Posted October 25, 2017 Author Posted October 25, 2017 The solution was found some time ago forum.armbian.com/index.php?/topic/4224-analog-audio-on-lime2-with-stable-kernel-version-49/
OpenglMan Posted October 26, 2017 Author Posted October 26, 2017 Hello Igor, According to the previous link, i add the following code segment to the dts : &codec { status = "okay"; }; The dts file is located in: build/cache/sources/linux-mainline/linux-4.13.y/arch/arm/boot/dts/sun7i-a20-olinuxino-lime.dts After that, i run compile.sh , but if i check the dts file again, i can't see the code segment that i added. So, how can i modify the device tree of the lime board or any other board? (mainline kernel) Thank you very much in advance
Igor Posted October 26, 2017 Posted October 26, 2017 51 minutes ago, OpenglMan said: After that, i run compile.sh , but if i check the dts file again, i can't see the code segment that i added. A source is checked out by default. You need to switch to "edit" mode. CREATE_PATCHES=yes ... https://docs.armbian.com/Developer-Guide_Build-Options/ This will prompt you to make changes to the source code. Then you make them. After you are done, return and press ENTER. This will also create a patch in output/patches ... which you can move later to appropriate userpatches directory or submit upstream.
OpenglMan Posted October 26, 2017 Author Posted October 26, 2017 Thank you very much, the whole process worked correctly
