KhanhDTP Posted 4 hours ago Posted 4 hours ago As the title says, how can I install the ntsync kernel module for use with Wine/Proton? Quote Linux orangepi5 6.16.4-edge-rockchip64 #1 SMP PREEMPT Thu Aug 28 14:34:51 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux 0 Quote
Solution The Tall Man Posted 3 hours ago Solution Posted 3 hours ago (edited) That module is not included in the default kernel build configuration. But you can build the kernel yourself. https://docs.armbian.com/Developer-Guide_Build-Preparation/ https://docs.armbian.com/Developer-Guide_Build-Commands/ When you run ./compile.sh, the first thing it shows you is the kernel configuration screen (image 1). Select, "Show a kernel configuration menu before compilation". When it finally arrives on the configuration menu (image 2), use the forward slash key (/) for search, enter ntsync. When the result comes up (image 3), press 1 to select it. It will take you right to it. It will be highlighted (image 4). Press the M key to select it as a module. The use the right arrow to move from Select to Exit, and keep doing that until you get to where you save it. Then keep going with the rest of the process. I could be wrong about this, but I think you can build the kernel only without the whole armbian image too, with this (from the second link above); ./compile.sh kernel-config BOARD=orangepi5 BRANCH=edge Image 1: Select Kernel Configuration Image 2: Kernel Configuration Menu Image 3: Search Result - NTSYNC Image 4: - NTSYNC Selection Edited 2 hours ago by The Tall Man 0 Quote
KhanhDTP Posted 2 hours ago Author Posted 2 hours ago @The Tall Man Thank you very much, I will try and fb! 0 Quote
KhanhDTP Posted 34 minutes ago Author Posted 34 minutes ago @The Tall Man Thanks again, it works Quote khanhdtp@orangepi5:~/Desktop$ modinfo ntsync filename: /lib/modules/6.16.6-edge-rockchip64/kernel/drivers/misc/ntsync.ko license: GPL description: Kernel driver for NT synchronization primitives author: Elizabeth Figura <zfigura@codeweavers.com> depends: intree: Y name: ntsync vermagic: 6.16.6-edge-rockchip64 SMP preempt mod_unload aarch64 0 Quote
