Posted (edited)
23 hours ago, 晓飞丁 said:
How do you use Zink?
Set var environments as below:
export PAN_MESA_DEBUG=gl3
export MESA_GL_VERSION_OVERRIDE=4.3
export MESA_LOADER_DRIVER_OVERRIDE=zink
export GALLIUM_DRIVER=zink
export LIBGL_KOPPER_DRI2=true
Edited by KhanhDTP
8 hours ago, KhanhDTP said:
+ PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco)
+ box64 3.9 (https://ryanfortner.github.io/box64-debs/)
+ GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom)
+ Zink (openGL)
>=60fps@1080p
I am trying to use Zink to play TomRaider , while comes out this error:
[BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winepulse.so
[BOX64] Using native(wrapped) libpulse.so.0
[BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winealsa.so
[BOX64] Using native(wrapped) libasound.so.2
[BOX64] Using native(wrapped) libGL.so.1
WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance
[BOX64] 15479|Ask to run at NULL, will segfault
wine: Unhandled page fault on execute access to 0000000000000000 at address 0000000000000000 (thread 0024), starting debugger...
[BOX64] winedbg detected, not launching it!
0024:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 32 332" (731)
Read the Wine Developers Guide on how to set up winedbg or another debugger
Is "GE-proton" is a must to OpenEL games?
No, basically any wine/proton (wow64) will work!
Btw, that version of the Tomb Raider!
1 hour ago, KhanhDTP said:
Have you tried other wine/proton versions?
I just used wine-proton 10.0.3. While replace the wine to 11.0-rc1 to my previous proton environment, which is working fine on some games, such as VampireSuvivors, after installing Wine-mono, none game can be played.  Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed"
(https://www.pcgamingwiki.com/wiki/Vampire_Survivors)
Vampire_Survivors is a 64-bit / Direct3D 11.1 game.
You may not be setting DXVK (stripped) properly.
export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b"
Download the DXVK (stripped) here:
https://github.com/khanh-it/dxvk/releases/tag/releases
(You may want to try to know which version works best for this game)
Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file.
If you're setting up the DXVK properly, you will see the output with something like the following:
Quote
info:  Game: VampireSurvivors.exe
info:  DXVK: v1.6.1
info:  Built-in extension providers:
info:    Win32 WSI
info:    OpenVR
warn:  OpenVR: Failed to locate module
info:  Enabled instance extensions:
info:    VK_KHR_surface
info:    VK_KHR_win32_surface
warn:  D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT
info:  Mali-G610:
info:    Driver: 26.0.0
info:    Vulkan: 1.4.335
info:    Memory Heap[0]:
info:      Size: 5945 MiB
info:      Flags: 0x1
info:      Memory Type[0]: Property Flags = 0x7
info:  Process set as DPI aware
info:  Device properties:
info:    Device name:     : Mali-G610
info:    Driver version   : 26.0.0
info:  Enabled device extensions:
Thank you so much! I will try it tonight!
Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again?
You extract and copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file folder.
So no need to change anything in $WINEPREFIX dir.
Have you ever met the issue "lack of OpenAl32.dll". I try to run "isaac:rebirth" and come out cannot find "openAl32.dll", I got a copy of openAl32.dll from my windows laptop and put it into $WINEPREIX/windows/system32 or the game's executable file folder, cannot get the right result.
No
You can try to set env:
export BOX64_PREFER_EMULATED=1
After applying these settings, TomeRaider can be run perfectly now, Thank you !
Posted (edited)
Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115)
+ wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14)
+ WineD3D / Zink (OpenGL)
~30fps@720p (this game is capped at 30fps)
NARUTO SHIPPUDEN - Ultimate Ninja STORM 3 Full Burst HD
Edited by KhanhDTP
 + GE-proton-10.25 (https://github.com/GloriousEggroll/proton-ge-custom)
+ DXVK-stripped v1.6.1
~60fps@1080p
How do you use GE-proton? I see no wine dir in the released tar.gz but a bunch of python script.  When I try to run the "proton", comes out "Proton: No compat data path?"
4 minutes ago, 晓飞丁 said:
 I am trying to use umu-launcher,  using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened.
You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up!
Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much!
Posted (edited)
Do you mind sharing some screenshots + your settings :D ?
Edited by KhanhDTP
Sure. However, I am in PRC, Google is blocked.  I cannot login in on my SBC since I am using Google account to login.  I have to use my laptop which has vpn. I will find a way this weekend.
I noticed that some games are using DXVK while some are using wined3d, what is the reason? It that a way that force every game using DXVK?
I've read your DXVK-stripped code on github. Looks like your code is far behind the original one. Is your code can match the release "stripped 2.7.1" libs you provide? Thanks you so much!
+ FEX-Emu 2510
+ hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18)
+ Dxvk 1.10.3 (stripped)
30~60fps@720p (mixed settings)
Tomb Raider (2013) Definitive Edition
Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115)
+ Dxvk 2.1 (stripped)
~60fps@1080p
MiSide Full
+ FEX-Emu 2510
+ Dxvk 1.7.1 (stripped)
~60fps@1080p
Dave The Diver
~24fps@720p
Sleeping Dogs - Definitive Edition
+ FEX-Emu 2510
~60fps@1080p
I failed to run DaveTheDiver using these settings:
PanVk-mesa 26.0
+ wine-Proton-10.0.3
+ Dxvk 2.7.1(stripped)
the log shows:
Unsupported ioctl 74080
Faking StorageDeviceProperty data
Is FEX or DXVK 1.7.1 is a must ?
