KhanhDTP Posted December 6, 2025 Author Posted December 6, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.5.5 ~60fps@720p Left 4 Dead 2 0 Quote
KhanhDTP Posted December 6, 2025 Author Posted December 6, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.5.5 >=60fps@720p Super Robot Wars V 0 Quote
晓飞丁 Posted December 8, 2025 Posted December 8, 2025 Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 0 Quote
NicoD Posted December 8, 2025 Posted December 8, 2025 52 minutes ago, 晓飞丁 said: Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 I tried FEX-emu, but on our devices it's slower. It is optimised for snapdragon while box64 is more optimised for the lower-end SBC ARM-SOC. Here a video I once made about it. Things have changed a lot, fex-emu has matured at lot in this time. I didn't know it was build for steam back then so didn't test that. Also have no steam games that would run. 1 Quote
KhanhDTP Posted December 8, 2025 Author Posted December 8, 2025 2 hours ago, 晓飞丁 said: Have you guys ever try FEX-emu instead of box64? I heard FEX is 10%~20% faster than box64 I am using hangover-10.18, which is Fex-Emu 2510. https://github.com/AndreRH/hangover/releases/tag/hangover-10.18 I didn't benchmark. But I think rn, the main bottleneck is the GPU (PanVk driver is now only ~60% performance of the libMali driver). 0 Quote
KhanhDTP Posted December 8, 2025 Author Posted December 8, 2025 1 hour ago, NicoD said: Also have no steam games that would run. Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. 0 Quote
晓飞丁 Posted December 8, 2025 Posted December 8, 2025 3 hours ago, KhanhDTP said: I didn't benchmark. But I think rn, the main bottleneck is the GPU (PanVk driver is now only ~60% performance of the libMali driver). Sorry I am an amateur on rk3588. If libMali have better performance. But why most of you are using PanVk? 2 hours ago, KhanhDTP said: Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. Without steam it is meanlingless, while we could only play games with no drm? 2 hours ago, KhanhDTP said: Steam games are working now, I tested some games a week ago. But the steam client alone took ~5gb. So, I would not recomend unless you have a 16gb board. I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ 0 Quote
KhanhDTP Posted December 8, 2025 Author Posted December 8, 2025 1 hour ago, 晓飞丁 said: If libMali have better performance. But why most of you are using PanVk? Because the compatibility, I can't get the libMali driver to work with 32bit games (DXVK specifically). Also, although 64bit games work with the libMali, most of the games I have tested are black screen, or missing textures. 1 hour ago, 晓飞丁 said: I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ Thanks for the sharing, I will try it later. 0 Quote
KhanhDTP Posted December 8, 2025 Author Posted December 8, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-proton-10.25 (https://github.com/GloriousEggroll/proton-ge-custom) + DXVK-stripped v1.6.1 ~60fps@1080p Half Life 2 0 Quote
KhanhDTP Posted December 9, 2025 Author Posted December 9, 2025 12 hours ago, 晓飞丁 said: I found a way to shrink the memory occupation by not starting the steamclientwebhelp. See the tips here :https://www.howtogeek.com/694531/how-to-reduce-steams-ram-usage-from-400-mb-to-60-mb/ Still the same 0 Quote
晓飞丁 Posted December 9, 2025 Posted December 9, 2025 2 hours ago, KhanhDTP said: Still the same It's wierd that in native Windows environment. steamwebhelper will only cost about 500MB memroy 1 Quote
heyrict Posted December 9, 2025 Posted December 9, 2025 (edited) 20 hours ago, 晓飞丁 said: If libMali have better performance. But why most of you are using PanVk? I failed to get a working OpenGL with libmali. A more performant GLES may give a more performant desktop, but won't make most games working. Since the community have been doing excellent work bringing rk3588 to mainline, it makes no sense to stick to a 5.x vendor kernel for a closed-source library with flaws, at least in my use case. 5 hours ago, 晓飞丁 said: It's wierd that in native Windows environment. steamwebhelper will only cost about 500MB memroy The FEX's developer has explained the reason why memory usage is high under arm64, and I think box64 may also have similar problems. Edited December 9, 2025 by heyrict 1 Quote
KhanhDTP Posted December 9, 2025 Author Posted December 9, 2025 https://github.com/ptitSeb/box64/issues/3146#issuecomment-3630691360 Optimize is on the way, just wait! 2 Quote
KhanhDTP Posted December 12, 2025 Author Posted December 12, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v2.6.2 >=60fps@1080p Cuphead 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v2.6.2 >=60fps@1080p Blasphemous 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v2.6.2 >=60fps@1080p Blasphemous 2 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v2.6.2 >=60fps@1080p Shovel Knight Dig 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.7.1 ~60fps@1080p Ori and the Blind Forest: Definitive Edition 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 (edited) Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Zink 30~60fps@720p Quote I tried all the DXVK(-stripped) possible for both dx9, dx10. Either crashes or black screen, or missing textures; only Zink works. I also tried box64, but it's not working (crashed) Crysis x64 (dx10) Edited December 13, 2025 by KhanhDTP 0 Quote
晓飞丁 Posted December 13, 2025 Posted December 13, 2025 Are you using X11 or wayland? I am not able to run wayland while under X11 it is very slow 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 1 hour ago, 晓飞丁 said: Are you using X11 or wayland? I am not able to run wayland while under X11 it is very slow I am using X11 (XFCE), make sure you installed the driver. 0 Quote
晓飞丁 Posted December 13, 2025 Posted December 13, 2025 36 minutes ago, KhanhDTP said: I am using X11 (XFCE), make sure you installed the drive How do you use proton/wine. I download the archieve file and after extraction, there are bin & lib files, how can I use them ? set some environment variables? 0 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 You can follow this guide to getting started https://gist.github.com/JeodC/aa89f7b387d9dd7976d39bf585e471fd 0 Quote
晓飞丁 Posted December 13, 2025 Posted December 13, 2025 6 minutes ago, KhanhDTP said: You can follow this guide to getting started Thank you so much! Read it right away! 1 Quote
heyrict Posted December 13, 2025 Posted December 13, 2025 3 hours ago, 晓飞丁 said: Are you using X11 or wayland? I am not able to run wayland while under X11 it is very slow I've tested niri, hyprland, sway and i3, all of them should work if properly configured. 1 Quote
KhanhDTP Posted December 13, 2025 Author Posted December 13, 2025 Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v1.6.1 ~60fps@720p Left 4 Dead 0 Quote
KhanhDTP Posted December 14, 2025 Author Posted December 14, 2025 (edited) Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p Tomb Raider Remastered I - II - III Edited December 14, 2025 by KhanhDTP 0 Quote
KhanhDTP Posted December 14, 2025 Author Posted December 14, 2025 (edited) Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p Tomb Raider Remastered IV - V - VI Edited December 14, 2025 by KhanhDTP 0 Quote
