xiboliyadongtu Posted March 14 Posted March 14 Thank you very much for your suggestions; I have tested both of them using Protonge. I replaced the BdO launcher to rule out any issues with Chinese language support. Both suggestions caused the launcher to display an error window. Furthermore, I tested the solution involving DXVK using Wine 11.4 staging, but the launcher only displayed a black window; I have uploaded the logs and screenshots. Additionally, I downloaded the Windows version of VKcube, which displays the rotating cube correctly. Translated with DeepL.com (free version) log-protonge.txt log-wine11.4staging.txt 0 Quote
KhanhDTP Posted March 14 Author Posted March 14 @xiboliyadongtu as your ss, the launcher is 32-bits. So, can you copy x32/d3d11.dll, x32/dxgi.dll files to the game folder and try again? 0 Quote
xiboliyadongtu Posted March 14 Posted March 14 i delete the previous 64-bit version of DXVK, copy the 32-bit version DXVK, and tried to luanch the game; the game dispalyed a logo and then disappeared. Maybe it have crashed. log-dxvk log-zink 0 Quote
KhanhDTP Posted March 14 Author Posted March 14 @xiboliyadongtu Can this game be started without a launcher? Is there an executable file besides BlackDesertLauncher.exe (like BlackDesert.exe)? The BlackDesertLauncher.exe is definitely a 32-bit file. So, you might need to run it with GE-Proton10-32 in WoW64 mode. Delete the created GE-Proton10-32's prefix to make sure. Then start it again with envs Quote export PROTON_USE_WOW64=1 export PROTON_USE_WINED3D=1 export WINEDLLOVERRIDES="d3d11,dxgi=n,b" export DXVK_HUD="api,version,compiler,fps,scale=1" export DXVK_CONFIG="d3d11.maxFeatureLevel=12_1" If everything is right, you will see the Dxvk output log with something like below: Quote info: Game: BlackDesertLauncher.exe info: DXVK: v1.6.1 info: Built-in extension providers: info: Win32 WSI info: OpenVR warn: OpenVR: Failed to locate module info: Enabled instance extensions: info: VK_KHR_surface info: VK_KHR_win32_surface warn: D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT info: Mali-G610: ... 0 Quote
xiboliyadongtu Posted March 14 Posted March 14 This game cant start without the launcher, I will try these options 0 Quote
xiboliyadongtu Posted March 14 Posted March 14 i just delete the default file named umu-defalut. and i try to start the launcher, but it still crash. Did i got right things? log 0 Quote
xiboliyadongtu Posted March 14 Posted March 14 this game do have a file named blackdesert64.exe 0 Quote
KhanhDTP Posted March 14 Author Posted March 14 @xiboliyadongtu Then copy x64/d3d11.dll, x64/dxgi.dll files to the same folder as blackdesert64.exe and try to run it without the launcher. 0 Quote
MiStar Posted March 15 Posted March 15 Hello! I'll take the topic a little away from the main direction, but the question will be in the framework of game testing: is running games through the ps2 emulator (aethersx2) a dead end? When you turn on the MALI-610 on aethersx2 (need for speed underground), the video loads well (60fps, 100%), but there is braking on the screensavers, the sound also stutters and the control is noticeably delayed. When switching to Open GL, the screensavers load quickly, the sound does not stutter, the controls are clear without delay, but the video goes with slight drawdowns, the picture and sound twitch, but very rarely (while the video has an average of 55-60 fps with a percentage of 70-90%).I tested everything on the armbian 26 installed on the sd. 0 Quote
xiboliyadongtu Posted March 16 Posted March 16 Sry, it is too late so i go sleep. But i found the method to fix this. I use box64 and wine staging succeed run the luancher by edit the file. “To fix the white or black launcher: Go in Documents\BlackDeser\GameOptionLauncher.txt and change these value to 0 launcherGpu = 0 launcherOffScreen = 0 This should fix the launcher once for all” https://www.codeweavers.com/compatibility/crossover/forum/black-desert-online?srsltid=AfmBOoomxtE1rM4fxkwr05vZXqg7N30pyVeyxG9wztivOZNf4rmiFs9W;msg=319137 By the way, this game must boot by luancher. 1 Quote
KhanhDTP Posted March 16 Author Posted March 16 @xiboliyadongtu So, you were able to play the game with Dxvk (or Zink) now? How is the performance I wonder? 0 Quote
xiboliyadongtu Posted March 16 Posted March 16 The game have not start couse "technique not found shader : ObjectNormal.fx, ObjectLava" 1 Quote
xiboliyadongtu Posted March 16 Posted March 16 I found "https://www.naeu.playblackdesert.com/en-US/Forum/Qna/Detail?_questionNo=1122&_answerSortType=0" have same problem, but I have no idea about find the device ID. 0 Quote
xiboliyadongtu Posted March 16 Posted March 16 I found that if I use umu-run(protonge), the launcher will crash, but if i use wine staging (with dxvk), the launcher start is no problem but the game got a error. 1 Quote
KhanhDTP Posted March 16 Author Posted March 16 I can see it has already set: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum Mali-G610 MC4 0 Quote
xiboliyadongtu Posted March 16 Posted March 16 I changed the devicedesc, but game still shows same error. And the launcher shows it is another name. (Nvdia Geforce 6800).Ps: must go bed for now XD. 1 Quote
Alex Ling Posted March 30 Posted March 30 @KhanhDTP Now Call of Duty 2 can be launched with dxvk 2.7.1 + mesaaco ppa. 1 Quote
KhanhDTP Posted March 30 Author Posted March 30 @Alex Ling yeah, I have noticed it too. With Mesa (PanVk) recent updates, DX9 games can be played with Dxvk without dgVoodoo2 wrapper. 1 Quote
Alex Ling Posted March 30 Posted March 30 @KhanhDTP BTW, I'm using the edge 7.0-rc3 kernel. Did you find the vendor 6.1 kernel is more stable? 0 Quote
KhanhDTP Posted March 30 Author Posted March 30 @Alex Ling I haven't tried mainline kernel 7.x so I can't tell. Can you check the GPU clock is capped at 850 Mhz bug is fixed? 0 Quote
chaitan3 Posted March 30 Posted March 30 @KhanhDTPHow to choose which dxvk version to use for which game from your dxvk stripped github actions? Are there a set of versions that are known to be more stable? Also, what is the GPU clock bug, I am on kernel 6.19 using mesa 26.1-git. 0 Quote
Alex Ling Posted March 30 Posted March 30 (edited) @KhanhDTP gpu clock is still limited to 850mhz with 7.0. I tried to port rockchip vendor kernel clock settings but no success yet. @chaitan3 The gpu can clock up to 1Ghz by hardware design but it is limited to 850mhz with mainline kernel. Edited March 30 by Alex Ling 1 Quote
KhanhDTP Posted March 31 Author Posted March 31 (edited) 1 hour ago, chaitan3 said: How to choose which dxvk version to use for which game from your dxvk stripped github actions? @chaitan3 It depends on the games; I have to try around to find what is best. I usually try 1.7.3, 1.10.3, 1.6.1 then 2.x versions. Edited March 31 by KhanhDTP 1 Quote
