HW: OrangePi5 Plus 32 32 GB RAM
    512 GB NVME
    5K Monitor
Image: Armbian_25.8.1_Orangepi5-plus_trixie_vendor_6.1.115_xfce_desktop.img
prepare system before each case
dd if=u-boot-V2024.04-orangepi5-plus-spi.img  of=/dev/mtdblock0
flash_erase /dev/mtd0 0 0
case 1:
1. copy image to 64GB uSD
2. booting
3. system comes up with xfce
4. sudo apt-get -y update; apt-get -y upgrade
5. reboot
6. system comes up, without desktop. system is reachable with ssh
case 2:
2. booting
4. armbian-install
5. choose boot from mtd flash
6. choose nvme0n1p1
6. update mtdblock0
7. reboot
8. system comes up, without desktop. system is reachable with ssh
any idea whats going wrong?
Posted (edited)
@DiplDi
I was doing some experiments on Armbian 25.8.1 Trixie, and I decided to do a quick try of installing the XFCE desktop (along with some others):
sudo apt-get -o APT::Install-Recommends="true" install task-xfce-desktop
It works under X, but not under Wayland. I found out that its Wayland support is experimental, and that if you install the labwc package, that will get it running (very very badly) under Wayland. But it does work well under X. It's possible a different wayland compositor (than labwc) will work better?
I also tried with the Vendor kernel (with the Panthor GPU overlay), and the edge kernel. Edge GPU performs seemingly not at all under X, but vendor with Panthor overlay performs well in X.
I initially logged in via the SDDM display manager, but I switched to LightDM, and that worked as well, although with a hiccup.
Edited by The Tall Man
