laibsch Posted September 30 Posted September 30 The latest Armbian IoT image for Khadas VIM4 does not boot. sha256sum: 69b10797369fd572d590aeb0dd7b28a4ebc5882cec8db8daf592db7b158bf141 Here is the log from the serial debug console. Spoiler [...] Hit any key to stop autoboot: 0 Setting bus to 6 _find_partition_by_name()-200: do not find match in table boot _find_partition_by_name()-200: do not find match in table boot error partition name! 4096 bytes read in 1 ms (3.9 MiB/s) _find_partition_by_name()-200: do not find match in table boot _find_partition_by_name()-200: do not find match in table boot error partition name! 4194304 bytes read in 2 ms (2 GiB/s) avb2: 1 active_slot is normal ab_suffix is _find_partition_by_name()-200: do not find match in table vbmeta _find_partition_by_name()-200: do not find match in table vbmeta get partition info failed !! _find_partition_by_name()-200: do not find match in table vbmeta _find_partition_by_name()-200: do not find match in table vbmeta error partition name! Failed to read 65536B from part[vbmeta] at 0 avb_slot_verify.c:721: ERROR: vbmeta: Error loading vbmeta data. avb verification: locked = 1, result = 2 try upgrade as booting failure PHY2=00000000fe03a020,phy-base=0xfe03e000 noSof Device: emmc Manufacturer ID: 15 OEM: 100 Name: BJTD4 Bus Speed: 192000000 Mode : HS200 (200MHz) Rd Block Len: 512 MMC version 5.1 High Capacity: Yes Capacity: 29.1 GiB Bus Width: 8-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 29.1 GiB WRREL Boot Capacity: 4 MiB ENH RPMB Capacity: 4 MiB ENH card in ** Unrecognized filesystem type ** ** Unrecognized filesystem type ** starting USB... USB0: Register 1000120 NbrPorts 1 Starting the controller USB XHCI 1.10 USB1: No ----gpio-vbus-power Register 2000120 NbrPorts 1 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found active_slot: normal _find_partition_by_name()-200: do not find match in table recovery _find_partition_by_name()-200: do not find match in table recovery error partition name! Err imgread(L199):Fail to read 0x2000B from part[recovery] at offset 0 Err imgread(L466):Fail read dtb from recovery, ret 200 restore dtb the dtb partition size is:40000 byte _verify_dtb_checksum()-2815: calc 0, store 0 update_dtb_info()-2923: cpy 1 is not valid _verify_dtb_checksum()-2815: calc 0, store 0 update_dtb_info()-2923: cpy 0 is not valid dtb_read()-3030: total valid 0 Err imgread(L339):Fail read dtb from rsv with sz 0x40000 Err imgread(L466):Fail read dtb from _aml_dtb, ret -340 [imgread]read from part: recovery _find_partition_by_name()-200: do not find match in table recovery _find_partition_by_name()-200: do not find match in table recovery error partition name! Err imgread(L545):Fail to read 0x100000B from part[recovery] at offset 0 kvim4# 0 Quote
laibsch Posted October 1 Author Posted October 1 no boot for Khadas-supplied Fenix 24.04.1.6.9 image, either. sha256sum: e89b80b7777fed524651b98d04e8afc0406fee76e4c5f9ccf4457df4fb6d9054 Spoiler [...] mmc_init: -110, time 1589 emmc: resp timeout, cmd8, status=0x1cf2800 emmc: resp timeout, cmd55, status=0x1cf2800 emmc: tuning start: emmc: best_win_start =5, best_win_size =5 emmc: clk = 10000206, dly1 = 0, dly2 = 0, adj = 12000, cfg = 804872 1 blocks read: OK gpt_alt->magic _mmc_check_gpt: gpt is invalid and can't be repair gpt is complete 34 blocks read: OK mmc_gpt_read: invalid GPT 34 blocks read: OK mmc_gpt_read: invalid GPT fill_ept_by_gpt: invalid gpt check_valid_dts: FDT_ERR_BADMAGIC get_partition_from_dts() 244: ret -9 get_partition_from_dts() 247: ret -9 get_ptbl_from_dtb()-373: get partition table from dts faild mmc_device_init()-1861: get partition table from dtb failed get_ptbl_rsv()-638: magic faild MPT, mmc_device_init()-1895: dtb&rsv are not exist, no LPT source switch to partitions #0, OK mmc1(part 0) is current device ** Invalid partition 1 ** _find_partition_by_name()-203: do not find match in table boot _find_partition_by_name()-203: do not find match in table boot error partition name! 4096 bytes read in 2 ms (2 MiB/s) ## Error: "storage_param" not defined _find_partition_by_name()-203: do not find match in table boot _find_partition_by_name()-203: do not find match in table boot error partition name! 4194304 bytes read in 2 ms (2 GiB/s) avb2: 0 avb2: 0 Wrong Image Format for bootm command ERROR: can't get kernel image! check_ramdump, ramdump_enable = <NULL> libfdt fdt_check_header(): FDT_ERR_BADMAGIC [rsvmem] fdt addr error. rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed try upgrade as booting failure PHY2=00000000fe03a020,phy-base=0xfe03e000 noSof Device: emmc Manufacturer ID: 15 OEM: 100 Name: BJTD4 Bus Speed: 192000000 Mode : HS200 (200MHz) Rd Block Len: 512 MMC version 5.1 High Capacity: Yes Capacity: 29.1 GiB Bus Width: 8-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 29.1 GiB WRREL Boot Capacity: 4 MiB ENH RPMB Capacity: 4 MiB ENH sd: resp timeout, cmd17, status=0x1ff2800 ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** sd: resp timeout, cmd17, status=0x1ff2800 ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** active_slot: normal _find_partition_by_name()-203: do not find match in table recovery _find_partition_by_name()-203: do not find match in table recovery error partition name! Err imgread(L228):Fail to read 0x2000B from part[recovery] at offset 0 Err imgread(L447):Fail read dtb from recovery, ret 229 restore dtb the dtb partition size is:40000 byte _verify_dtb_checksum()-2960: calc 0, store 0 update_dtb_info()-3068: cpy 1 is not valid _verify_dtb_checksum()-2960: calc 0, store 0 update_dtb_info()-3068: cpy 0 is not valid dtb_read()-3175: total valid 0 Err imgread(L391):Fail read dtb from rsv with sz 0x40000 Err imgread(L447):Fail read dtb from _aml_dtb, ret -392 Load dtb/amlogic/kvim4n.dtb from SD (0:1) ... sd: resp timeout, cmd17, status=0x1ff2800 ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** sd: resp timeout, cmd17, status=0x1ff2800 ** Can't read partition table on 0:0 ** ** Invalid partition 1 ** [imgread]read from part: recovery _find_partition_by_name()-203: do not find match in table recovery _find_partition_by_name()-203: do not find match in table recovery error partition name! Err imgread(L551):Fail to read 0x100000B from part[recovery] at offset 0 ethernet@fdc00000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110eth init FAILED Retrieving file: pxelinux.cfg/00000000-0000-0000-0000-000000000000 ethernet@fdc00000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110eth init FAILED Retrieving file: pxelinux.cfg/01-02-ad-36-01-7d-7a ethernet@fdc00000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110eth init FAILED Retrieving file: pxelinux.cfg/C0A81FC8 ethernet@fdc00000 Waiting for PHY auto negotiation to complete........ 0 Quote
Werner Posted October 1 Posted October 1 So besides Armbian a more recent image from khadas themselves also fails to boot? 0 Quote
laibsch Posted October 1 Author Posted October 1 1 hour ago, Werner said: So besides Armbian a more recent image from khadas themselves also fails to boot? Yes, the more recent Khadas-supplied image also fails to boot. The unit came with Android flashed from the factory and that image worked fine (but was ugly and I do not know which one it was exactly). Trying to install an Android or Ubuntu image via their OOWOW service also failed but at the time I did not log it via serial console. Maybe it is to do with the changes in VIM4 New? Maybe it is a Ubuntu issue? At this point, I cannot say for sure, yet. I believe I can say with a fair degree of certainty that recent images from both Armbian and Khadas are broken. Other users have reported similar experiences. I am currently going through all kinds of images to see if they work or not. @c0rnelius was kind enough to provide me with a trixie-based, self-compiled image and that one worked, too. He also did not have any issues with other images, but I believe he did not try Android or Ubuntu images, but only Trixie and Coreelec ones. I believe I tried at one point a self-compiled Ubuntu image and that also did not work. Again, I did not get a serial console log for that one. 0 Quote
laibsch Posted October 1 Author Posted October 1 Today's Khadas-supplied Armbian Trixie image works but gives out a warning that it is intended only for developers and not for production. sha256sum: f4a3038ce2f3b67151ceab10d6cb075939262956995038d23d1527fe74fd08d9 Quote WARNING! You are using an automated build meant only for developers to provide constructive feedback to improve build system, OS settings or UX. If this does not apply to you, STOP NOW! Especially don't use this image for production since things might not work as expected or at all. They may break anytime with next update. Creating a new user account. Press <Ctrl-C> to abort 0 Quote
c0rnelius Posted October 1 Posted October 1 You should try erasing the eMMC or re-flashing U-Boot to it. I don't see why that would be necessary, as it wasn't for me. But I did read somewhere on their wiki at one point that in some use cases erasing the eMMC is a work around when getting boot fails. 0 Quote
laibsch Posted October 1 Author Posted October 1 Thank you, @c0rnelius. I might do that. But I believe that in fact, the images are faulty (and hence should be replaced). Can you confirm to boot successfully from any of the ones I marked as broken? 0 Quote
c0rnelius Posted October 1 Posted October 1 @laibsch That first one you posted is one of the ones I boot tested a week ago. It is still in my Download dir. Booted for me. 0 Quote
laibsch Posted October 1 Author Posted October 1 3 hours ago, c0rnelius said: That first one you posted is one of the ones I boot tested a week ago. I retried that image now but with a different installation method, booting into OOWOW (?) via the Function+Reset button, control via serial debug console. I then wget the image from my local server and dd out to /dev/mmcblock0. Subsequent boot was indeed successful. 0 Quote
