Recently, when I run `armbian-upgrade`, I was greeted with an update to raspi-firmware. However, this version of firmware doesn't seem to work with the corresponding intramfs with kernel 6.12.44.
sudo armbian-upgrade
Hit:1 https://mirrors.ustc.edu.cn/armbian trixie InRelease
Hit:2 https://mirrors.ustc.edu.cn/debian trixie InRelease
Hit:3 https://mirrors.ustc.edu.cn/debian trixie-updates InRelease
Hit:4 https://mirrors.ustc.edu.cn/debian-security trixie-security InRelease
Hit:5 https://github.armbian.com/configng stable InRelease
Get:6 https://apt.syncthing.net syncthing InRelease [24.2 kB]
Fetched 24.2 kB in 2s (14.8 kB/s)
2 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following packages will be upgraded:
  armbian-config  raspi-firmware
Summary:
  Upgraded: 2, Newly installed: 0, To remove: 0, Not upgraded: 0
  Download size: 13.2 MB
  Space required/available: 272 kB / 553 GB
Get:1 https://mirrors.ustc.edu.cn/armbian trixie/trixie-utils arm64 raspi-firmware all 1:1.20250915-1~bookworm [13.0 MB]
Get:2 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.11.0-trunk.234.0923.175957 [157 kB]
Fetched 13.2 MB in 2s (5,967 kB/s)
(Reading database ... 46602 files and directories currently installed.)
Preparing to unpack .../raspi-firmware_1%3a1.20250915-1~bookworm_all.deb  ...
Unpacking raspi-firmware (1:1.20250915-1~bookworm) over (1:1.20250430-4~bookworm) ...
Preparing to unpack .../armbian-config_25.11.0-trunk.234.0923.175957_all.deb  ...
Unpacking armbian-config (25.11.0-trunk.234.0923.175957) over (25.11.0-trunk.192.0915.191809) ...
Setting up armbian-config (25.11.0-trunk.234.0923.175957) ...
Setting up raspi-firmware (1:1.20250915-1~bookworm) ...
Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ...
Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ...
WARNING: Unsupported kernel version (6.12.44-current-bcm2711) - skipping setup
NOTE: Manual boot configuration may be required
Processing triggers for initramfs-tools (0.148.3) ...
update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711
WARNING: Unsupported initramfs version (6.12.44-current-bcm2711) - skipping setup
Summary:
  Upgraded: 0, Newly installed: 0, To remove: 0, Not upgraded: 0
How exactly should I do in this case? In the past, I normally invoke update-intramfs to perform the  the intramfs update.
Thanks,
