rezaee Posted October 30, 2017 Share Posted October 30, 2017 Hi I have an ARM-based board(http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M1) and use Armbian(Ubuntu-server 16.04) on it. I have a 2.2" TFT-LCD with SPI connection, and use this framebuffer driver(https://github.com/notro/fbtft) to launch it. I can setup my LCD with this command: sudo modprobe fbtft_device custom name=fb_ili9341 gpios=reset:1,dc:201,led:6 speed=16000000 rotate=90 bgr=1 And before, when I had Ubuntu desktop, I could change display by this command: FRAMEBUFFER=/dev/fb8 startx But in Ubuntu-server I get this error message: X.Org X Server 1.18.4 Release Date: 2016-07-19 X Protocol Version 11, Revision 0 Build Operating System: Linux 4.4.0-97-generic armv7l Ubuntu Current Operating System: Linux nanopim1 3.4.113-sun8i #16 SMP PREEMPT Tue Jun 13 14:15:57 CEST 2017 armv7l Kernel command line: root=UUID=10b3b795-f372-4ea9-b78a-93ae9355c20c rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=bd75a2d6-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 Build Date: 13 October 2017 01:59:44PM xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support) Current version of pixman: 0.33.6 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 26 16:44:04 2017 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" (EE) Fatal server error: (EE) no screens found(EE) (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. (EE) (EE) Server terminated with error (1). Closing log file. And have only a blank screen. I want to know how can I set this LCD as my boards default LCD and make it to run. In addition I must say I have installed xorg, openbox and xserver-xorg-video-fbdev too. Also I did accidentally remove this file's content 01-armbian-defaults.conf And looking for it too. Link to comment Share on other sites More sharing options...
rezaee Posted October 30, 2017 Author Share Posted October 30, 2017 MAy someone puts the contents of 01-armbian-defaults.conf inside : /etc/X11/xorg.conf.d/01-armbian-defaults.conf For NanoPi-M1 Armbian-5.30-Ubuntu-server. Link to comment Share on other sites More sharing options...
