Mikhail M Posted October 6 Posted October 6 at the first launch, I ran into the problem that the board cannot connect to the lan Internet via cable, it writes permanent connection and disconnection in the admin console. therefore, I cannot find out the ip address and understand what to connect to. Please help me if someone knows or has solved this problem. 0 Quote
Werner Posted October 7 Posted October 7 6 hours ago, Mikhail M said: it writes permanent connection and disconnection in the admin console Armbian does not come with some sort of admin console. Please elaborate. Try different patch cable. moved 1 Quote
Mikhail M Posted October 7 Author Posted October 7 The provider's admin console, to be more precise, I'm sorry. 0 Quote
Mikhail M Posted October 7 Author Posted October 7 I use ubunta jammy 1.0.8 for desktop, a 32 GB sd drive, and I was able to achieve a new result: the image was recorded (there were problems with the sd card) and now I just have a red light on all the time, and the operating system does not boot, so the image is not displayed on the monitor, no 0 Quote
Werner Posted October 8 Posted October 8 4 hours ago, Mikhail M said: jammy 1.0.8 Not an Armbian image. If you want to use this one, try to get support from where you got the image from. 0 Quote
