I'm trying create new image, but for end i have error in install.log:
Fingerprinting. Armbian 4.81 Udoo Debian jessie next Linux 4.2.8 info
Displaying message: Building deb package. linux-jessie-root-next-udoo_4.81_armhf.deb info
Displaying message: Install locales en_US.UTF-8 info
chroot: failed to run command ‘/bin/bash’: No such file or directory
Displaying message: Installation of package failed  err
In install.log from archives:
Displaying message: Compiling uboot. Please wait. 2015.10 info
31.12.2015 17:17:23 /home/marcin/sources/u-boot-udoo/2015.10.fslc-qdl/udoo_qdl_config
Displaying message: Target directory /home/marcin/output/debs/ info
Displaying message: Building deb linux-u-boot-next-udoo_4.81_armhf.deb info
Displaying message: Building failed, check configuration. linux-u-boot-next-udoo_4.81_armhf.deb deleted err
Where are you compiling this? On what host? Have you read manuals? Reboot if you get such problems, remove cached files and run again.
Compilation is working on Ubuntu Trusty (checked this moment), elsewhere you need to install proper compiler.
System ubuntu 14.04 on virtual machine. Today i compiled new image udoo ubuntu trusty 3.14.28 but not boot on my udoo quad.
U-Boot SPL 2015.10-armbian (Jan 02 2016 - 11:41:27)
U-Boot 2015.10-armbian (Jan 02 2016 - 11:41:27 +0100)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: UDOO Quad
DRAM:  1 GiB
MMC:   FSL_SDHC: 0
No panel detected: default to HDMI
Display: HDMI (1024x768)
In:    serial
Out:   serial
Err:   serial
Net:   using phy at 6
FEC [PRIME]
switch to partitions #0, OK
mmc0 is current device
Scanning mmc
Found U-Boot script /boot.scr
** File not found /boot.scr **
590 bytes read in 160 ms (2.9 KiB/s)
Running bootscript from mmc ...
## Executing script at 12000000
** File not found /boot/dtb/imx6q-udoo-hdmi.dtb **
6681024 bytes read in 483 ms (13.2 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x65f1c0 ]
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Device Tree: dts/imx6q-udoo-hdmi.dtb
Booting from net ...
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.0.101 (3016 ms)
Using FEC device
TFTP from server 0.0.0.0; our IP address is 192.168.0.101; sending through gateway 192.168.0.1
Filename 'zImage'.
Load address: 0x12000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.0.101 (3015 ms)
Using FEC device
Filename 'dts/imx6q-udoo-hdmi.dtb'.
Load address: 0x18000000
Bad Linux ARM zImage magic!
Your kernel is not compiling properly. That's all I can tell from this boot log.
Check debug log in output/debug or put it to pastebin.com that I can see more info.
boot.scr is present
kernel (zImage) is present
but U-Boot didn't load any Device Tree file (this error is printed by u-boot, not by kernel)
