Hello, I've flashed several times last image from cubox-i but I have this:
Wrong image format for "source" command
file not found /boot.scr
file not fougn /uEnv.txt
file not found /zImage
file not found /uImage
ERROR: Did not find a cndline Flattened Device Tree
Could not find a valid device tree
And more
¿Whats wrong?
Thanks
Edited by korrupto
7z and zip archives can be uncompressed with 7-Zip on Windows, Keka on OS X and 7z on Linux. Images shall only be written with Etcher on all platforms since unlike other tools Etcher validates burning results saving you from corrupted SD card contents.
This is the problem - u-boot does not recognize your board properly. I assume you are trying to run a modern kernel?
Try this. Add:
setenv fdt_file imx6dl-cubox-i.dtb
to /boot/boot.cmd and recompile boot script with mkimage -C none -A arm -T script -d boot.cmd boot.scr  (you will need some Debian based Linux to mount your SD card there and install u-boot-tools)
You can try first with adding
fdt_file=imx6dl-cubox-i.dtb
to /boot/armbianEnv.txt but I am not sure this works properly at Cubox since u-boot is very old.
One (quick and dirty) way is also to copy /boot/dtb/imx6dl-cubox-i.dtb to /boot/dtb/imx6-cubox-i-som-v45.dtb (or whatever you have under file not found)
Than try 3rd option. Copy file from one to another. You only need some linux to access sd card. Something else will most likely have same problem since we all use the same uboot from Solidrun.
Wrote on mobile
