sunshine Posted Wednesday at 06:16 AM Posted Wednesday at 06:16 AM Armbianmonitor: https://paste.armbian.com/yadokinoko Hello, I have installed NextcloudPi on my Raspberry PI5. Current OS is installed currently: Now, I would like to make an upgrade and get the following issue. What can I do? I am very grateful for any help. 0 Quote
mitu Posted Wednesday at 12:28 PM Posted Wednesday at 12:28 PM (edited) Try an apt full-upgrade. The libraspberrypi packages have been deprecated recently (e.g. June/July) and recent RPI packages shouldn't depend on them, including raspi-firmware. Edited Wednesday at 12:28 PM by mitu 0 Quote
sunshine Posted Thursday at 04:32 AM Author Posted Thursday at 04:32 AM Thank you very much for the tip. I have heard that one should avoid updating the firmware if possible. Of course, I don't want my entire system to stop working afterwards. Can that happen? Should I make a complete backup before? 0 Quote
mitu Posted Thursday at 05:05 AM Posted Thursday at 05:05 AM Where did you hear that ? Note that the 'firmware' package is not updating the EEPROM that's present on a Pi4/Pi5 and I had no booting issues updating the raspi-firmware package on RaspiOS.\ Of course you could make a backup if you want to feel safer, but I have no reason to believe there's anything that's going to cause issues if you're going to upgrade the raspi-firmware package. 0 Quote
sunshine Posted Thursday at 09:39 AM Author Posted Thursday at 09:39 AM OK. I tried it without a backup and I still get an error. 0 Quote
mitu Posted Thursday at 03:56 PM Posted Thursday at 03:56 PM @sunshine sorry it didn't work, I though the upgrade for `raspi-firmware` would force the uninstallation of the (outdated) libs, but this doesn't seem to be the case. 0 Quote
geoW Posted Thursday at 05:17 PM Posted Thursday at 05:17 PM The following is documented: Zitat Troubleshooting On Debian bookworm variant you might bump into broken packages dependency, conflicts between firmware and bsp package. Here is how you can solve it: apt update dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current apt --fix-broken install apt install armbian-bsp-cli-rpi4b-current But nobody seems to read the docs.😪 Raspberry Pi 1 Quote
sunshine Posted Thursday at 08:30 PM Author Posted Thursday at 08:30 PM Very good, thank you very much. Stupid question – I have a Raspberry pi5 and the manual mentions rpi4b. Will that work? 0 Quote
Igor Posted yesterday at 04:23 AM Posted yesterday at 04:23 AM 7 hours ago, sunshine said: Will that work? yes 1 Quote
sunshine Posted yesterday at 12:27 PM Author Posted yesterday at 12:27 PM (edited) That sounds good 😃, but is it very risky without a full backup? Or can I save same special files/directories in case of a system crash? I have waste a lot of time with the raspberry because of many problem. Therefore, I'm a little bit fearful. Edited 22 hours ago by sunshine 0 Quote
sunshine Posted 10 hours ago Author Posted 10 hours ago So, I have now tried to solve the problem using the instructions. But unfortunately, it didn't work and I am getting an error message again. I ask for further assistance. 0 Quote
eselarm Posted 4 hours ago Posted 4 hours ago You seem to have the older obsolete special RPI5 build, that doe not exist anymore, it is just 1 RPI build called 'rpi4b' So remove armbian-bsp-cli-rpi5b-current as well apt update dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current armbian-bsp-cli-rpi5b-current apt --fix-broken install apt install armbian-bsp-cli-rpi4b-current 0 Quote
sunshine Posted 2 hours ago Author Posted 2 hours ago Great! That worked. Do I need to do anything else after that? 0 Quote
