Posted (edited)
Yesterday, Oct 20th, I installed armbian version "Minimal/IOT images with Armbian Linux v6.1" to the Orange PI 5 PRO and updated kernel using armbian-config to kernel 6.18 RC1(2 options were available 6.12 and 6.18 R1, note 6.12 did not work).
Armbian works fine including vulkan support(I tested with swith emulator) with this kernel(6.18 rc1), but today option to update to any kernel is not available anymore. I'm getting warning "No other kernels available!"
System is pretty stable with this version.
stas@orangepi5pro:~$ uname -r
6.18.0-rc1-edge-rockchip64
stas@orangepi5pro:~$ vulkaninfo --summary
VULKANINFO
Vulkan Instance Version: 1.4.309
Instance Extensions: count = 24
VK_EXT_acquire_drm_display             : extension revision 1
VK_EXT_acquire_xlib_display            : extension revision 1
VK_EXT_debug_report                    : extension revision 10
VK_EXT_debug_utils                     : extension revision 2
VK_EXT_direct_mode_display             : extension revision 1
VK_EXT_display_surface_counter         : extension revision 1
VK_EXT_headless_surface                : extension revision 1
VK_EXT_surface_maintenance1            : extension revision 1
VK_EXT_swapchain_colorspace            : extension revision 5
VK_KHR_device_group_creation           : extension revision 1
VK_KHR_display                         : extension revision 23
VK_KHR_external_fence_capabilities     : extension revision 1
VK_KHR_external_memory_capabilities    : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2         : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2       : extension revision 1
VK_KHR_portability_enumeration         : extension revision 1
VK_KHR_surface                         : extension revision 25
VK_KHR_surface_protected_capabilities  : extension revision 1
VK_KHR_wayland_surface                 : extension revision 6
VK_KHR_xcb_surface                     : extension revision 6
VK_KHR_xlib_surface                    : extension revision 6
VK_LUNARG_direct_driver_loading        : extension revision 1
Instance Layers: count = 2
VK_LAYER_MESA_device_select Linux device selection layer 1.4.303  version 1
VK_LAYER_MESA_overlay       Mesa Overlay layer           1.4.303  version 1
Devices:
GPU0:
    apiVersion         = 1.1.305
    driverVersion      = 25.0.7
    vendorID           = 0x13b5
    deviceID           = 0xa8670000
    deviceType         = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
    deviceName         = Mali-G610
    driverID           = DRIVER_ID_MESA_PANVK
    driverName         = panvk
    driverInfo         = Mesa 25.0.7-2
    conformanceVersion = 1.4.1.2
Edited by Stanislav Berghici
add logs
This kernel is available only when you change repository to beta.armbian.com , which provides daily builds. EDGE kernels comes as is - glad to hear it works, but beware it might also break down as kernel is changing rapidly.
