jps Posted November 7, 2017 Posted November 7, 2017 Hi. I have made a system with O Pi Lite and Armbian to automate an aquarium from where to control the light, the bubbles and with a webcam I can see the system through the web, everything automated from Cron. From a web page I can turn on and off the lights and bubbles from web buttons. Everything is fine. The problem arises when I want to put some phisical buttons for 3 things: turn off the system, change the state of light and bubbles. I have used a code in Python and the PYA20 library. This is the code. It works very well, but when I start it with the system, the program stop working soon and the buttons stop to work. #!/usr/bin/env python from pyA20.gpio import gpio from pyA20.gpio import port import subprocess import time import os # PIN 29 - IN Light (luz) onoff = port.PA7 # PIN 7 - IN Bubbles (burbujas) luzboton = port.PA6 # PIN 8 - IN Shutdown burbujasboton = port.PA13 # OUT Pins luzvivo = port.PA8 burbujasvivo = port.PA9 gpio.init() #Button ON-OFF gpio.setcfg(onoff, gpio.INPUT) gpio.pullup(onoff, gpio.PULLUP) #Button light gpio.setcfg(luzboton, gpio.INPUT) gpio.pullup(luzboton, gpio.PULLUP) #Button bubbles gpio.setcfg(burbujasboton, gpio.INPUT) gpio.pullup(burbujasboton, gpio.PULLUP) # OUT gpio.setcfg(luzvivo, gpio.OUTPUT) gpio.setcfg(burbujasvivo, gpio.OUTPUT) while True: # PROCESS ON-OFF need 5 seconds to avoid mistaken shutdowns if gpio.input(onoff) == 0: #start counting pressed time print ("pulsado") time.sleep(5) if gpio.input(onoff) == 0 : os.system("shutdown now -h") # PROCESS LIGHT if gpio.input(luzboton) == 0: print ("pulsado luz") estadoluz = gpio.input(luzvivo) gpio.output(luzvivo, not estadoluz) time.sleep(1) # PROCESS bubbles if gpio.input(burbujasboton) == 0: print ("pulsado bubbles") estadoburbujas = gpio.input(burbujasvivo) gpio.output(burbujasvivo, not estadoburbujas) # To avoid bounce time.sleep(1) If i check the procces, i can see it, but i can also see that consumes a lot of CPU: ps aux | grep botones root 652 95.1 0.6 8552 3412 ? Rs 10:53 2:36 python /etc/init.d/botones.py start What i am doing wrong? Thank you in advance.
martinayotte Posted November 7, 2017 Posted November 7, 2017 You need to add a "time.sleep(0.1)" in your "while" loop ...
jps Posted November 7, 2017 Author Posted November 7, 2017 Well, now the consume of CPU lower to 0,1%... thank you very much. BUT... still dying. The file is in /etc/init.d/ and have +x permission. The file starts but after a while dies.... The Python file is called "botones.py". In syslog: Nov 7 16:31:03 localhost systemd[1]: botones.py.service start operation timed out. Terminating. Nov 7 16:31:03 localhost rsyslogd-2007: action 'action 17' suspended, next retry is Tue Nov 7 16:31:33 2017 [try http://www.rsyslog.com/e/2007 ] Nov 7 16:31:03 localhost systemd[1]: Failed to start (null). Nov 7 16:31:03 localhost systemd[1]: Unit botones.py.service entered failed state. If i run from the monitor, never dies....
zador.blood.stained Posted November 7, 2017 Posted November 7, 2017 Scripts in /etc/init.d should double fork, for launching long running processes like this start-stop-daemon, rc.local or systemd "simple" service type should be used.
jps Posted November 7, 2017 Author Posted November 7, 2017 I can not make it work from rc.local... i tried to launch with: nohup python /home/orangepi/scripts/botones.py & and with and without sudo but nothing never runs. I tried too to run from /etc/init.d/.... What am i lossing?
martinayotte Posted November 7, 2017 Posted November 7, 2017 If it is running fine at the command line, I don't see why it is not running in /etc/rc.local ... try adding " > /tmp/botones.log 2>&1" before the ampersand, maybe this log will provide you hints !
jps Posted November 7, 2017 Author Posted November 7, 2017 With: nohup python /home/orangepi/scripts/botones.py > /tmp/botones.log 2>&1 in rc.local, nothing in /tmp folder..... And the script does not run at boot.
jps Posted November 7, 2017 Author Posted November 7, 2017 By the way, in my rc.local i have other scripts that runs normally: #!/bin/sh -e # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. /etc/init.d/entrehoras.sh # CÁMARA HP /etc/init.d/runmjpg.sh # Cámara GEMBIRD #/etc/init.d/runmjpgGEMBIRD.sh nohup python /home/orangepi/scripts/botones.py > /tmp/botones.log 2>&1 #/etc/init.d/botones.sh exit 0
martinayotte Posted November 7, 2017 Posted November 7, 2017 BTW, you have an ampersand missing : nohup python /home/orangepi/scripts/botones.py > /tmp/botones.log 2>&1 & And you don't have any /tmp/botones.log created ? Strange ! Add some print() in the python script ... Try also to change the first line from " #!/usr/bin/env python" to " #!/usr/bin/python" 1
zador.blood.stained Posted November 8, 2017 Posted November 8, 2017 If previous scripts in /etc/rc.local don't return execution (they have no ampersands either and no "start" parameter that suggests that they are a proper LSB init.d scripts) then the 3rd script simply won't be executed.
jps Posted November 8, 2017 Author Posted November 8, 2017 Yes!. It was the "&" at the end of the calls to the scripts. The 3 of them... Now i have too a "/tmp/botones.log". With that and the "sleep.time(0.1)" at the end of the while, all works fine. Thank you both!!! 1
