Terence Posted November 2, 2025 Posted November 2, 2025 I have a raspberry pi running "Armbian 25.11.0-trunk.38 trixie" - I want to use this as a gateway, including running wireguard. When I install 'wireguard' and 'wireguard-tools' I receive this error: ``` Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 2 2 not fully installed or removed. Space needed: 0 B / 27.9 GB available Setting up linux-image-6.12.48+deb13-rt-arm64 (6.12.48-1) ... /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.12.48+deb13-rt-arm64 WARNING: Unsupported initramfs version (6.12.48+deb13-rt-arm64) - skipping setup NOTE: Manual boot configuration may be required /etc/kernel/postinst.d/z50-raspi-firmware: WARNING: Unsupported kernel version (6.12.48+deb13-rt-arm64) - skipping setup NOTE: Manual boot configuration may be required /etc/kernel/postinst.d/zzz-copy-new-files: cp: cannot stat '/usr/lib/linux-image-6.12.48+deb13-rt-arm64//overlays': No such file or directory run-parts: /etc/kernel/postinst.d/zzz-copy-new-files exited with return code 1 dpkg: error processing package linux-image-6.12.48+deb13-rt-arm64 (--configure): installed linux-image-6.12.48+deb13-rt-arm64 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of linux-image-rt-arm64: linux-image-rt-arm64 depends on linux-image-6.12.48+deb13-rt-arm64 (= 6.12.48-1); however: Package linux-image-6.12.48+deb13-rt-arm64 is not configured yet. dpkg: error processing package linux-image-rt-arm64 (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: linux-image-6.12.48+deb13-rt-arm64 linux-image-rt-arm64 ``` It looks like the linux-image-6.12.48+deb13-rt-arm64 (6.12.48-1 package is trying to install an overlay in '/usr/lib/linux-image-6.12.48+deb13-rt-arm64//overlays' but that directory does not exist. The description of this package says: "This package depends on the latest Linux kernel and modules for use on 64-bit ARMv8 machines. " ``` ic linux-image-6.12.48+deb13-rt-arm64 6.12.48-1 arm64 Linux 6.12 for 64-bit ARMv8 machines (signed), PREEMPT_RT ii linux-image-current-bcm2711 25.8.2 arm64 Armbian Linux current kernel image 6.12.56-current-bcm2711 rc linux-image-rt-arm64 6.12.48-1 arm64 Linux for 64-bit ARMv8 machines (meta-package) ``` Any suggestions on how to resolve this? fastfetch output: 0 Quote
Werner Posted November 2, 2025 Posted November 2, 2025 There is no need to install "wireguard" as all Armbian images come with this kernel module by default. All you need is the userspace tools (if not installed already) from "wireguard-tools". If necessary try installing with "--no-install-recommends". 0 Quote
eselarm Posted November 2, 2025 Posted November 2, 2025 Strange thing is that on Armbian Trixie (arm64), if I do 'apt install wireguard', I get as dependencies: linux-image-6.12.48+deb13-rt-arm64 linux-image-rt-arm64 wireguard-tools On vanilla Debian Tixie (arm64), only wireguard-tools Even if I remove/disable all armbian sources, same problem. Anyway the fix/cleanup that works for me (RK3588 platform): apt purge linux-image-6.12.48+deb13-rt-arm64 linux-image-rt-arm64 apt-mark manual wireguard-tools 0 Quote
Terence Posted November 2, 2025 Author Posted November 2, 2025 Installing 'wireguard' caused lots of problems, but wireguard-tools works after restart. 0 Quote
Werner Posted November 3, 2025 Posted November 3, 2025 10 hours ago, eselarm said: Strange thing is that on Armbian Trixie (arm64), if I do 'apt install wireguard', I get as dependencies: linux-image-6.12.48+deb13-rt-arm64 linux-image-rt-arm64 wireguard-tools Nothing strange there. The wireguard package comes from trixie which has dependency to debian's own kernel packages. The package cannot know that there is wireguard kernel-wise already in place or even know about Armbian kernel packages. So this is kind of expected. However I think at some point Armbian kernel packages included a apt information that it provides wireguard. Not sure about the status there. 0 Quote
eselarm Posted November 3, 2025 Posted November 3, 2025 But why the Real-Time kernel and not the normal (linux-image-arm64) kernel package? I actually did run it as a systemd-nspawn -bxD <btrfs read-only snapshot> , so Armbian as container and host vanilla Debian. The actual kernel is then 6.12.48+deb13-arm64, but indeed the Armbian userspace (rootfs tree) has a few others/custom kernels installed only, so standard kernel package is missing. 0 Quote
eselarm Posted November 3, 2025 Posted November 3, 2025 Quick retest in the container if I also install normal Debian kernel: root@ranc:~# apt install linux-image-arm64 wireguard Installing: linux-image-arm64 wireguard Installing dependencies: linux-image-6.12.48+deb13-arm64 wireguard-tools Suggested packages: firmware-linux-free linux-doc-6.12 debian-kernel-handbook openresolv | resolvconf 0 Quote
Werner Posted November 3, 2025 Posted November 3, 2025 3 hours ago, eselarm said: But why the Real-Time kernel and not the normal (linux-image-arm64) kernel package? No clue 0 Quote
