I have a raspberry pi running "Armbian 25.11.0-trunk.38 trixie" - I want to use this as a gateway, including running wireguard. When I install 'wireguard' and 'wireguard-tools' I receive this error:
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 2
  2 not fully installed or removed.
  Space needed: 0 B / 27.9 GB available
Setting up linux-image-6.12.48+deb13-rt-arm64 (6.12.48-1) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.12.48+deb13-rt-arm64
WARNING: Unsupported initramfs version (6.12.48+deb13-rt-arm64) - skipping setup
NOTE: Manual boot configuration may be required
/etc/kernel/postinst.d/z50-raspi-firmware:
WARNING: Unsupported kernel version (6.12.48+deb13-rt-arm64) - skipping setup
/etc/kernel/postinst.d/zzz-copy-new-files:
cp: cannot stat '/usr/lib/linux-image-6.12.48+deb13-rt-arm64//overlays': No such file or directory
run-parts: /etc/kernel/postinst.d/zzz-copy-new-files exited with return code 1
dpkg: error processing package linux-image-6.12.48+deb13-rt-arm64 (--configure):
 installed linux-image-6.12.48+deb13-rt-arm64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rt-arm64:
 linux-image-rt-arm64 depends on linux-image-6.12.48+deb13-rt-arm64 (= 6.12.48-1); however:
  Package linux-image-6.12.48+deb13-rt-arm64 is not configured yet.
dpkg: error processing package linux-image-rt-arm64 (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
It looks like the linux-image-6.12.48+deb13-rt-arm64 (6.12.48-1 package is trying to install an overlay in '/usr/lib/linux-image-6.12.48+deb13-rt-arm64//overlays' but that directory does not exist.
The description of this package says: "This package depends on the latest Linux kernel and modules for use on 64-bit ARMv8 machines. "
ic  linux-image-6.12.48+deb13-rt-arm64 6.12.48-1                      arm64        Linux 6.12 for 64-bit ARMv8 machines (signed), PREEMPT_RT
ii  linux-image-current-bcm2711        25.8.2                         arm64        Armbian Linux current kernel image 6.12.56-current-bcm2711
rc  linux-image-rt-arm64               6.12.48-1                      arm64        Linux for 64-bit ARMv8 machines (meta-package)
Any suggestions on how to resolve this?
fastfetch output:
There is no need to install "wireguard" as all Armbian images come with this kernel module by default. All you need is the userspace tools (if not installed already) from "wireguard-tools".
If necessary try installing with "--no-install-recommends".
Strange thing is that on Armbian Trixie (arm64), if I do 'apt install wireguard', I get as dependencies:
linux-image-6.12.48+deb13-rt-arm64  linux-image-rt-arm64  wireguard-tools
On vanilla Debian Tixie (arm64), only wireguard-tools
Even if I remove/disable all armbian sources, same problem.
Anyway the fix/cleanup that works for me (RK3588 platform):
apt purge linux-image-6.12.48+deb13-rt-arm64 linux-image-rt-arm64
apt-mark manual wireguard-tools
