Tony Mauro Posted November 8, 2017 Posted November 8, 2017 Hi, I've tried setting up an SD Card to boot from and I'm getting the strangest issues. I've tried multiple images and even compiled my own and I'm getting the same issue. I'm booting from SD Card because I have the stock ubuntu running on the emmc right now and I don't want to flash that until I know the image works the way I want it to. Here are the logs I've got from the console on boot. I followed the directions with 7z and Etcher from the documentation page. Thanks for the help! starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3100 bytes read in 196 ms (14.6 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 143 bytes read in 158 ms (0 Bytes/s) ** File not found /boot/dtb/allwinner/sun50i-h5-nanopi-neo-plus2.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 504 bytes read in 529 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 504 bytes read in 538 ms (0 Bytes/s) Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Error applying DT overlays, restoring original DT ** File not found /boot/dtb/allwinner/allwinner/sun50i-h5-nanopi-neo-plus2.dtb ** 5254590 bytes read in 528 ms (9.5 MiB/s) 12957704 bytes read in 897 ms (13.8 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 5254526 Bytes = 5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot.scr reading /boot.scr 850 bytes read in 20 ms (41 KiB/s) ## Executing script at 4fc00000 ** Unrecognized filesystem type ** ** Unrecognized filesystem type ** ** Unrecognized filesystem type ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Bad Linux ARM64 Image magic! SCRIPT FAILED: continuing... Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. No ethernet found. =>
Superkoning Posted November 10, 2017 Posted November 10, 2017 It says "File not found /boot/dtb/allwinner/sun50i-h5-nanopi-neo-plus2.dtb" ... so did you check if that files exists?
Igor Posted November 10, 2017 Posted November 10, 2017 This board is not finished - DT does not exist yet. Yesterday I add Nano Pi M1+ and M1 plus2 and I hope I manage to add this later today.
