Hi
I moved from  3.14 to 4.13. In 3.14 I had a imx framebuffer , needed for my lvds LCD
In the 4.13 kernel menuconfig i cannot find a way to set CONFIG_FB_IMX.
How to enable this?
Dig
It is possible that there are no drivers for this in a modern kernel yet. This is common for all boards. Check around if there are some patches for or prepare to port this driver. We don't have resources for such task.
Hi, thanks for the quick reply.
I was digging in the source and found the DRM stuff.  I have compiled this into the kernel. Still no fb. Have to adapt the dtb.
Is nobody using the LVDS on the solo module?
Dig
I have trouble getting the driver (imx-ldb)  to load. It is present in the kernel, but there is no sign of it in dmesg. Also no fb.
In my dtb:
    //    ldb: ldb {      The address was missing in the original dtsi , needed?
            ldb: ldb@020e0008 {
                #address-cells = <1>;
                #size-cells = <0>;
                compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb";      The driver is imx6q   Works for Solo ?
                gpr = <&gpr>;
                status = "okay";
                lvds-channel@0 {
                #size-cells = <0>;
                    reg = <0>;
                    status = "okay";
                    port@0 {
                        reg = <0>;
                        lvds0_mux_0: endpoint {
                            remote-endpoint = <&ipu1_di0_lvds0>;
                    port@1 {
                        reg = <1>;
                        lvds0_mux_1: endpoint {
                    //        remote-endpoint = <&ipu1_di1_lvds0>;
                            remote_endpoint = <&panel_in>;
                panel { // klp
                    compatible = "mitsubishi,aa121td01", "panel-lvds";
                    width-mm = <261>;
                    height-mm = <163>;
                    data-mapping = "jeida-24";
                    panel-timing {
                        clock-frequency = <60000000>;
                        hactive = <1024>;
                        vactive = <600>;
                        hback-porch = <160>;
                        hfront-porch = <160>;
                        vback-porch = <23>;
                        vfront-porch = <12>;
                        hsync-len = <70>;  // 60
                        vsync-len = <15>;// 10
                        // <1>: high active
                        // <0>: low active
                        hsync-active = <1>;//hsync pulse is active low/high/ignored
                        vsync-active = <1>;//vsync pulse is active low/high/ignored
                        //    de-active = <1>;
                        pixelclk-active = <1>;// active high = drive pixel data on rising edge/sample data on falling edge
                        // active low  = drive pixel data on falling edge/    sample data on rising edge
                    port {
                        panel_in: endpoint {
                            remote-endpoint = <&lvds_out>;
Any idea?
            ldb: ldb@020e0008 {
No, node name is irrelevant.
I would suggest looking at DT bindings docs: https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/tree/Documentation/devicetree/bindings/display/imx
Thanks,
I did, with above result. If the driver would not work for the solo i expect to see a message when the the driver is probed. It seems that no attempt is made to load the driver.
