Posted (edited)
@Sand_Death I just updated my build with @alexc's BSP changes, which include the latest AIC8800 drivers. I'm building an image right now, so I haven't tested it yet.
I haven't tested Ethernet either. Maybe Alex can help you with that.
Edited by Nick A
My board is A7Z so unfortunately I couldn't fully test the Ethernet drivers.
Hi @qq20739111 / @humanus, any luck with the on board Ethernet?
FYI, my new version utilizes mainline MMC drivers as well. And I'm looking into PCIE at the moment.
Posted (edited)
OK, it looks like the BSP PCIe driver might have some issues related to power management. I’m not entirely sure of the root cause yet, but when I connected an NVMe drive, it got extremely hot and failed to initialize properly.
The NVMe dmesg output suggested adding the following kernel parameters:
nvme_core.default_ps_max_latency_us=0 pcie_aspm=off
This resolved the NVMe issues on my side. I’ll try to dig deeper into the root cause, but @humanus please give it a try as well.
Edited by alexc
I tried to boot via EMMC using alexc's/Nick's BSP Kernel (6.18) and had a kernel panic: https://pastebin.com/aPhDfFzr
The crash occurs in thread T77 (a background worker) while it is attempting to scan for SD cards (mmc_rescan).
More specifically, the crash occurs when calling sd_uhs2_power_up, which is requested by mmc_attach_sd_uhs2. Here, the kernel is attempting to power up the power supply for the UHS-II SD card protocol.
Hi @Marvin-03, could you try the latest build?
It looks like your board is still using the BSP MMC driver, but we migrated to the mainline MMC driver last week. That should at least resolve the issue you're currently seeing.
Also looking forward to your testing on the eMMC side, since the A7Z does not have eMMC support.
Posted (edited)
@Nick A I had to modify the "0011-Add-BSP-support-files-afa7aabb90" patch in the "Radxa-mainline-WIP-test" branch to allow compiling. This is the new patch file: https://pastebin.com/3Qc2bGPY
After flashing the image to the emmc I got this bootlog: https://pastebin.com/eqsZ2d1r
It seems like it wont leave the U-Boot.
I used this command to flash the image: sudo dd if=/mnt/transcend/Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a7a_trixie_edge_6.18.19_gnome_desktop.img of=/dev/mmcblk1 bs=4M status=progress conv=fsync
@alexc Do you know if the A523 and A733 use the same pcie driver? I've already optimized the A523 pcie driver and its in the mainline armbian.
Edited by Marvin-03
Hello, I am attempting to run armbian off of UFS on an a7z and running into issues.  I don't know if I'm missing something fairly basic.
- Board is unmodified by me.  I don't know how commonly sellers mod these boards themselves, but there is a bit of scuffing on the ram and UFS chip.  It has 8gb ram, the official hsf, and the official power supply.  Display over HDMI, USB hub for IO.
- I can boot the official radxa image from the ufs, flashing it with
sudo dd if=<path_to_image> of=/dev/sda bs=4M status=progress conv=fsync
- I have successfully built and booted armbian trixie 6.6 kernel with kde on the sd card.  I had to do some tty backflips to get kde to launch once it booted, but it did run.  I have also booted the released armbian xfce build from sd, which I had no problems with at all.
- Currently I have the official radxa image booted off the sd card, and I have been attempting to build and flash armbian for ufs.
- I built with ./compile.sh, board selection: radxa-cubie-a7z-ufs, vendor 6.6, trixie, desktop, kde, no extras
- Flashed to the ufs with the same command from above from my session on the radxa build sd card, and rebooted without the sd card.  The green LED comes on solid, then the fan kicks in, then the LED turns off.  My display comes up out of sleep, black screen for a second, then no signal.
- After about 25 minutes, I disconnected power, and booted back into the sd card.  Here is the boot.log from the ufs: https://pastebin.com/ASpndqVU
Posted (edited)
@Nick A My bad, cleaned my build folder and it compiled fine.
Still, it is still stuck in the bootloader
Bootlog:
https://pastebin.com/ckqP10Bb
I tried with both of my board with and without emmc installed.
UPDATE: After applying Nick's changes it works fine with gnome. The EMMC still doesnt get recognized by the kernel driver.
The bootlog is still the same when booting via EMMC with the new image.
Edited by Marvin-03
@Marvin-03
Just to confirm: for both boards, with and without eMMC, are you using the same microSD card as the boot device?
From the current boot log, it looks like there may be an issue with the microSD card. Both the previous boot log (using the BSP MMC driver) and the current boot log (using the mainline MMC driver) show problems detecting mmc0 (the microSD card).
Could you try a different microSD card, preferably from another brand, and see if the issue persists?
Posted (edited)
@Marvin-03 It is past the bootloader. I only tested the build on XFCE, which boots fine. GNOME failing to boot properly might be due to the PowerVR or KMScon install script.
If you need GNOME. Try removing the function post_family_tweaks__install_powervr_desktop().
https://github.com/NickAlilovic/build/blob/Radxa-mainline-WIP-test/config/sources/families/sun60iw2.conf#L467-L1045
Update:
I removed both post_family_tweaks__install_powervr_desktop() and kmscon install funtions. Gnome works. But you need to use a serial device to fill in the first login information.
Edited by Nick A
@alexc What pcie hat do you use? I use one from Yahboom made for the RPI 5, but my nvme wont show up and since logs show "sunxi:pcie-rc-6000000.pcie:[ERR]: Speed change timeout" it seems like the hat doesnt work. On the Cubie A5E I only get this timeout if the SSD isnt plugged in.
@Marvin-03
You're probably right—it may be worth checking the FPC connection. A timeout usually only occurs when the PCIe/NVMe board is not being detected.
I'm currently using an early MCUZone NVMe 2230 HAT. I recently ordered a new Waveshare AIO HAT as well, so once it arrives I'll be able to do some additional testing.
I wanted to report a specific regression regarding CPU frequency scaling on the Radxa Cubie A7S and share the DTS workaround that fully restores complete functionality.
The Regression Behavior
November Kernel State: Using the kernel branch/commit built back in November (running Linux version 6.6.98-vendor-sun60iw2 #SMP PREEMPT Wed Nov 19 2025 ), CPU frequency scaling worked perfectly out of the box. All available frequencies scaled smoothly across both core clusters, and the benchmark results for my specific A7S board were fully aligned with Thomas Kaiser's provided optimization targets.
May Kernel State: After updating to the recent kernel build (mid-May 2026), CPU frequency scaling completely broke under the stock DTB configuration. The core clusters refused to scale through their operational performance points properly.
The Frequency Trick & DTS Fix
The root cause was isolated to how cpufreq binds under the newer kernel configuration, specifically linked to the inclusion of CONFIG_CPUFREQ_DT_PLATDEV=y.
To make the scaling work seamlessly on the latest May kernel, the underlying Device Tree needs a dedicated adjustment in the opp-table and driver mapping. By manually adapting the standard DTS bindings for the sun60iw2 platform to explicitly force correct platform-device scaling registration, all operational frequencies are now fully functional and stable again on the new kernel.
Request for Review/Merge@Nick (or current DTB maintainer),
cubie_a7s.zip
could you please verify this behavior against the latest repository changes? If everything checks out on your end, please pull this DTS patch into the main Armbian sunxi tree so that the Cubie A7S doesn't remain locked to lower fallback states on fresh updates.Let me know if you need the raw diff -u dump of the modified .dts files attached!
cubie_a7s.zip
test with 1.5V CPU voltage, the SBC draws over two amps. You need a really good active heatsink.
7-Zip (r) 25.01 (arm64) : Igor Pavlov : Public domain : 2025-08-03
 64-bit arm_v:8-A locale=en_US.UTF-8 Threads:8 OPEN_MAX:1024, ASM
Compiler:  ver:14.2.0 GCC 14.2.0 : UNALIGNED
Linux : 6.6.98-vendor-sun60iw2 : #2 SMP PREEMPT Fri May 15 10:57:21 CEST 2026 : aarch64
PageSize:4KB hwcap:119FFB:CRC32:SHA1:SHA2:AES:ASIMD
arm64
1T CPU Freq (MHz):  1267  2000  2000  2000  2000  2000  2000
4T CPU Freq (MHz): 366% 1621   367% 1631
8T CPU Freq (MHz): 742% 1561   746% 1580
RAM size:    5906 MB,  # CPU hardware threads:   8
RAM usage:   1779 MB,  # Benchmark threads:      8
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       9894   757   1272   9625  |     226530   685   2821  19317
23:       9405   767   1249   9583  |     219768   687   2768  19010
24:       8867   766   1245   9535  |     213378   689   2717  18722
25:       8382   753   1271   9571  |     205891   692   2649  18320
Avr:      9137   761   1259   9578  |     216392   688   2739  18842
Tot:             724   1999  14210
And the same test with 1.32V, SBC draws 1.5 amps
Last login: Fri Jun  5 11:11:21 2026 from 192.168.11.50
root@radxa-cubie-a7s:~# 7zr b
arm64
1T CPU Freq (MHz):  1393  1682  2000  2000  2000  2000  2000
4T CPU Freq (MHz): 369% 1606   367% 1634
8T CPU Freq (MHz): 743% 1552   745% 1573
22:       9314   722   1254   9061  |     224321   686   2790  19128
23:       8943   752   1211   9113  |     217854   688   2739  18845
24:       8556   749   1228   9200  |     210699   688   2686  18487
25:       8216   754   1244   9382  |     202281   686   2623  17999
Avr:      8758   745   1234   9189  |     213789   687   2710  18615
Tot:             716   1972  13902
@Jacob GeorgeThat's excellent progress, thanks for sharing!
EDK2 support on the A733 would be a very welcome addition, and it's great to hear the port is moving along so quickly.
One thing that would be especially valuable for the community is if some of the platform work could eventually be drafted as mainline kernel patches/drivers. That would save a lot of development effort and benefit everyone using these boards.There are already a few A733 patches in 7.x or in the queue.
Looking forward to seeing the project reach the finish line.
@alexc Had to take a couple days break while we wait for a ordered Oscilloscope and CH341 to arrive. Current focus is SPI-NOR which is the most dangerous part of this EDK2 port due to the vendor of the board not releasing  it to the public. That doesn't stop us tinkerers from from physically pulling it from the on-board SPI-NOR, so holding back such a valuable piece of the puzzle serves what purpose? They released it for the Rockchip SoC so who knows. After the SPI-NOR is conquered I hope to get some runtime pixels on the screen. I say around that time the EDK2 will be more of a usable boot loader to start on the alpha release (compiled public release). Right now I can boot to a generic Ubuntu 26.04 with working ssh and uart so things are looking good. Working with Opus 4.8 has been surprisingly very productive. These models have got so much better, I find myself getting more sleep by using Openclaw HEARTBEAT.md to nudge Opus 4.8 every 30 minutes to autonomously  work on the port in my absence :) My good guy has a full report of his work  done and ready to review by lunchtime :D
I can not get anything over USB to UART, I did connected pins 6,8,10 it is COM6 Prolific PL2303GT cable, when I cros wire green and yellow I get response from Putty, please give me some advice, what am I missing?
@Nick A @alexc
Update: Hailo8 AI HAT issue - Root cause found
First, a quick update on the Ethernet issue — I set the board aside for a while, noticed some activity in the GitHub repository, rebuilt the firmware, and it worked.
Now I'm trying to run Frigate with a Hailo8 AI HAT (marketed for Raspberry Pi 5, with an M.2 slot). The device loads firmware successfully but becomes completely unresponsive. After extensive debugging I believe I found the root cause.
Problem: MSI interrupts not working
bash$ cat /sys/bus/pci/devices/0000:04:00.0/msi_irqs/
# empty — MSI not configured
$ lspci -vvv -s 04:00.0 | grep MSI
Capabilities: [e0] MSI: Enable- Count=1/1 Maskable- 64bit+
    Address: 0000000000000000  Data: 0000
# Address is zero — MSI never configured by kernel
$ cat /proc/interrupts | grep hailo
# empty — no interrupt handler registered
Interrupt: pin ? routed to IRQ 492
# "?" means no INTx routing either
Hailo8 uses MSI interrupts to signal command completion. Without MSI, every fw_control ioctl waits 1000ms and times out. The device loads firmware successfully but becomes unusable for any actual inference.
PCIe topology:
00:00.0 Root Port
01:00.0 ASMedia ASM1182e PCIe Switch (upstream)
02:07.0 ASMedia ASM1182e PCIe Switch (downstream)
04:00.0 Hailo-8 AI Processor
Kernel: 6.18.19-edge-sun60iw2 (Armbian community build)
It seems the sunxi PCIe driver does not support MSI for devices behind an ASMedia PCIe switch. Is this a known limitation? Is there a fix or workaround available?
@Sand_Death
congrats on finding this... I also found the sunxi PCIE driver to be limited. I think someone would need to develop it a bit, or write something from scratch, in order to get more devices to work.
