WiringOP I2C interface not working
OldBikerPete
I've installed this library on an Orange Pi PC Plus running 'Armbian 5.31 stable Ubuntu 16.04.3 LTS 3.4.113-sun8i' with all updates and I would like to use wiringPiI2C but it doesn't work with either /dev/i2c-0 or /dev/i2c-1.
My USB storage CRO device shows no output at all when I attempt a write to an I2C device on connector pins 3 and 5 (BCM pins 2 & 3).
the 'gpio' app and 'blink' example apps that come with the library wiggles these and other pins as outputs, no trouble at all.
I'm porting a library that interfaces to a DS3232 or DS3231 real-time-clock chip from Arduino and have used the initialisation sequence from the example in the WiringOP library as below.
static int sfd;
void DS323xRTC(bool *retVal) {
    wiringPiSetup();
    if((sfd = wiringPiI2CSetupInterface("/dev/i2c-1", DS323x_I2C_ID)) < 0) {
        *retVal = false
        return;
// Control reg All disabled, EOSC low = oscillator enabled.
    wiringPiWriteReg8(sfd, CONTROL_REG, 0x00);
    wiringPiWrite(sfd, 0x08);   // Status/Control reg, Enable 32kHz output
    *retVal = true;
I note that the I2C examples that come with this library drive an I2C device via software bit-bashing.
Has anybody been able to use from C++ the I2C interface built into the H3 chip? If so, how did you get it working?
Peter.
Sorry about the long delay. I've had issues!
Installed I2C-tools and ran i2cdetect on an Orange Pi PC plus and an Orange Pi Zero - both running the same Armbian distro. The results are below. /dev/i2c-0 detected a non-existent (as far as I know) device at 0x48 and the /dev/i2c-1 device detected nothing at all.
In the interval since my first post on this subject, I wrote a bit-bashing library for the I2C bus on connector pins 3 and 5 and this works a treat with a DS3231 clock chip located at address 0x68 on the I2C bus on both CPUs using the gpio pin part of the WiringOP library to access the bits and a microsecond delay routine. Note that i2cdetect did not find my clock chip on the bus.
root@orangepizero:~# i2cdetect 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@orangepizero:~# i2cdetect 1
I will probe file /dev/i2c-1.
Continue? [Y/n] y
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Peter.
Note that I'm investigating a message that flashes by at boot-up on the debug serial port. 'FAILURE: Linux Kernel modules failed to load'
