cofrandp Posted November 14 Posted November 14 Hello, I've been using https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html with a custom kernel that I built to activate my TPM2.0 device and it works. Now I'm asked to use an UEFI compatible image with my Orange Pi 5 Plus. So what I did is more or less the same thing that in here But instead of the legacy kernel I used the 6.1.115-rockchip-vendor-rk35xx kernel and my device booted, I got an HDMI output, etc. And then I updated it to my custom kernel (6.1.0-1027-rockchip) that has the necessary configurations to allow TPM over SPI. Now I'm trying to activate my TPM2.0 as I did before. To do that I added my compiled *.dtbo (rk3588-spi0-tpm-cs1.dtbo) to /boot/dtb/rockchip/overlay and activated it with armbian-config. After reboot this is my /boot/armbianEnv.txt orangepi@uefi-arm64:~$ cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both extraargs=cma=256M overlay_prefix=rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=3e555b58-fdf4-4e2f-a3af-a8ecfd8034b6 rootfstype=ext4 overlays=spi0-tpm-cs1 param_spidev_spi_bus=0 However I still can't see my tpm under /dev/. I don't know what I'm missing, I'm quite new to this sorry Thank you for your time 0 Quote
Werner Posted November 14 Posted November 14 You should check uboot logs if the dtbo is loaded correctly. You can get those using a debug serial console. If you don't know what that is or how to connect: https://debug.armbian.de 0 Quote
royk Posted November 15 Posted November 15 Did you also install the dtb that belongs to that kernel version? You could check if the dtbo is compatible with your dtb with: fdtoverlay -v -i /boot/dtb/current.dtb -o /tmp/test.dtb your-overlay.dtbo It would be better to compile the dts with armbian-add-overlay your-overlay.dts so it will automatically install it to /boot/overlay-user and added to your armbianEnv.txt. In this way it also won't get overwritten when you update the dtb. And of course like Werner said, check the debug serial console, you'll see much more detailed information. And check if the symlinks are correctly linked to your kernel version. ls -l /boot 0 Quote
cofrandp Posted November 19 Author Posted November 19 Hello, Thank you for your answers. I decided to recompile the whole image with the correct configuration to be sure I did not mess up anything when updating my kernel (following this https://github.com/armbian/build/commit/54c896e0298a441338cd7d29f312ca590304f120 , using BRANCH=vendor RELEASE=noble) I was able to get the boot logs (see attached file). It seems since I'm using UEFI it completely bypasses the U-Boot applying the overlays ( i can see EFI stub: Using DTB from configuration table inside the logs but no Applying device tree overlay...) . I'll try to recompile the image while integrating my overlay directly into it to see if it works. boot.logs 0 Quote
The Tall Man Posted November 19 Posted November 19 (edited) Since you're using UEFI, you can use Grub to boot. Grub has a Devcetree command. There's also a post here on how to integrate overlays: Edited November 19 by The Tall Man 0 Quote
Solution cofrandp Posted November 19 Author Solution Posted November 19 (edited) So I rebuilt the image, applied a patch to integrate the tpm into the dts during the build and it works. I still need to figure out how to make overlays work with GRUB in case we need them. Thank you for your support Edited November 19 by cofrandp 0 Quote
