I have the temperature sensor DS18B20 connected to port 20 of the gpio as w1, if I want to connect another sensor it is as easy as adding a w2 and its port in /boot/bin/orangepiplus2e.bin
[w1_para]
w1_used = 1
gpio = 20
[w2_para]
w2_used = 1
gpio = 10
or
[w1_para]
w1_used = 1
gpio = 20
gpio = 10
So or something else? thanks
Onewire does have limitations on bus capacitance and length.  When using multiple sensors on one interface, it is best to not have stubs, wire to one sensor then the next rather than both from the pi.  You are also more likely to need to power your sensors rather than have them just on the bus.
...but the 3.4.x legacy kernel has a limitation - you won't be able to instantiate more than one 1-wire bus without patching and recompiling the kernel.
Linear or star topology, not using parasite power, pull-up resistor value are details that would need to be adjusted for better reliability or even to make things work to start with.
I would recommend reading this application note: https://www.maximintegrated.com/en/app-notes/index.mvp/id/148
