Ok!, finally... Ready for the mainline experiments.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-119590-gcb31337-dirty (alex@svn) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08)) #1 SMP Thu Nov 16 12:25:11 -02 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Xunlong Orange Pi PC
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 65536
[    0.000000] free_area_init_node: node 0, pgdat c0a60540, node_mem_map cfdfa000
[    0.000000]   Normal zone: 512 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 65536 pages, LIFO batch:15
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 16 pages/cpu @cfda7000 s33740 r8192 d23604 u65536
[    0.000000] pcpu-alloc: s33740 r8192 d23604 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes panic=10
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 248640K/262144K available (6144K kernel code, 388K rwdata, 1428K rodata, 1024K init, 254K bss, 13504K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
                   lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0700000   (7136 kB)
                     .init : 0xc0900000 - 0xc0a00000   (1024 kB)
                     .data : 0xc0a00000 - 0xc0a61120   ( 389 kB)
                      .bss : 0xc0a6807c - 0xc0aa798c   ( 255 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018] Switching to timer-based delay loop, resolution 41ns
[    0.000198] Console: colour dummy device 80x30
[    0.000232] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000245] pid_max: default: 32768 minimum: 301
[    0.000367] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000380] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000960] CPU: Testing write buffer coherency: ok
[    0.001336] CPU0: update cpu_capacity 1024
[    0.001347] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001663] Setting up static identity map for 0x40100000 - 0x40100060
[    0.001762] Hierarchical SRCU implementation.
[    0.002252] smp: Bringing up secondary CPUs ...
[    0.012873] CPU1: update cpu_capacity 1024
[    0.012878] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.023565] CPU2: update cpu_capacity 1024
[    0.023570] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.034215] CPU3: update cpu_capacity 1024
[    0.034220] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.034287] smp: Brought up 1 node, 4 CPUs
[    0.034312] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.034318] CPU: All CPU(s) started in HYP mode.
[    0.034322] CPU: Virtualization extensions available.
[    0.035030] devtmpfs: initialized
[    0.039678] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.039897] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.039920] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.040196] pinctrl core: initialized pinctrl subsystem
[    0.041014] NET: Registered protocol family 16
[    0.041399] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.042218] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.042229] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.054483] SCSI subsystem initialized
[    0.054718] libata version 3.00 loaded.
[    0.054886] usbcore: registered new interface driver usbfs
[    0.054929] usbcore: registered new interface driver hub
[    0.054997] usbcore: registered new device driver usb
[    0.055183] pps_core: LinuxPPS API ver. 1 registered
[    0.055190] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.055208] PTP clock support registered
[    0.055406] Advanced Linux Sound Architecture Driver Initialized.
[    0.056137] clocksource: Switched to clocksource arch_sys_counter
[    0.062580] NET: Registered protocol family 2
[    0.063067] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.063101] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.063138] TCP: Hash tables configured (established 2048 bind 2048)
[    0.063258] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.063300] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.063477] NET: Registered protocol family 1
[    0.063831] RPC: Registered named UNIX socket transport module.
[    0.063841] RPC: Registered udp transport module.
[    0.063847] RPC: Registered tcp transport module.
[    0.063852] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.064120] Unpacking initramfs...
[    0.106468] Freeing initrd memory: 960K
[    0.108085] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[    0.113005] NFS: Registering the id_resolver key type
[    0.113051] Key type id_resolver registered
[    0.113059] Key type id_legacy registered
[    0.113874] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.113888] io scheduler noop registered
[    0.113895] io scheduler deadline registered
[    0.114099] io scheduler cfq registered (default)
[    0.114107] io scheduler mq-deadline registered
[    0.114113] io scheduler kyber registered
[    0.114681] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.118187] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.119586] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.162555] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.164825] console [ttyS0] disabled
[    0.184987] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
[    0.818795] console [ttyS0] enabled
[    0.825085] libphy: Fixed MDIO Bus: probed
[    0.829231] CAN device driver interface
[    0.833578] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.839384] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.845077] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.851200] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.856873] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.864086] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.869747] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.876966] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.881924] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.888812] libphy: stmmac: probed
[    0.893706] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.900253] ehci-platform: EHCI generic platform driver
[    0.905663] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.911268] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.919171] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[    0.946147] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.952915] hub 1-0:1.0: USB hub found
[    0.956720] hub 1-0:1.0: 1 port detected
[    0.961249] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.967468] ohci-platform: OHCI generic platform driver
[    0.972861] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.979508] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.987348] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[    1.060700] hub 2-0:1.0: USB hub found
[    1.064488] hub 2-0:1.0: 1 port detected
[    1.072226] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.079047] sun6i-rtc 1f00000.rtc: RTC enabled
[    1.083646] i2c /dev entries driver
[    1.087947] IR NEC protocol handler initialized
[    1.092473] IR RC5(x/sz) protocol handler initialized
[    1.097551] IR RC6 protocol handler initialized
[    1.102075] IR JVC protocol handler initialized
[    1.106614] IR Sony protocol handler initialized
[    1.111223] IR SANYO protocol handler initialized
[    1.115919] IR Sharp protocol handler initialized
[    1.120632] IR MCE Keyboard/mouse protocol handler initialized
[    1.126472] IR XMP protocol handler initialized
[    1.131503] Registered IR keymap rc-empty
[    1.135604] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
[    1.142349] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input0
[    1.149885] input: MCE IR Keyboard/Mouse (sunxi-ir) as /devices/virtual/input/input1
[    1.157835] sunxi-ir 1f02000.ir: initialized sunXi IR driver
[    1.164175] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.173241] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.246155] sunxi-mmc 1c0f000.mmc: base:0xd0883000 irq:26
[    1.252652] usbcore: registered new interface driver usbhid
[    1.258255] usbhid: USB HID core driver
[    1.263235] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    1.271192] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.278016] NET: Registered protocol family 17
[    1.282483] can: controller area network core (rev 20170425 abi 9)
[    1.288759] NET: Registered protocol family 29
[    1.293200] can: raw protocol (rev 20170425)
[    1.297487] can: broadcast manager protocol (rev 20170425 t)
[    1.303143] can: netlink gateway (rev 20170425) max_hops=1
[    1.308850] Key type dns_resolver registered
[    1.313254] Registering SWP/SWPB emulation handler
[    1.328005] ehci-platform 1c1b000.usb: EHCI Host Controller
[    1.333618] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    1.341565] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
[    1.376155] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    1.382969] hub 3-0:1.0: USB hub found
[    1.386802] hub 3-0:1.0: 1 port detected
[    1.391440] ehci-platform 1c1c000.usb: EHCI Host Controller
[    1.397055] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    1.404909] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
[    1.417712] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.429311] mmc0: new high speed SDHC card at address aaaa
[    1.435190] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    1.439858] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    1.446917] hub 4-0:1.0: USB hub found
[    1.450735]  mmcblk0: p1 p2
[    1.453661] hub 4-0:1.0: 1 port detected
[    1.458803] ehci-platform 1c1d000.usb: EHCI Host Controller
[    1.464392] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    1.472282] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
[    1.506146] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    1.512822] hub 5-0:1.0: USB hub found
[    1.516620] hub 5-0:1.0: 1 port detected
[    1.521136] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    1.527781] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    1.535656] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
[    1.610722] hub 6-0:1.0: USB hub found
[    1.614499] hub 6-0:1.0: 1 port detected
[    1.619018] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    1.625643] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    1.633483] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
[    1.710668] hub 7-0:1.0: USB hub found
[    1.714443] hub 7-0:1.0: 1 port detected
[    1.718955] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    1.725587] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    1.733427] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
[    1.810686] hub 8-0:1.0: USB hub found
[    1.814460] hub 8-0:1.0: 1 port detected
[    1.819020] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.830092] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.835840] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
[    1.843721] usb 4-1: new high-speed USB device number 2 using ehci-platform
[    1.851465] hub 9-0:1.0: USB hub found
[    1.855246] hub 9-0:1.0: 1 port detected
[    1.860570] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    1.868509] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.874985] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:00:10 UTC (10)
[    1.883282] vcc3v0: disabling
[    1.886267] vcc5v0: disabling
[    1.889233] usb0-vbus: disabling
[    1.892456] ALSA device list:
[    1.895418]   No soundcards found.
[    1.900466] Freeing unused kernel memory: 1024K
[    1.916248] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    1.986345] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.994971] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.015529] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    2.049189] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    2.057140] sun4i-codec 1c22c00.codec: Failed to register our card
[    2.127449] hub 5-1:1.0: USB hub found
[    2.131324] hub 5-1:1.0: 4 ports detected
[    2.137354] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    2.145279] sun4i-codec 1c22c00.codec: Failed to register our card
[    2.407053] systemd[1]: System time before build time, advancing clock.
[    2.441930] systemd[1]: Failed to insert module 'autofs4': No such file or directory
[    2.480279] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    2.498856] systemd[1]: Detected architecture arm.
[    2.537302] systemd[1]: Set hostname to <nanopi-duo>.
[    2.823907] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.856489] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.886263] systemd[1]: Reached target Swap.
[    2.916352] systemd[1]: Listening on udev Kernel Socket.
[    2.946236] systemd[1]: Reached target Encrypted Volumes.
[    2.976486] systemd[1]: Created slice System Slice.
[    3.006457] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    3.376485] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.147896] systemd-journald[99]: Received request to flush runtime journal from PID 1
[    5.463568] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    5.708824] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    5.716836] sun4i-codec 1c22c00.codec: Failed to register our card
[    5.719010] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.720928] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    5.720941] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    8.876722] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
1 hour ago, Nuno Goncalves said:
Great. But Ethernet support is already on 4.14.0?
Yes, fully working. I have not done any benchmark or stress test. I tried to make DT from  scratch for DUO without success and now it is based  on opi pc.  BTW i have not heard there was any issue with ethernet in 32 bit.
PS: If you mean wifi, i am giving a try now.
Edited by @lex
ethernet wifi
Some progress with my DT, only missing ALSA device finding. Will try to fix that.
Kernel switched to megous (Credits) with very little tweaks. Works very nice with nano pi DUO + SHIELD for tests.
If @Igor or @zador.blood.stained wants to push that to test or fix the ALSA thing let me know  how to proceed.
Next step is to work with banana pi zero DT when i receive it.
kenel 4.14.0:
[    0.000000] Linux version 4.14.0-h2-2 (alex@svn) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08)) #1 SMP Sat Nov 25 11:18:32 -02 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[    0.000000] OF: fdt: Machine model: FriendlyArm NanoPi DUO
[    0.000000] cma: Reserved 16 MiB at 0x4f000000
[    0.000000] free_area_init_node: node 0, pgdat c0bcd240, node_mem_map cedb1000
[    0.000000]   Normal zone: 576 pages used for memmap
[    0.000000] percpu: Embedded 17 pages/cpu @ced58000 s39628 r8192 d21812 u69632
[    0.000000] pcpu-alloc: s39628 r8192 d21812 u69632 alloc=17*4096
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 64960
[    0.000000] allocated 262144 bytes of page_ext
[    0.000000] Memory: 230088K/262144K available (6144K kernel code, 894K rwdata, 2032K rodata, 1024K init, 319K bss, 15672K reserved, 16384K cma-reserved, 0K highmem)
                   modules : 0xbf800000 - 0xbfe00000   (   6 MB)
                     .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
                     .data : 0xc0b00000 - 0xc0bdf8e4   ( 895 kB)
                      .bss : 0xc0be7528 - 0xc0c37284   ( 320 kB)
[    0.000000] ftrace: allocating 33872 entries in 67 pages
[    0.000015] Switching to timer-based delay loop, resolution 41ns
[    0.000204] Console: colour dummy device 80x30
[    0.000236] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000247] pid_max: default: 32768 minimum: 301
[    0.000431] Security Framework initialized
[    0.000443] AppArmor: AppArmor disabled by boot time parameter
[    0.000500] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000508] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001357] CPU: Testing write buffer coherency: ok
[    0.001796] CPU0: update cpu_capacity 1024
[    0.001802] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002164] Setting up static identity map for 0x40100000 - 0x40100054
[    0.002266] Hierarchical SRCU implementation.
[    0.002989] smp: Bringing up secondary CPUs ...
[    0.013688] CPU1: update cpu_capacity 1024
[    0.013694] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.024467] CPU2: update cpu_capacity 1024
[    0.024472] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.035194] CPU3: update cpu_capacity 1024
[    0.035200] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.035283] smp: Brought up 1 node, 4 CPUs
[    0.035291] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.035295] CPU: All CPU(s) started in HYP mode.
[    0.035297] CPU: Virtualization extensions available.
[    0.036213] devtmpfs: initialized
[    0.042478] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.042717] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.042734] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.043987] pinctrl core: initialized pinctrl subsystem
[    0.044844] NET: Registered protocol family 16
[    0.046364] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.047258] cpuidle: using governor ladder
[    0.047288] cpuidle: using governor menu
[    0.048054] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.048060] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.064765] gpio-regulator gpio-regulator: could not find pctldev for node /soc/pinctrl@01f02c00/regulator_pins@0, deferring probe
[    0.065093] SCSI subsystem initialized
[    0.065286] libata version 3.00 loaded.
[    0.065485] usbcore: registered new interface driver usbfs
[    0.065532] usbcore: registered new interface driver hub
[    0.065594] usbcore: registered new device driver usb
[    0.065785] media: Linux media interface: v0.10
[    0.065825] Linux video capture interface: v2.00
[    0.065883] pps_core: LinuxPPS API ver. 1 registered
[    0.065888] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.065903] PTP clock support registered
[    0.066271] Advanced Linux Sound Architecture Driver Initialized.
[    0.067217] clocksource: Switched to clocksource arch_sys_counter
[    0.154410] VFS: Disk quotas dquot_6.6.0
[    0.154495] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.162284] NET: Registered protocol family 2
[    0.162947] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.162978] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.163011] TCP: Hash tables configured (established 2048 bind 2048)
[    0.163110] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.163148] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.163351] NET: Registered protocol family 1
[    0.163804] RPC: Registered named UNIX socket transport module.
[    0.163809] RPC: Registered udp transport module.
[    0.163812] RPC: Registered tcp transport module.
[    0.163815] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.164046] Trying to unpack rootfs image as initramfs...
[    0.215226] Freeing initrd memory: 960K
[    0.216738] audit: initializing netlink subsys (disabled)
[    0.217005] audit: type=2000 audit(0.200:1): state=initialized audit_enabled=0 res=1
[    0.217285] Initialise system trusted keyrings
[    0.217445] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[    0.222598] zbud: loaded
[    0.224934] NFS: Registering the id_resolver key type
[    0.224964] Key type id_resolver registered
[    0.224968] Key type id_legacy registered
[    0.224981] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.224985] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.226053] JFS: nTxBlock = 1933, nTxLock = 15464
[    0.229855] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    0.236754] Key type asymmetric registered
[    0.236840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.236984] io scheduler noop registered
[    0.236988] io scheduler deadline registered
[    0.237342] io scheduler cfq registered (default)
[    0.237347] io scheduler mq-deadline registered
[    0.237352] io scheduler kyber registered
[    0.237481] io scheduler bfq registered
[    0.238585] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.242513] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.244096] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.292245] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.295395] console [ttyS0] disabled
[    0.315547] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 46, base_baud = 1500000) is a U6_16550A
[    0.315609] console [ttyS0] enabled
[    0.319278] brd: module loaded
[    0.325083] loop: module loaded
[    0.328171] libphy: Fixed MDIO Bus: probed
[    0.328688] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.328727] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.328773] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.328968] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.328974] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.328980] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.328985] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.328992] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.328998] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.329106] libphy: stmmac: probed
[    0.330762] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.330768] ehci-platform: EHCI generic platform driver
[    0.331000] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.331028] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.331408] ehci-platform 1c1a000.usb: irq 29, io mem 0x01c1a000
[    0.357226] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.357512] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.357521] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.357528] usb usb1: Product: EHCI Host Controller
[    0.357534] usb usb1: Manufacturer: Linux 4.14.0-h2-2 ehci_hcd
[    0.357540] usb usb1: SerialNumber: 1c1a000.usb
[    0.358109] hub 1-0:1.0: USB hub found
[    0.358156] hub 1-0:1.0: 1 port detected
[    0.358915] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.358940] ohci-platform: OHCI generic platform driver
[    0.359156] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.359179] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.359372] ohci-platform 1c1a400.usb: irq 30, io mem 0x01c1a400
[    0.431461] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    0.431470] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.431476] usb usb2: Product: Generic Platform OHCI controller
[    0.431482] usb usb2: Manufacturer: Linux 4.14.0-h2-2 ohci_hcd
[    0.431488] usb usb2: SerialNumber: 1c1a400.usb
[    0.431960] hub 2-0:1.0: USB hub found
[    0.432005] hub 2-0:1.0: 1 port detected
[    0.432805] usbcore: registered new interface driver usb-storage
[    0.433339] mousedev: PS/2 mouse device common for all mice
[    0.434033] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.434039] sun6i-rtc 1f00000.rtc: RTC enabled
[    0.434241] i2c /dev entries driver
[    0.436399] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.437793] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    0.497234] sunxi-mmc 1c0f000.mmc: base:0xd096f000 irq:26
[    0.499011] ledtrig-cpu: registered to indicate activity on CPUs
[    0.499086] hidraw: raw HID events driver (C) Jiri Kosina
[    0.499224] usbcore: registered new interface driver usbhid
[    0.499227] usbhid: USB HID core driver
[    0.499784] NET: Registered protocol family 17
[    0.499888] Key type dns_resolver registered
[    0.500145] Registering SWP/SWPB emulation handler
[    0.500686] registered taskstats version 1
[    0.500691] Loading compiled-in X.509 certificates
[    0.500810] zswap: loaded using pool lzo/zbud
[    0.503620] Key type encrypted registered
[    0.512058] ehci-platform 1c1b000.usb: EHCI Host Controller
[    0.512091] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    0.512295] ehci-platform 1c1b000.usb: irq 31, io mem 0x01c1b000
[    0.545989] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.547229] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    0.547449] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.547457] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.547463] usb usb3: Product: EHCI Host Controller
[    0.547470] usb usb3: Manufacturer: Linux 4.14.0-h2-2 ehci_hcd
[    0.547475] usb usb3: SerialNumber: 1c1b000.usb
[    0.548041] hub 3-0:1.0: USB hub found
[    0.548083] hub 3-0:1.0: 1 port detected
[    0.548811] ehci-platform 1c1c000.usb: EHCI Host Controller
[    0.548836] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    0.549018] ehci-platform 1c1c000.usb: irq 33, io mem 0x01c1c000
[    0.549773] mmc0: new high speed SDHC card at address aaaa
[    0.550373] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    0.551565]  mmcblk0: p1 p2
[    0.577237] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    0.577443] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    0.577451] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.577457] usb usb4: Product: EHCI Host Controller
[    0.577463] usb usb4: Manufacturer: Linux 4.14.0-h2-2 ehci_hcd
[    0.577469] usb usb4: SerialNumber: 1c1c000.usb
[    0.577981] hub 4-0:1.0: USB hub found
[    0.578020] hub 4-0:1.0: 1 port detected
[    0.578803] ehci-platform 1c1d000.usb: EHCI Host Controller
[    0.578829] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    0.579010] ehci-platform 1c1d000.usb: irq 35, io mem 0x01c1d000
[    0.607234] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    0.607417] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    0.607425] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.607431] usb usb5: Product: EHCI Host Controller
[    0.607437] usb usb5: Manufacturer: Linux 4.14.0-h2-2 ehci_hcd
[    0.607443] usb usb5: SerialNumber: 1c1d000.usb
[    0.607902] hub 5-0:1.0: USB hub found
[    0.607939] hub 5-0:1.0: 1 port detected
[    0.608597] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    0.608621] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    0.608764] ohci-platform 1c1b400.usb: irq 32, io mem 0x01c1b400
[    0.681392] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    0.681401] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.681407] usb usb6: Product: Generic Platform OHCI controller
[    0.681413] usb usb6: Manufacturer: Linux 4.14.0-h2-2 ohci_hcd
[    0.681419] usb usb6: SerialNumber: 1c1b400.usb
[    0.681863] hub 6-0:1.0: USB hub found
[    0.681903] hub 6-0:1.0: 1 port detected
[    0.682541] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    0.682563] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    0.682692] ohci-platform 1c1c400.usb: irq 34, io mem 0x01c1c400
[    0.751391] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    0.751400] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.751406] usb usb7: Product: Generic Platform OHCI controller
[    0.751412] usb usb7: Manufacturer: Linux 4.14.0-h2-2 ohci_hcd
[    0.751418] usb usb7: SerialNumber: 1c1c400.usb
[    0.751874] hub 7-0:1.0: USB hub found
[    0.751910] hub 7-0:1.0: 1 port detected
[    0.752522] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    0.752545] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    0.752698] ohci-platform 1c1d400.usb: irq 36, io mem 0x01c1d400
[    0.821379] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    0.821387] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.821393] usb usb8: Product: Generic Platform OHCI controller
[    0.821399] usb usb8: Manufacturer: Linux 4.14.0-h2-2 ohci_hcd
[    0.821405] usb usb8: SerialNumber: 1c1d400.usb
[    0.821855] hub 8-0:1.0: USB hub found
[    0.821889] hub 8-0:1.0: 1 port detected
[    0.822591] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    0.822922] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.822934] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
[    0.823151] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[    0.823159] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.823165] usb usb9: Product: MUSB HDRC host driver
[    0.823171] usb usb9: Manufacturer: Linux 4.14.0-h2-2 musb-hcd
[    0.823177] usb usb9: SerialNumber: musb-hdrc.1.auto
[    0.823657] hub 9-0:1.0: USB hub found
[    0.823704] hub 9-0:1.0: 1 port detected
[    0.827390] vcc3v0: disabling
[    0.827399] vcc5v0: disabling
[    0.827404] usb0-vbus: disabling
[    0.827408] vcc-wifi: disabling
[    0.827413] ALSA device list:
[    0.827416]   No soundcards found.
[    0.830546] Freeing unused kernel memory: 1024K
[    0.947405] usb 4-1: new high-speed USB device number 2 using ehci-platform
[    0.974310] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    0.974948] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    0.987271] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    0.991582] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.160873] usb 4-1: New USB device found, idVendor=152d, idProduct=0578
[    1.160905] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.160925] usb 4-1: Product: External Disk 3.0
[    1.160945] usb 4-1: Manufacturer: JMicron
[    1.160963] usb 4-1: SerialNumber: 000000004896
[    1.166683] alloc_contig_range: [4f051, 4f052) PFNs busy
[    1.198984] usb 5-1: New USB device found, idVendor=1a40, idProduct=0101
[    1.199059] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.199110] usb 5-1: Product: USB 2.0 Hub
[    1.202320] hub 5-1:1.0: USB hub found
[    1.204279] hub 5-1:1.0: 4 ports detected
[    1.469577] systemd[1]: System time before build time, advancing clock.
[    1.649142] NET: Registered protocol family 10
[    1.700648] Segment Routing with IPv6
[    1.751243] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    1.751937] systemd[1]: Detected architecture arm.
[    1.790602] systemd[1]: Set hostname to <nanopi-duo>.
[    2.172063] systemd[1]: Listening on Journal Socket.
[    2.200688] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.230624] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.260169] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.290052] systemd[1]: Listening on udev Control Socket.
[    2.320475] systemd[1]: Reached target Swap.
[    2.350617] systemd[1]: Listening on Journal Audit Socket.
[    2.906328] g_serial gadget: Gadget Serial v2.4
[    2.906342] g_serial gadget: g_serial ready
[    2.922125] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.814594] systemd-journald[171]: Received request to flush runtime journal from PID 1
[    4.127912] alloc_contig_range: [4f051, 4f052) PFNs busy
[    4.138425] alloc_contig_range: [4f051, 4f052) PFNs busy
[    4.138449] alloc_contig_range: [4f052, 4f053) PFNs busy
[    4.228166] scsi host0: uas
[    4.258854] ads7846 spi0.1: spi0.1 supply vcc not found, using dummy regulator
[    4.259669] ads7846 spi0.1: touchscreen, irq 93
[    4.260294] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input0
[    4.281611] sy8106a 0-0065: Failed to read voltage at probe time: -6
[    4.296938] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[    4.312138] fb_st7789v: module is from the staging directory, the quality is unknown, you have been warned.
[    4.314296] fbtft_of_value: buswidth = 8
[    4.314315] fbtft_of_value: debug = 0
[    4.314321] fbtft_of_value: rotate = 90
[    4.314327] fbtft_of_value: fps = 33
[    4.319326] lirc_dev: IR Remote Control driver registered, major 242
[    4.369645] IR LIRC bridge handler initialized
[    4.370548] Registered IR keymap rc-empty
[    4.370705] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
[    4.370887] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input1
[    4.374965] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[    4.375145] sunxi-ir 1f02000.ir: initialized sunXi IR driver
[    4.376098] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.376106] [drm] No driver support for vblank timestamp query.
[    4.387000] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer])
[    4.387472] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    4.387500] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_tcon])
[    4.435339] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    4.483224] Console: switching to colour frame buffer device 40x30
[    4.484292] graphics fb0: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi0.0 at 50 MHz
[    4.517589] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    4.519247] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.519750] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi])
[    4.519826] [drm] Cannot find any crtc or sizes
[    4.520325] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    4.520915] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    4.528940] sun4i-codec 1c22c00.codec: Failed to register our card
[    4.713425] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    4.728469] random: crng init done
[    4.797757] sunxi-mmc 1c10000.mmc: base:0xd0ed8000 irq:27
[    4.802188] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    4.823136] mmc1: new high speed SDIO card at address 0001
[    4.824320] xradio_wlan mmc1:0001:1: no mac address provided, using random
[    5.017309] Registered IR keymap rc-cec
[    5.017618] rc rc1: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1
[    5.017851] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1/input2
[    5.039182] xradio_wlan mmc1:0001:1:    Input buffers: 30 x 1632 bytes
                  Hardware: 7.9
                  WSM firmware ver: 8, build: 5207, api: 1060, cap: 0x0003
[    5.039194] xradio_wlan mmc1:0001:1: Firmware Label:XR_C01.08.52.07 Nov 10 2016 13:22:16
[    5.044802] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    5.597458] [drm] Cannot find any crtc or sizes
[    5.709194] ieee80211 phy0: Interface ID:0 of type:2 added
[    5.709609] ieee80211 phy0: vif 0, configuring tx
[    5.709874] ieee80211 phy0: vif 0, configuring tx
[    5.710152] ieee80211 phy0: vif 0, configuring tx
[    5.710474] ieee80211 phy0: vif 0, configuring tx
[    5.710787] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
[    5.710952] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    5.711975] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.715728] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    5.715746] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    5.716168] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.878608] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    8.878771] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.229438] scsi 0:0:0:0: scsi scan: 96 byte inquiry failed.  Consider BLIST_INQUIRY_36 for this device
[   14.231500] usbcore: registered new interface driver uas
lsmod
Module                  Size  Used by
rc_cec                 16384  0
snd_soc_hdmi_codec     16384  0
dw_hdmi_cec            16384  0
dw_hdmi_i2s_audio      16384  0
sun8i_codec_analog     24576  1
pwrseq_simple          16384  1
sun4i_i2s              16384  0
sun4i_codec            32768  3
sun8i_dw_hdmi          16384  0
ir_lirc_codec          16384  0
dw_hdmi                24576  2 dw_hdmi_i2s_audio,sun8i_dw_hdmi
lirc_dev               16384  1 ir_lirc_codec
cec                    32768  2 dw_hdmi_cec,dw_hdmi
fb_st7789v             16384  1
snd_soc_core          114688  4 sun4i_codec,sun4i_i2s,sun8i_codec_analog,snd_soc_hdmi_codec
fbtft                  28672  1 fb_st7789v
sunxi_cir              16384  0
spidev                 16384  0
sy8106a_regulator      16384  0
ads7846                20480  0
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                65536  4 sun4i_i2s,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_core
uas                    20480  0
snd_timer              24576  1 snd_pcm
sun4i_tcon             20480  1 sun8i_dw_hdmi
sun8i_mixer            16384  0
sun4i_drm              16384  0
uio_pdrv_genirq        16384  0
uio                    16384  1 uio_pdrv_genirq
usb_f_acm              16384  1
u_serial               20480  1 usb_f_acm
g_serial               16384  0
libcomposite           40960  2 g_serial,usb_f_acm
xradio_wlan            90112  1
mac80211              438272  1 xradio_wlan
cfg80211              376832  2 mac80211,xradio_wlan
rfkill                 20480  2 cfg80211
ipv6                  319488  16
              total        used        free      shared  buff/cache   available
Mem:            242          14         178           4          49         204
Swap:             0           0           0
Fixed. NanoPi DUO with kernel 4.14.0, fast, solid as rock.
That's it. Job accomplished.
[    0.000000] Linux version 4.14.0-h2-4 (alex@svn) (gcc version 7.1.1 20170707 (Linaro GCC 7.1-2017.08)) #1 SMP Sat Nov 25 18:07:25 -02 2017
[    0.000000] free_area_init_node: node 0, pgdat c0bcf680, node_mem_map cedb1000
[    0.000000] Memory: 230076K/262144K available (6144K kernel code, 904K rwdata, 2100K rodata, 1024K init, 319K bss, 15684K reserved, 16384K cma-reserved, 0K highmem)
                     .data : 0xc0b00000 - 0xc0be2044   ( 905 kB)
                      .bss : 0xc0bea54c - 0xc0c3a504   ( 320 kB)
[    0.000000] ftrace: allocating 34558 entries in 68 pages
[    0.000014] Switching to timer-based delay loop, resolution 41ns
[    0.000235] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000246] pid_max: default: 32768 minimum: 301
[    0.000444] AppArmor: AppArmor disabled by boot time parameter
[    0.000502] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000511] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001367] CPU: Testing write buffer coherency: ok
[    0.001807] CPU0: update cpu_capacity 1024
[    0.001814] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002171] Setting up static identity map for 0x40100000 - 0x40100054
[    0.002276] Hierarchical SRCU implementation.
[    0.002999] smp: Bringing up secondary CPUs ...
[    0.013699] CPU1: update cpu_capacity 1024
[    0.013705] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.024479] CPU2: update cpu_capacity 1024
[    0.024485] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.035210] CPU3: update cpu_capacity 1024
[    0.035215] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.035298] smp: Brought up 1 node, 4 CPUs
[    0.035307] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.035311] CPU: All CPU(s) started in HYP mode.
[    0.035314] CPU: Virtualization extensions available.
[    0.036223] devtmpfs: initialized
[    0.042332] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.042567] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.042583] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.043851] pinctrl core: initialized pinctrl subsystem
[    0.044722] NET: Registered protocol family 16
[    0.046263] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.047148] cpuidle: using governor ladder
[    0.047181] cpuidle: using governor menu
[    0.047938] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.047943] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.064637] gpio-regulator gpio-regulator: could not find pctldev for node /soc/pinctrl@01f02c00/regulator_pins@0, deferring probe
[    0.064960] SCSI subsystem initialized
[    0.065177] libata version 3.00 loaded.
[    0.065414] usbcore: registered new interface driver usbfs
[    0.065456] usbcore: registered new interface driver hub
[    0.065517] usbcore: registered new device driver usb
[    0.065709] media: Linux media interface: v0.10
[    0.065739] Linux video capture interface: v2.00
[    0.065796] pps_core: LinuxPPS API ver. 1 registered
[    0.065800] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.065815] PTP clock support registered
[    0.066176] Advanced Linux Sound Architecture Driver Initialized.
[    0.067105] clocksource: Switched to clocksource arch_sys_counter
[    0.154903] VFS: Disk quotas dquot_6.6.0
[    0.154987] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.162612] NET: Registered protocol family 2
[    0.163257] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.163285] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.163318] TCP: Hash tables configured (established 2048 bind 2048)
[    0.163413] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.163452] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.163662] NET: Registered protocol family 1
[    0.164106] RPC: Registered named UNIX socket transport module.
[    0.164110] RPC: Registered udp transport module.
[    0.164113] RPC: Registered tcp transport module.
[    0.164117] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.164352] Trying to unpack rootfs image as initramfs...
[    0.215551] Freeing initrd memory: 960K
[    0.217068] audit: initializing netlink subsys (disabled)
[    0.217444] audit: type=2000 audit(0.210:1): state=initialized audit_enabled=0 res=1
[    0.217667] Initialise system trusted keyrings
[    0.217832] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[    0.222803] zbud: loaded
[    0.225094] NFS: Registering the id_resolver key type
[    0.225117] Key type id_resolver registered
[    0.225121] Key type id_legacy registered
[    0.225133] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.225138] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.226184] JFS: nTxBlock = 1932, nTxLock = 15463
[    0.229969] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    0.236980] Key type asymmetric registered
[    0.237071] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.237270] io scheduler noop registered
[    0.237276] io scheduler deadline registered
[    0.237557] io scheduler cfq registered (default)
[    0.237563] io scheduler mq-deadline registered
[    0.237567] io scheduler kyber registered
[    0.237691] io scheduler bfq registered
[    0.238796] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.242729] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.244253] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.293222] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.296299] console [ttyS0] disabled
[    0.316451] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 46, base_baud = 1500000) is a U6_16550A
[    0.316513] console [ttyS0] enabled
[    0.320219] brd: module loaded
[    0.325984] loop: module loaded
[    0.329030] libphy: Fixed MDIO Bus: probed
[    0.329517] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.329558] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.329603] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.329803] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.329810] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.329816] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.329821] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.329828] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.329833] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.329934] libphy: stmmac: probed
[    0.331623] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.331629] ehci-platform: EHCI generic platform driver
[    0.331830] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.331866] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.332242] ehci-platform 1c1a000.usb: irq 29, io mem 0x01c1a000
[    0.357109] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.357399] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.357408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.357414] usb usb1: Product: EHCI Host Controller
[    0.357420] usb usb1: Manufacturer: Linux 4.14.0-h2-4 ehci_hcd
[    0.357426] usb usb1: SerialNumber: 1c1a000.usb
[    0.358010] hub 1-0:1.0: USB hub found
[    0.358053] hub 1-0:1.0: 1 port detected
[    0.358790] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.358844] ohci-platform: OHCI generic platform driver
[    0.359053] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.359076] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.359285] ohci-platform 1c1a400.usb: irq 30, io mem 0x01c1a400
[    0.431369] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    0.431378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.431385] usb usb2: Product: Generic Platform OHCI controller
[    0.431391] usb usb2: Manufacturer: Linux 4.14.0-h2-4 ohci_hcd
[    0.431397] usb usb2: SerialNumber: 1c1a400.usb
[    0.431901] hub 2-0:1.0: USB hub found
[    0.431946] hub 2-0:1.0: 1 port detected
[    0.432786] usbcore: registered new interface driver usb-storage
[    0.433291] mousedev: PS/2 mouse device common for all mice
[    0.433970] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    0.433977] sun6i-rtc 1f00000.rtc: RTC enabled
[    0.434178] i2c /dev entries driver
[    0.436336] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.437773] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    0.497128] sunxi-mmc 1c0f000.mmc: base:0xd096f000 irq:26
[    0.498904] ledtrig-cpu: registered to indicate activity on CPUs
[    0.498985] hidraw: raw HID events driver (C) Jiri Kosina
[    0.499105] usbcore: registered new interface driver usbhid
[    0.499108] usbhid: USB HID core driver
[    0.500300] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01f015c0 not registered
[    0.500310] sun4i-codec 1c22c00.codec: Failed to register our card
[    0.501808] NET: Registered protocol family 17
[    0.501903] Key type dns_resolver registered
[    0.502169] Registering SWP/SWPB emulation handler
[    0.502700] registered taskstats version 1
[    0.502705] Loading compiled-in X.509 certificates
[    0.502834] zswap: loaded using pool lzo/zbud
[    0.503747] Key type encrypted registered
[    0.512262] ehci-platform 1c1b000.usb: EHCI Host Controller
[    0.512295] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    0.512531] ehci-platform 1c1b000.usb: irq 31, io mem 0x01c1b000
[    0.537112] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    0.537330] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.537338] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.537345] usb usb3: Product: EHCI Host Controller
[    0.537351] usb usb3: Manufacturer: Linux 4.14.0-h2-4 ehci_hcd
[    0.537357] usb usb3: SerialNumber: 1c1b000.usb
[    0.537930] hub 3-0:1.0: USB hub found
[    0.537984] hub 3-0:1.0: 1 port detected
[    0.538727] ehci-platform 1c1c000.usb: EHCI Host Controller
[    0.538751] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    0.538915] ehci-platform 1c1c000.usb: irq 33, io mem 0x01c1c000
[    0.555840] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.559398] mmc0: new high speed SDHC card at address aaaa
[    0.560004] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    0.561282]  mmcblk0: p1 p2
[    0.567136] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    0.567372] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    0.567380] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.567386] usb usb4: Product: EHCI Host Controller
[    0.567392] usb usb4: Manufacturer: Linux 4.14.0-h2-4 ehci_hcd
[    0.567397] usb usb4: SerialNumber: 1c1c000.usb
[    0.567880] hub 4-0:1.0: USB hub found
[    0.567918] hub 4-0:1.0: 1 port detected
[    0.568661] ehci-platform 1c1d000.usb: EHCI Host Controller
[    0.568687] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    0.568866] ehci-platform 1c1d000.usb: irq 35, io mem 0x01c1d000
[    0.597107] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    0.597320] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    0.597329] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.597335] usb usb5: Product: EHCI Host Controller
[    0.597341] usb usb5: Manufacturer: Linux 4.14.0-h2-4 ehci_hcd
[    0.597347] usb usb5: SerialNumber: 1c1d000.usb
[    0.597791] hub 5-0:1.0: USB hub found
[    0.597825] hub 5-0:1.0: 1 port detected
[    0.598454] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    0.598486] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    0.598618] ohci-platform 1c1b400.usb: irq 32, io mem 0x01c1b400
[    0.671286] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    0.671295] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.671301] usb usb6: Product: Generic Platform OHCI controller
[    0.671307] usb usb6: Manufacturer: Linux 4.14.0-h2-4 ohci_hcd
[    0.671312] usb usb6: SerialNumber: 1c1b400.usb
[    0.671753] hub 6-0:1.0: USB hub found
[    0.671789] hub 6-0:1.0: 1 port detected
[    0.672435] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    0.672456] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    0.672597] ohci-platform 1c1c400.usb: irq 34, io mem 0x01c1c400
[    0.741276] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    0.741284] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.741290] usb usb7: Product: Generic Platform OHCI controller
[    0.741296] usb usb7: Manufacturer: Linux 4.14.0-h2-4 ohci_hcd
[    0.741302] usb usb7: SerialNumber: 1c1c400.usb
[    0.741748] hub 7-0:1.0: USB hub found
[    0.741784] hub 7-0:1.0: 1 port detected
[    0.742412] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    0.742433] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    0.742577] ohci-platform 1c1d400.usb: irq 36, io mem 0x01c1d400
[    0.811271] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    0.811279] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.811285] usb usb8: Product: Generic Platform OHCI controller
[    0.811292] usb usb8: Manufacturer: Linux 4.14.0-h2-4 ohci_hcd
[    0.811297] usb usb8: SerialNumber: 1c1d400.usb
[    0.811728] hub 8-0:1.0: USB hub found
[    0.811765] hub 8-0:1.0: 1 port detected
[    0.812420] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    0.812787] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.812797] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
[    0.813031] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[    0.813039] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.813045] usb usb9: Product: MUSB HDRC host driver
[    0.813050] usb usb9: Manufacturer: Linux 4.14.0-h2-4 musb-hcd
[    0.813056] usb usb9: SerialNumber: musb-hdrc.1.auto
[    0.813466] hub 9-0:1.0: USB hub found
[    0.813502] hub 9-0:1.0: 1 port detected
[    0.818881] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    0.820961] alloc_contig_range: [4f051, 4f052) PFNs busy
[    0.821839] vcc3v0: disabling
[    0.821848] vcc5v0: disabling
[    0.821853] usb0-vbus: disabling
[    0.821857] vcc-wifi: disabling
[    0.821861] ALSA device list:
[    0.821865]   #0: H3 Audio Codec
[    0.825828] Freeing unused kernel memory: 1024K
[    0.937257] usb 4-1: new high-speed USB device number 2 using ehci-platform
[    0.953829] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    0.954395] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    0.967214] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    1.014332] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.140486] usb 4-1: New USB device found, idVendor=152d, idProduct=0578
[    1.140508] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.140521] usb 4-1: Product: External Disk 3.0
[    1.140533] usb 4-1: Manufacturer: JMicron
[    1.140545] usb 4-1: SerialNumber: 000000004896
[    1.167957] usb 5-1: New USB device found, idVendor=1a40, idProduct=0101
[    1.167986] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.168005] usb 5-1: Product: USB 2.0 Hub
[    1.169276] hub 5-1:1.0: USB hub found
[    1.169441] hub 5-1:1.0: 4 ports detected
[    1.173608] alloc_contig_range: [4f051, 4f052) PFNs busy
[    1.476821] systemd[1]: System time before build time, advancing clock.
[    1.623959] NET: Registered protocol family 10
[    1.666872] Segment Routing with IPv6
[    1.719187] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    1.720046] systemd[1]: Detected architecture arm.
[    1.760371] systemd[1]: Set hostname to <nanopi-duo>.
[    2.150297] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.180469] systemd[1]: Listening on Journal Socket.
[    2.210768] systemd[1]: Listening on Journal Audit Socket.
[    2.240272] systemd[1]: Reached target Encrypted Volumes.
[    2.269974] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    2.300458] systemd[1]: Listening on udev Kernel Socket.
[    2.327798] systemd[1]: Reached target Swap.
[    2.912315] g_serial gadget: Gadget Serial v2.4
[    2.912330] g_serial gadget: g_serial ready
[    2.940504] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    3.712597] systemd-journald[175]: Received request to flush runtime journal from PID 1
[    4.027288] alloc_contig_range: [4f051, 4f052) PFNs busy
[    4.198757] sy8106a 0-0065: Failed to read voltage at probe time: -6
[    4.211207] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[    4.222753] fb_st7789v: module is from the staging directory, the quality is unknown, you have been warned.
[    4.223858] fbtft_of_value: buswidth = 8
[    4.223869] fbtft_of_value: debug = 0
[    4.223874] fbtft_of_value: rotate = 90
[    4.223879] fbtft_of_value: fps = 33
[    4.254275] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.254287] [drm] No driver support for vblank timestamp query.
[    4.265271] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_platform_driver_exit [sun8i_mixer])
[    4.265681] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    4.265708] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_platform_driver_exit [sun4i_tcon])
[    4.307420] scsi host0: uas
[    4.346142] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    4.397585] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    4.403174] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.403785] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops [sun8i_dw_hdmi])
[    4.404214] Console: switching to colour frame buffer device 40x30
[    4.405143] graphics fb0: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=33, spi0.0 at 50 MHz
[    4.405599] ads7846 spi0.1: spi0.1 supply vcc not found, using dummy regulator
[    4.406069] [drm] Cannot find any crtc or sizes
[    4.406274] ads7846 spi0.1: touchscreen, irq 93
[    4.406569] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    4.406868] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input0
[    4.422257] lirc_dev: IR Remote Control driver registered, major 242
[    4.424576] IR LIRC bridge handler initialized
[    4.425663] Registered IR keymap rc-empty
[    4.425842] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
[    4.426070] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input1
[    4.426802] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[    4.427002] sunxi-ir 1f02000.ir: initialized sunXi IR driver
[    4.707232] sunxi-mmc 1c10000.mmc: base:0xd0e16000 irq:27
[    4.726048] mmc1: new high speed SDIO card at address 0001
[    4.728093] xradio_wlan mmc1:0001:1: no mac address provided, using random
[    5.022865] random: crng init done
[    5.177167] Registered IR keymap rc-cec
[    5.178502] rc rc1: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1
[    5.186034] input: RC for dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc1/input2
[    5.285285] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    5.342498] xradio_wlan mmc1:0001:1:    Input buffers: 30 x 1632 bytes
                  Hardware: 7.9
[    5.342512] xradio_wlan mmc1:0001:1: Firmware Label:XR_C01.08.52.07 Nov 10 2016 13:22:16
[    5.350703] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    5.437333] [drm] Cannot find any crtc or sizes
[    5.616894] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.620281] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    5.620298] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    5.620583] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.721370] ieee80211 phy0: Interface ID:0 of type:2 added
[    5.721778] ieee80211 phy0: vif 0, configuring tx
[    5.722042] ieee80211 phy0: vif 0, configuring tx
[    5.722325] ieee80211 phy0: vif 0, configuring tx
[    5.722603] ieee80211 phy0: vif 0, configuring tx
[    5.722889] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
[    5.723033] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    8.720811] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    8.720972] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.309916] scsi 0:0:0:0: scsi scan: 96 byte inquiry failed.  Consider BLIST_INQUIRY_36 for this device
[   14.311388] usbcore: registered new interface driver uas
ethernet:
eth0      Link encap:Ethernet  HWaddr 02:42:f5:56:f0:a5
          inet addr:192.168.254.100  Bcast:192.168.255.255  Mask:255.255.0.0
          inet6 addr: fe80::42:f5ff:fe56:f0a5/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:14 errors:0 dropped:0 overruns:0 frame:0
          TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:2138 (2.1 KB)  TX bytes:2820 (2.8 KB)
          Interrupt:41
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr ae:66:fe:f6:f1:e0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
I have not applied any patch regarding ethernet except xr819 (which is still bad), so i got ethernet running by accident, possibly. What i know is working but have not done any becnhmark.
DT has FBTFT setup to spidev0, but i think it would work only on spi1,  right or wrong?
Thanks, clear now.
afaik the ethernet driver was ok on 4.14, but the mainline DT on 4.14 didn't have it enabled, so maybe you are using another DT that have it enabled (like current linus-master).
Yeah, answering my own question FBTFT is on SPI1 on DUO and SPI0 on NEO H5. So, if 4.14 runs on H2 it runs on H5 too!
