Zammy Posted November 15, 2017 Posted November 15, 2017 Hi, I have Orange Pi Zero based on H2+ which is failed to boot Armbian_5.34_Orangepizero_Ubuntu_xenial_next_4.13.8.img Symptoms: Green power light is always on, red led next to it does not flash at all. Ethernet lights are off. I am using proper power supply and Sandisk A1 16Gb Class 10 micro sd-card. Connecting UART-USB adapter based on CP2102x to UART port next to Ethernet ports shows nothing. Exactly same setup, same hardware, no changes on connections/setup boots "Armbian_5.30_Orangepizero_Ubuntu_xenial_default_3.4.113.img" image without any problems. UART works fine. Any ideas how I can help to test newer image?
Igor Posted November 16, 2017 Posted November 16, 2017 Latest nightly is working fine: http://sprunge.us/bcUN
