ASim M Posted 3 hours ago Posted 3 hours ago I have an Radxa 5B+ that are powered through POE HAT. The problem is that POE HAT fan does not work at all. I have to identical machines, same issue on both of them. I have installed Armbian minimal Bookworm on both, on nvme ssd. 0 Quote
Werner Posted 2 hours ago Posted 2 hours ago According to the schematic it seems like pwm is used for that. That would need to be enabled as device tree overlay. https://dl.radxa.com/accessories/25w-poe/radxa_25w_poe_plus_hat_v1.2_schematic.pdf Not sure if there is further/DIY programming necessary to make it work. 0 Quote
