1111Windows Posted March 20 Posted March 20 @sven-ola Have you tried booting from a microSD card? I downloaded Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.18.18_gnome_desktop.img and flashed it to my microSD card, but it won't boot. log: sys: 0x200 try sd... bm:3 j... U-Boot SPL 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.381] DDR type LPDDR4X [ 0.383] set ddr tx odt to 80ohm! [ 0.393] lpddr silicon init consume 11ms [ 0.394] Change DDR data rate to 2400MT/s [ 0.633] Boot from fit configuration x1_orangepi-rv2 [ 0.635] ## Checking hash(es) for config conf_18 ... OK [ 0.641] ## Checking hash(es) for Image uboot ... crc32+ OK [ 0.652] ## Checking hash(es) for Image fdt_18 ... crc32+ OK [ 0.674] ## Checking hash(es) for config config_1 ... OK [ 0.677] ## Checking hash(es) for Image opensbi ... crc32+ OK [ 0.725] U-Boot 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.732] CPU: rv64imafdcv [ 0.734] Model: ky x1 orangepi-rv2 board [ 0.738] DRAM: 2 GiB [ 0.830] Core: 414 devices, 29 uclasses, devicetree: board [ 0.843] WDT: Started PMIC_WDT with servicing (60s timeout) [ 0.848] WDT: Started watchdog@D4080000 with servicing (60s timeout) [ 0.857] MMC: [ 0.956] *** Warning - bad CRC, using default environment [ 0.961] initialize_console_log_buffer [ 0.962] Have allocated memory for console log buffer [ 0.967] In: serial [ 0.969] Out: serial [ 0.971] Err: serial [ 1.116] k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26500000Hz [ 1.124] k1x_qspi spi@d420c000: rx buf size:128, tx buf size:256, ahb buf size=512 [ 1.131] k1x_qspi spi@d420c000: AHB read enabled [ 1.136] k1x_qspi spi@d420c000: bus clock: 26500000Hz, PMUap reg[0xd4282860]:0x0000075b [ 1.143] k1x_qspi spi@d420c000: AHB buf size: 512 [ 1.148] SF: Detected XM25QU128C with page size 256 Bytes, erase size 64 KiB, total 16 MiB List of MTD devices: [ 1.159] * nor0 [ 1.160] - device: flash@0 [ 1.163] - parent: spi@d420c000 [ 1.166] - driver: jedec_spi_nor [ 1.170] - path: /soc/spi@d420c000/flash@0 [ 1.173] - type: NOR flash [ 1.176] - block size: 0x10000 bytes [ 1.180] - min I/O: 0x1 bytes [ 1.183] - 0x000000000000-0x000001000000 : "nor0" [ 1.188] - 0x000000000000-0x000000010000 : "bootinfo" [ 1.193] - 0x000000010000-0x000000020000 : "private" [ 1.198] - 0x000000020000-0x000000060000 : "fsbl" [ 1.203] - 0x000000060000-0x000000070000 : "env" [ 1.208] - 0x000000070000-0x0000000a0000 : "opensbi" [ 1.213] - 0x0000000a0000-0x000001000000 : "uboot" [ 1.219] Failed to get fastboot key config: -19 [ 1.222] Failed to probe HUSB239: -19 [ 1.227] RGMII interface [ 1.228] eth0: ethernet@cac80000 [ 1.231] MAC mapping file path not set in environment [ 1.236] K1X: :_load_env_from_blk [ 1.247] Can't set block device [ 1.248] Net: eth0: ethernet@cac80000 [ 1.254] Hit any key to stop autoboot: 0 Loading K1-X Environment ... [ 2.260] [ 2.261] Running NVMe Scan ... [ 2.272] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 2.277] Now init Rterm... [ 2.279] pcie prot id = 1, porta_init_done = 0 [ 2.283] Now waiting portA resister tuning done... [ 2.288] porta redonly_reg2: 00005d37 [ 2.292] pcie_rcal = 0x00005d37 [ 2.295] pcie port id = 1, lane num = 2 [ 2.298] Now int init_puphy... [ 2.301] waiting pll lock... [ 2.304] Now finish init_puphy.... [ 2.307] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 2.312] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 2.317] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 3.426] PCIE-0: Link down [ 3.438] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 3.441] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 3.448] Now init Rterm... [ 3.450] pcie prot id = 2, porta_init_done = 0 [ 3.455] Now waiting portA resister tuning done... [ 3.459] porta redonly_reg2: 00005d37 [ 3.463] pcie_rcal = 0x00005d37 [ 3.466] pcie port id = 2, lane num = 2 [ 3.470] Now int init_puphy... [ 3.472] waiting pll lock... [ 3.475] Now finish init_puphy.... [ 3.479] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 3.484] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 4.590] PCIE-1: Link down [ 4.642] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 4.646] Now init Rterm... [ 4.648] pcie prot id = 1, porta_init_done = 0 [ 4.653] Now waiting portA resister tuning done... [ 4.657] porta redonly_reg2: 00005d37 [ 4.661] pcie_rcal = 0x00005d37 [ 4.664] pcie port id = 1, lane num = 2 [ 4.668] Now int init_puphy... [ 4.671] waiting pll lock... [ 4.673] Now finish init_puphy.... [ 4.677] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 4.682] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 4.687] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 5.795] PCIE-0: Link down [ 5.807] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 5.810] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 5.817] Now init Rterm... [ 5.819] pcie prot id = 2, porta_init_done = 0 [ 5.824] Now waiting portA resister tuning done... [ 5.828] porta redonly_reg2: 00005d37 [ 5.832] pcie_rcal = 0x00005d37 [ 5.835] pcie port id = 2, lane num = 2 [ 5.839] Now int init_puphy... [ 5.841] waiting pll lock... [ 5.844] Now finish init_puphy.... [ 5.848] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 5.853] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 6.959] PCIE-1: Link down [ 6.963] no nvme partition table available [ 6.964] Couldn't find partition nvme 0:1 [ 6.968] Couldn't find partition nvme 0:1 [ 6.972] Couldn't find partition nvme 0:1 [ 6.976] Couldn't find partition nvme 0:1 [ 6.980] Couldn't find partition nvme 0:1 => 0 Quote
sven-ola Posted March 20 Author Posted March 20 vor 3 Stunden schrieb 1111Windows: U-Boot SPL 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) Hello @1111Windows, you are booting an unknown u-boot from NVME that does not find any meaningful data stored on the NVME. You may need to re-insert the SD card or swap to a working SD card or so. I attach the (timestamp stripped for better diff) version from you (forum.txt) and the expected UART output on my RV2 (minicom.txt). The latter I have captured after re-downloading and SD-flashing the mentioned trixie-gnome img which has a root file system with UUID=8f6e5f9c-3108-4e4d-8fbd-10a8295d396e. HTH // Sven-Ola forum.txt minicom.txt 0 Quote
lewa_j Posted March 22 Posted March 22 Hello @sven-ola, big thank you for all you work on RV2 support! I was wondering, is it possible to enable CONFIG_DRM_POWERVR for 6.18 and up? I guess more than that is required to actually use it though. 0 Quote
maxsub Posted March 22 Posted March 22 The R2S has an internal eMMC and a USB port. After debugging the default u-boot scripts I found that it does not boot from USB once you have Armbian installed on eMMC. To reinstall a fresh copy of Armbian or any other OS, you have to use the fastboot based KyTool which does not usually work on a modern Windows PC with USB 3.0 ports. So you could end up in a state where you have to manually interrupt U-boot, or worse if you corrupt the eMMC. I rewrote the u-boot flow on the R2S. I also cleaned up the nand-sata-install and added a lot of safety checks. It will look at USB and boot from there. After that you can safely install to eMMC. Below is the link. Please let me know if it is worth submitting a PR. The changes will not touch anything in the main system, it adds these scripts to /usr/local/lib and /usr/local/sbin. https://github.com/arvindmaxar/u-boot-tools 0 Quote
1111Windows Posted March 22 Posted March 22 Hello@sven-ola After flashing the image correctly, I found that running `sudo apt upgrade` to update the system caused the kernel to fail to load; the issue appears to stem from the kernel update. Installing the `linux-image-current-spacemit 26.2.1` update causes the kernel to fail to load. I noticed that the kernel version in the image is 6.18.18-current-spacemit, while the kernel version in the Armbian repository is 6.6.99-current-spacemit. I think this is likely the root of the problem; I should not have used apt to update the kernel. In any case, thank you for porting Armbian to the OrangePi RV2. 0 Quote
sven-ola Posted March 22 Author Posted March 22 vor 11 Stunden schrieb lewa_j: is it possible to enable CONFIG_DRM_POWERVR for 6.18 and up Hello @lewa_j, there already is a CONFIG_POWERVR_ROGUE=y in the 6.18 kernel. This was required for Wayland and subsequently for Spacemit-GPU-Binary-Support (see https://github.com/armbian/build/pull/9515). What exactly will work additionally with this option (I am not a GPU expert)? Hello @1111Windows, doing "apt-get upgrade" on my GPU demo image this will downgrade the kernel from 6.18.18 to 6.6.99. Probably b/c recently the 6.6.99 was changed "current->legacy" and the 6.18 changed "edge->current". Also, OpiRV2 is not a really / full official Armbian image right now. So we probably need to wait until build pipelines catch up. I'll place a "apt-mark hold linux-image*" on my todo for those images. @maxsub The R2S does not have a NOR flash (or "MTD") that it boots from in the first place? That little project of yours does not look like an Armbian fork ready to be merged in. I may need some time to dig in and understand how it works. Have you considered changing the u-boot enviroment (...that can be save with "env save")? 0 Quote
maxsub Posted March 22 Posted March 22 @sven-ola there are 3 ways to boot the R2S: 1. Press the boot button before applying power. White USB port connected to a PC. Apply power. It goes into fastboot mode like an android. Theoretically this should let you flash the on-board eMMC. I can successfully put it in fastboot mode but the flashing has not worked. 2. Boot from eMMC 3. Boot from USB. The eMMC has two boot partitions that are fixed size and one large main partition. My project uses the u-boot environment but also does a few minor things. It prioritizes USB if it finds a bootable medium there. It also safely flashes the boot blocks on the eMMC and then the main blocks. It adds some safety checks before flashing. Nothing else. 0 Quote
Logan Posted March 23 Posted March 23 Hi guys? are there any cli/minimal Armbian (triexie) images with current kernel for Opi RV2? 0 Quote
sven-ola Posted March 24 Author Posted March 24 (edited) @Łukasz Żywczyk Currently no prebuild nightly images. You are on your own. Grab a Debian Trixie on 64 bit PC (8G RAM, 16G Disk), then sudo apt-get install docker.io qemu-user git # add yourself to group docker, logout && login git clone https://github.com/armbian/build.git cd build && ./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie \ BUILD_MINIMAL=yes KERNEL_CONFIGURE=no KERNEL_BTF=no KERNEL_GIT=shallow should build your image in output/images/*.img ready to be used... Edited March 24 by sven-ola qemu-system -> qemu-user 0 Quote
lewa_j Posted March 25 Posted March 25 (edited) @sven-ola CONFIG_POWERVR_ROGUE is for proprietary blob userspace drivers. CONFIG_DRM_POWERVR is new mainlined kerner driver (drivers/gpu/drm/imagination) for use with opensource mesa driver (main/src/imagination) Edited March 25 by lewa_j 0 Quote
sven-ola Posted March 25 Author Posted March 25 Hello @lewa_j! Thanks for the explanation. As long as https://docs.mesa3d.org/drivers/powervr.html lists BXE-2-32 as unsupported we stick to the blobs. Of course, you are free to check this for youself, see compiling "getting started" above. HTH // Sven-Ola 0 Quote
Solution sven-ola Posted March 26 Author Solution Posted March 26 Found an error in the "use proprietary GPU driver for Spacemit K1" script. Because I cannot edit here is the corrected install script. spacemit-gpu-addon.sh 0 Quote
Dmitrii Trifonov Posted Saturday at 04:06 PM Posted Saturday at 04:06 PM (edited) Hello! How to download nightly build with 6.18 kernel? I've got 404 error when trying to download via link. Edited Saturday at 04:07 PM by Dmitrii Trifonov Change dot to question mark 0 Quote
Werner Posted Sunday at 05:11 AM Posted Sunday at 05:11 AM If an pre-made image is not there, just DIY. https://docs.armbian.com/Developer-Guide_Build-Preparation/ 1 Quote
1111Windows Posted 21 hours ago Posted 21 hours ago Hi @sven-ola , I'm having an issue where my portrait-oriented monitor isn't displaying anything properly. I have a portrait-oriented monitor, and when I try to connect it via HDMI, it doesn't display anything—the screen remains blank. I found this in dmesg: [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] Initialized spacemit 1.0.0 for c0440000.display-subsystem-hdmi on minor 1 [drm] spacemit_hdmi_connector_detect() hdmi status connected [drm] spacemit_hdmi_get_edid_block() len 128 [drm] spacemit_hdmi_get_edid_block() len 128 spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I added `video=1080x1920@60` to the kernel parameters. Now it outputs: [ 4.162834] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] User-defined mode not supported: "1080x1920": 60 137020 1080 1152 1160 1176 1920 1934 1936 1942 0x68 0x5 [ 4.162871] spacemit-drm-drv c0440000.display-subsystem-hdmi: [drm] Cannot find any crtc or sizes I think this is because the driver only supports a resolution of 1920x1080, but not 1080x1920. dmesg.txt 0 Quote
savznkvo Posted 6 hours ago Posted 6 hours ago Hello everyone! Hi @sven-ola How could I finally set up my minimal image on lower M.2 SSD only and use SBC without SD-card? I tried official dev image from Armbian Imager and compiled one by myself but armbian-installer always asking me to wipefs just `/dev/` for some reason and also system (booted from SD-card) just can't work with /dev/nvme0n1 (always Invalid Operation). I tried many ways but no luck. I just need minimal system image run on my lower M.2 SSD 0 Quote
Logan Posted 1 hour ago Posted 1 hour ago same question here.... we need minimal image... none of solutions in this topic doesn't work 0 Quote
c0rnelius Posted 1 hour ago Posted 1 hour ago The armbian boot loader is diff than the vendors. It checks for specific things in a particular order. nvme_devtype=nvme nvme_devnum=0 nvme_bootpart=1 autoboot=if test -e ${devtype} ${devnum}:${distro_bootpart} /extlinux/extlinux.conf; then \ sysboot ${devtype} ${devnum}:${distro_bootpart} any 0x2000000 /extlinux/extlinux.conf; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot/extlinux/extlinux.conf; then \ sysboot ${devtype} ${devnum}:${distro_bootpart} any 0x2000000 /boot/extlinux/extlinux.conf; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot.scr; then \ load ${devtype} ${devnum}:${distro_bootpart} 0x2000000 /boot.scr; source 0x2000000; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot/boot.scr; then \ load ${devtype} ${devnum}:${distro_bootpart} 0x2000000 /boot/boot.scr; source 0x2000000; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} EFI/BOOT/BOOTRISCV64.EFI; then \ load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} EFI/BOOT/BOOTRISCV64.EFI; bootefi ${kernel_addr_r}; \ fi; nvme part; \ setenv devtype $nvme_devtype; \ setenv devnum $nvme_devnum; \ setenv distro_bootpart $nvme_bootpart; \ if test -e ${devtype} ${devnum}:${distro_bootpart} /extlinux/extlinux.conf; then \ sysboot ${devtype} ${devnum}:${distro_bootpart} any 0x2000000 /extlinux/extlinux.conf; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot/extlinux/extlinux.conf; then \ sysboot ${devtype} ${devnum}:${distro_bootpart} any 0x2000000 /boot/extlinux/extlinux.conf; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot.scr; then \ load ${devtype} ${devnum}:${distro_bootpart} 0x2000000 /boot.scr; source 0x2000000; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} /boot/boot.scr; then \ load ${devtype} ${devnum}:${distro_bootpart} 0x2000000 /boot/boot.scr; source 0x2000000; \ elif test -e ${devtype} ${devnum}:${distro_bootpart} EFI/BOOT/BOOTRISCV64.EFI; then \ load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} EFI/BOOT/BOOTRISCV64.EFI; bootefi ${kernel_addr_r}; \ fi; bootcmd=echo "Loading K1-X Environment ..."; \ echo ""; \ echo "Running NVMe Scan ..."; \ nvme scan; \ run autoboot SD takes priority. After that it checks for an eMMC and if nothing on the eMMC is found it can use, it then moves on to check the NVMe. What this means? If the unit has an SPI, it needs to be updated with the Armbian boot loader. If the bootloader finds an extlinux.conf, boot.scr or *.EFI on the eMMC it will attempt to boot from it. I have a BPI-F3 which has no SPI. What I do in that case is boot from SD, format the eMMC and transfer the install to the NVMe. I then flash u-boot to the eMMC and wham oh. System boots from NVMe. In the case of an SPI, its the same. As long as it doesn't find anything of use on the eMMC your good. 0 Quote
sven-ola Posted 31 minutes ago Author Posted 31 minutes ago Hello @1111Windows! Having a portrait HDMI display is rather unusual. Normally, one can buy landscape HDMI displays and simply rotate them via software or video card hardware. However: if reading out the EDID via I2C / HDMI cable does not work correctly, the HDMI display driver may simply fallback to 1920x1080@60 using the compiled-in EDID. You can try to get the EDID from the display with the apt install read-edid tool. If I recall correctly, one can provide a custom EDID binary as file to the kernel via some boot cmd parameter, see https://www.marcusfolkesson.se/blog/custom-edid-in-linux/ for details. Simply configure some mode via video= when the mode is not available in the EDID will not work (as you already found out). It should also be possible to add a custom modeline, but this is deep dive as stated here: https://nyanpasu64.gitlab.io/blog/crt-modeline-cvt-interlacing HTH // Sven-Ola 0 Quote
sven-ola Posted 20 minutes ago Author Posted 20 minutes ago Hello @savznkvo and @Logan. Directly booting from NVME is not supported by the ROM software burned in the RISCV chip. Instead, the OrangePi RV2 chip is able to boot from SD, eMMC, and Flash / MTD (in this order). You need to prepare the board's internal flash for NVME boot with Boot Armbian from SD card. As root, start armbian-install and select "Install to MTD". Transfer a fresh Armbian image to your NVME. If you do not have the "armbianized" MTD boot config installed, @c0rnelius above hints on booting apply. HTH // Sven-Ola 0 Quote
