sven-ola Posted February 9 Author Posted February 9 (edited) Continued GPU hacks. I uploaded a medley from Armbian (uboot,kernel) plus OrangePi-Ubuntu-Noble (userspace) from downloaded Xunlong image to my https://privat-in.de site (-> Downloads, grab Armbian+OrangePi.img.xz). Root PW is "orangepi" and it has 3 scripts /boot/boot-6.x.x to switch kernels between 6.6.36-ky, 6.6.99 and 6.18.x (both from Armbian). While the original "ky" kernel has GPU support (instantly visible with the Gnome GUI reacting < 2 seconds), the Armbian kernels have no GPU. Turns out: the kernel DRM driver name needs to be "rvdisplay" instead of "spacemit". This works at least with Armbian-Stable-6.6.99, while Armbian-Edge-6.18.x probably needs further kicking. The Armbian kernels have the following (prelim) change: --- a/drivers/gpu/drm/spacemit/spacemit_drm.c +++ b/drivers/gpu/drm/spacemit/spacemit_drm.c @@ -24,7 +24,7 @@ #include "spacemit_dmmu.h" #include "spacemit_gem.h" -#define DRIVER_NAME "spacemit" +#define DRIVER_NAME "rvdisplay" #define DRIVER_DESC "Spacemit SoCs' DRM Driver" #define DRIVER_MAJOR 1 #define DRIVER_MINOR 0 Note, that Xorg has no GPU, the GPU stuff only works with Wayland (gnome-shell + mutter). Also: no luck with that Bianbu-Linux. It's damn slow Gnome (slower that OrangePi with Software rendering) and none of the kernels brings the GPU to live (even the original Bianbu kernel with a orangepirv2 DTB does not work). @c0rnelius Bananapi R3 and Musepi Pro have working GPU? HTH // Sven-Ola Edited February 9 by sven-ola 0 Quote
maxsub Posted February 9 Posted February 9 In your downloads site, does this one have the GPU hack? Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.6.99_minimal.img. I can do some testing. Thank you. 0 Quote
sven-ola Posted February 10 Author Posted February 10 Hi @maxsub, no, thats a normal image. Hacking is the looong filename: Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_edge_6.18.8_minimal+Orangepirv2_1.0.0_ubuntu_noble_desktop_gnome_linux6.6.63.img.xz 0 Quote
c0rnelius Posted February 10 Posted February 10 3 hours ago, sven-ola said: Bananapi F3 and Musepi Pro have working GPU? When I got the MusePi Pro it came pre flashed so I tested the install. I don't recall it having an amazing DE experience. Not sure about the GPU but like most SBC's I wouldn't expect great things in that department. Which makes me wonder about the MuseBook. 0 Quote
sven-ola Posted February 10 Author Posted February 10 @c0rnelius then the GPU probably works, since without GPU e.g the Bianbu first time wizard (language, kbd, timezone, user) needs 20 minutes while uptime reports load=10. I'm damn sure you have noticed an extraslow GUI 0 Quote
sven-ola Posted February 10 Author Posted February 10 (edited) That "rvdisplay" string is found in the following files: libVK_IMG.so, libsutu_display.so, and libpvr_dri_support.so. When comparing the OpiRV2 versions of these files with https://gitee.com/spacemit-buildroot/img-gpu-powervr I got 9a640=spacemit vs 9a2d0=rvdisplay. Thus, Xunlong has source code for these (different offsets, rvdisplay is one char longer). So no need to hack Armbian kernel, I presume GPU works if we use *.so from gitee repo. HTH // Sven-Ola Edited February 10 by sven-ola 0 Quote
maxsub Posted February 10 Posted February 10 So this is built fully from source by patching the xunlong source onto the edge code base? Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_edge_6.18.8_minimal+Orangepirv2_1.0.0_ubuntu_noble_desktop_gnome_linux6.6.63.img.xz 0 Quote
sven-ola Posted February 10 Author Posted February 10 @maxsub no, its hacked. At least from my side. For us, that GPU stuff is closed, patented, tighly licensed and so on. LG // Sven-Ola 0 Quote
cal5582 Posted February 12 Posted February 12 not sure if this is the right place to ask, but i was able to get it to recompile the kernel with the xe driver flag turned on, and got a working booting 6.18.9 image, which is amazing, i have never been able to get anything newer than the 6.6 kernel the manufacturer provided working. so thank you so much for all your hard work. theres only one problem, when i do the lspci command, i dont see anything attached to that slot. i tried two different intel arc gpus, an arc 350 and an arc 310 neither detects. so i pulled out an ibm fpga card and plugged it into the same powered oculink adapter, and lo and behold the fpga card detected, so my pcie adapter setup is good. is there any advice you could offer besides enabling the xe2 driver in kernel that i may have to persue? i know this is kind of off topic, id just like to get hardware accelerated graphics working on this device. 0 Quote
maxsub Posted February 12 Posted February 12 You mean the M.2 PCIe slot? My RV2 board has no oculink slot, only 2 PCIe slots, one for NVMe and one for SSD. 0 Quote
cal5582 Posted February 12 Posted February 12 (edited) nvme drive is in the bottom slot, oculink adapter going to a powered external pci-e adapter in the top nvme slot. i was able to plug a non-gpu in it and get a device to detect. just both my intel arc gpus failed to detect. edit, new discovery, when the fpga device is active on the 2nd nvme slot i can no longer see my original nvme drive if booting off the sd card. very strange. almost like its a lane bifrucation issue. ignore that, misconfig on my end. Edited February 12 by cal5582 0 Quote
brunorro Posted February 12 Posted February 12 Thank you, @sven-ola , your work is amazing About the GPU, I suppose that spacemit can do something like what this guy did to make work the BXM-4-64 on the TH1520 https://mwilczynski.dev/posts/riscv-gpu-zink/ Anyways, my hardware knowledge is way far away from this... 0 Quote
sven-ola Posted February 12 Author Posted February 12 @cal5582 Hav you plugged in your Oculink/Intel Arc combination to a standard PC's M.2 slot? Just to make sure, it's not the power supply for our power hungry graphical friends. If it is not the power supply (5V, 12V) then there is one difference from PC to OpiRV2: the OpiRV2's M.2 slot has only 2 PCIe lanes connected, while a standard PC has M.2/M-key connectors with 4 lanes normally. A graphics card may be used to a high number of lanes, so not only hungry for power but also for lanes. Also: there seems to exist Oculink adapters with an optical link between PC/board and card. In that case, I would expect an extra PCIe bridge to be shown with lspci. 0 Quote
sven-ola Posted February 12 Author Posted February 12 (edited) @brunorro What a read! That's cool stuff - hopefully those guys'n'gals visit the next station on their journey soon: from TH1520, via JH7110, then (hopefully) X1. At least that mailbox communication sounds similar with the SpacemiT SoC: power management via extra rCPU is also a thing here. Thank you for the link // Sven-Ola Edited February 12 by sven-ola 1 Quote
sven-ola Posted February 20 Author Posted February 20 Good news: this is merged in Armbian main now, many thanks to @c0rnelius and @Igor for reviewing this. So no more need to grab my fork, just clone Armbian/build:main. I was able to build and quick-test orangepirv2/edge-kernel and this looks fine including Wifi. There are of course unsolved quirks currently. With edge-kernel, Wayland does not work, we need to use Xorg. And with the current bcmdhd Wifi driver, AP mode is not possible. This is caused by outdated file in armbian-firmware for bcmdhd and may be the same on OrangePi5. There is a mechanism to load a different fw_bcm43456c5_ag.bin (the one downloadable from github/xunlong seems to work). LG // Sven-Ola 2 Quote
Igor Posted February 22 Posted February 22 On 2/20/2026 at 10:01 PM, sven-ola said: Good news Auto generated images: https://dl.armbian.com/nightly/orangepirv2/Forky_current_minimal https://dl.armbian.com/nightly/orangepirv2/Noble_current_xfce 1 Quote
sven-ola Posted February 23 Author Posted February 23 vor 21 Stunden schrieb Igor: Auto generated images: https://dl.armbian.com/nightly/orangepirv2/Forky_current_minimal https://dl.armbian.com/nightly/orangepirv2/Noble_current_xfce Thank you: I've downloaded both images. Both images boot, work, and seems to grab the correct updates. 0 Quote
maxsub Posted February 24 Posted February 24 Is it possible to build against a current kernel (6.18 for example)? I am trying to build an access point on Armbian but 6.6 does not support AP mode on most adapters. 0 Quote
sven-ola Posted February 24 Author Posted February 24 (edited) Hello @maxsub! The RV2 is a bit overpowered CPU-wise for an access point while underpowered Wifi-wise. I am pretty sure, that AP mode works with 6.6 if you overwrite fw_bcm43456c5_ag.bin from https://github.com/orangepi-xunlong/firmware As a note: to build a Wifi-Router/AP, you can use OpenWrt which is available for the RV2 and may be better up to the task... HTH // Sven-Ola Edited February 24 by sven-ola 0 Quote
maxsub Posted February 24 Posted February 24 Thanks @sven-ola! You have been of amazing support here. My worry about using the closed source binary firmware is that it opens up a security hole (no patches for vulnerabilities, etc). Same for OpenWrt - the xunlong code is a fork from OpenWrt and not being updated as far as I can tell. That's why I went the Armbian route, with your code in mainstream, it will get continuously updated. The WiFi is definitely underpowered, and CPU overpowered. I am using an R2S with a USB Wireless adapter (realtek): Panda wireless PAU0B. However, the 6.6 kernel seems to not allow AP mode. 0 Quote
sven-ola Posted February 24 Author Posted February 24 (edited) @maxsub: the sad truth is: nearly any non-primitive hardware component needs some sort of firmware these days, you should live with that... Anyhow, as I told earlier, just replace the FW for the bcmdhd. Here's how (make sure do disabled any /etc/netplan/wifi-this-and-that.yaml, my device has inet via eth) apt-get install hostapd cat > /etc/hostapd.conf << EOF interface=wlan0 driver=nl80211 ssid=test channel=1 EOF wget -O /lib/firmware/fw_bcm43456c5_ag.bin https://github.com/orangepi-xunlong/firmware/raw/refs/heads/master/fw_bcm43456c5_ag.bin hostapd -d /etc/hostapd.conf This works, tested on the Forky-minimal linked above. HTH // Sven-Ola Edited February 24 by sven-ola 0 Quote
maxsub Posted February 24 Posted February 24 Thanks @sven-ola. I will give that a try. The standard Armbian is unable to connect to an WPA3 access point in basic client mode (no AP). It connects fine to WPA2-Personal. 0 Quote
maxsub Posted February 26 Posted February 26 I setup a fresh install on the RV2 using the pre-built Forky binary. Everything works stably but the idle load average is very high all the time: armbian@orangepirv2:~$ uptime 09:22:27 up 13:30, 1 user, load average: 2.00, 2.00, 2.00 Looks like the bug that cause the kernel to spin is still there. 0 Quote
c0rnelius Posted February 26 Posted February 26 Looks like the same adjustment that was made for EDGE needs to be done so for CURRENT. 1 Quote
sven-ola Posted March 6 Author Posted March 6 Am 26.2.2026 um 19:21 schrieb c0rnelius: Looks like the same adjustment that was made for EDGE needs to be done so for CURRENT. Added the respective PR: https://github.com/armbian/build/pull/9496 0 Quote
sven-ola Posted March 8 Author Posted March 8 Status Update: There is already a suitable FW file for Wifi AP mode. It's located in the /lib/firmware/brcm subdir: the newer fw_bcm43456c5_ag.bin can be used by adding firmware_path=brcm/ nvram_path=brcm/ when loading the bcmdhd.ko kernel module. The necessary change is now in Armbian::main. Also, the RV2 legacy 6.6.99 kernel has an advantage: with the Xunlong Ubuntu userspace (from Xunlong image downloads) it supports Wayland and thus GPU when applying the following hack: diff --git a/drivers/gpu/drm/spacemit/spacemit_drm.c b/drivers/gpu/drm/spacemit/spacemit_drm.c index da25ec8b3f..073de3c7ca 100644 --- a/drivers/gpu/drm/spacemit/spacemit_drm.c +++ b/drivers/gpu/drm/spacemit/spacemit_drm.c @@ -23,7 +23,7 @@ #include "spacemit_dmmu.h" #include "spacemit_gem.h" -#define DRIVER_NAME "spacemit" +#define DRIVER_NAME "rvdisplay" #define DRIVER_DESC "Spacemit SoCs' DRM Driver" #define DRIVER_DATE "20231115" #define DRIVER_MAJOR 1 For that reason, we added the LOAD fix also to the legacy/6.6 kernel (thus the uptime output shows a reassuring 0.00). Wayland support for current/6.18 kernel is still under investigation. Also, the edge/7.0 kernel does not boot on the RV2 currently. 0 Quote
maxsub Posted March 8 Posted March 8 Excellent. Thank you so much. I will try the newer brcm driver today. So the GPU change is now in main? 0 Quote
sven-ola Posted March 9 Author Posted March 9 vor 12 Stunden schrieb maxsub: I will try the newer brcm driver today. So the GPU change is now in main? Hi @maxsub, two annotations. Firstly, it's not the Wifi driver but the firmware. Thus echo "options bcmdhd firmware_path=brcm/ nvram_path=brcm/" > /etc/modprobe.d/orangepirv2.conf will get you going. And secondly no, there is no GPU change currently. GPU not working in "current" but may work with dirty tricks using "legacy". That's why it may pay to do some maintenance on the ancient 6.6 kernel. 0 Quote
Cristian Apas Posted March 10 Posted March 10 The question is: does the auto-generated version available for download with a legacy kernel include the hack to make the GPU work in Wayland, and if not, how should I compile it? Thanks 0 Quote
c0rnelius Posted March 10 Posted March 10 @sven-ola https://lore.kernel.org/spacemit/20260310161853.3900605-1-gaohan@iscas.ac.cn/T/#t Sometime soon-ish I'll be doing another PR with early SD card and CPU freq scaling support. The above link should at least get you boot from eMMC or NVMe. 1 Quote
