Luna the Deer Posted Sunday at 02:37 AM Posted Sunday at 02:37 AM Armbianmonitor: https://paste.armbian.com/nibigepaca Fairly recently, I've noticed these warnings appearing when running apt update. I have tried importing the keys from the repositories in question, but that has not remediated the issue. root@modron:/home/luna# apt update Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://deb.debian.org/debian trixie-backports InRelease Hit:4 http://security.debian.org trixie-security InRelease Hit:6 https://download.docker.com/linux/debian trixie InRelease Hit:7 https://github.armbian.com/configng stable InRelease Get:5 http://armbian.lv.auroradev.org/apt trixie InRelease [62.3 kB] Err:5 http://armbian.lv.auroradev.org/apt trixie InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Fetched 62.3 kB in 1s (67.6 kB/s) 10 packages can be upgraded. Run 'apt list --upgradable' to see them. Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://armbian.lv.auroradev.org/apt trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Warning: Failed to fetch http://apt.armbian.com/dists/trixie/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Warning: Some index files failed to download. They have been ignored, or old ones used instead. 0 Quote
eselarm Posted Sunday at 11:06 AM Posted Sunday at 11:06 AM log says: No space left on device So you need to look at that, remove unneeded stuff etc. Also check the output of df Maybe something else is wrong 0 Quote
Luna the Deer Posted 1 hour ago Author Posted 1 hour ago That is another issue I'm working on, see As for this issue, once the disk space problem is resolved, it still happens. luna@modron:~$ df Filesystem 1K-blocks Used Available Use% Mounted on udev 926940 0 926940 0% /dev tmpfs 201916 900 201016 1% /run /dev/mmcblk0p1 120241980 18447284 100534968 16% / tmpfs 1009572 7236 1002336 1% /dev/shm tmpfs 5120 0 5120 0% /run/lock tmpfs 1024 0 1024 0% /run/credentials/systemd-resolved.service tmpfs 1009572 8 1009564 1% /tmp armbian-ramlog 51200 51200 0 100% /var/log tmpfs 1024 0 1024 0% /run/credentials/systemd-journald.service /dev/sda1 7751271852 7295398216 65155992 100% /mnt/external tmpfs 1024 0 1024 0% /run/credentials/getty@tty1.service tmpfs 1024 0 1024 0% /run/credentials/serial-getty@ttyS2.service tmpfs 201912 4 201908 1% /run/user/1000 luna@modron:~$ sudo apt update Hit:1 http://deb.debian.org/debian trixie InRelease Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Get:3 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Get:4 http://security.debian.org trixie-security InRelease [43.4 kB] Hit:6 https://download.docker.com/linux/debian trixie InRelease Hit:7 https://github.armbian.com/configng stable InRelease Get:5 http://armbian.lv.auroradev.org/apt trixie InRelease [62.3 kB] Get:8 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index [63.3 kB] Get:9 http://deb.debian.org/debian trixie-backports/main all Contents (deb).diff/Index [63.6 kB] Get:10 http://deb.debian.org/debian trixie-backports/main arm64 Contents (deb).diff/Index [63.5 kB] Err:5 http://armbian.lv.auroradev.org/apt trixie InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [17.6 kB] Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [17.6 kB] Get:12 http://deb.debian.org/debian trixie-backports/main all Contents (deb) T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [245 kB] Get:12 http://deb.debian.org/debian trixie-backports/main all Contents (deb) T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [245 kB] Get:13 http://deb.debian.org/debian trixie-backports/main arm64 Contents (deb) T-2025-12-31-0829.39-F-2025-12-29-0207.06.pdiff [399 kB] Get:13 http://deb.debian.org/debian trixie-backports/main arm64 Contents (deb) T-2025-12-31-0829.39-F-2025-12-29-0207.06.pdiff [399 kB] Fetched 1,059 kB in 10s (104 kB/s) 10 packages can be upgraded. Run 'apt list --upgradable' to see them. Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://armbian.lv.auroradev.org/apt trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Warning: Failed to fetch http://apt.armbian.com/dists/trixie/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. Warning: Some index files failed to download. They have been ignored, or old ones used instead. 0 Quote
eselarm Posted 56 minutes ago Posted 56 minutes ago (edited) I do not know how to fix that key / verify signature issue. It might be there because of earlier diskfull. I only know I needed new keyrings, listed in the armbian list files when I did the in-place upgrade from bookworm to trixie. There is a formal method for that I think, might be here on forum. I however did copy various things from a new Armbian Trixie image. E.g. new file is now: -rw-rw-r-- 1 root root 2297 Aug 31 22:15 /usr/share/keyrings/armbian-archive-keyring.gpg ~# sha256sum /usr/share/keyrings/armbian-archive-keyring.gpg 9d0ab1676008004f1ee0bfc0f99a6043544d8bb6df3d949f9bd30066246f9095 /usr/share/keyrings/armbian-archive-keyring.gpg For Docker problem: I don't use Docker, I have no clue why that file keeps growing. Edited 55 minutes ago by eselarm 0 Quote
