Fairly recently, I've noticed these warnings appearing when running apt update. I have tried importing the keys from the repositories in question, but that has not remediated the issue.
root@modron:/home/luna# apt update
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian trixie-backports InRelease
Hit:4 http://security.debian.org trixie-security InRelease
Hit:6 https://download.docker.com/linux/debian trixie InRelease
Hit:7 https://github.armbian.com/configng stable InRelease
Get:5 http://armbian.lv.auroradev.org/apt trixie InRelease [62.3 kB]
Err:5 http://armbian.lv.auroradev.org/apt trixie InRelease
  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature.
Fetched 62.3 kB in 1s (67.6 kB/s)
10 packages can be upgraded. Run 'apt list --upgradable' to see them.
Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://armbian.lv.auroradev.org/apt trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature.
Warning: Failed to fetch http://apt.armbian.com/dists/trixie/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature.
Warning: Some index files failed to download. They have been ignored, or old ones used instead.
That is another issue I'm working on, see
As for this issue, once the disk space problem is resolved, it still happens.
luna@modron:~$ df
Filesystem      1K-blocks       Used Available Use% Mounted on
udev               926940          0    926940   0% /dev
tmpfs              201916        900    201016   1% /run
/dev/mmcblk0p1  120241980   18447284 100534968  16% /
tmpfs             1009572       7236   1002336   1% /dev/shm
tmpfs                5120          0      5120   0% /run/lock
tmpfs                1024          0      1024   0% /run/credentials/systemd-resolved.service
tmpfs             1009572          8   1009564   1% /tmp
armbian-ramlog      51200      51200         0 100% /var/log
tmpfs                1024          0      1024   0% /run/credentials/systemd-journald.service
/dev/sda1      7751271852 7295398216  65155992 100% /mnt/external
tmpfs                1024          0      1024   0% /run/credentials/getty@tty1.service
tmpfs                1024          0      1024   0% /run/credentials/serial-getty@ttyS2.service
tmpfs              201912          4    201908   1% /run/user/1000
luna@modron:~$ sudo apt update
Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
Get:3 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB]
Get:4 http://security.debian.org trixie-security InRelease [43.4 kB]
Get:8 http://deb.debian.org/debian trixie-backports/main arm64 Packages.diff/Index [63.3 kB]
Get:9 http://deb.debian.org/debian trixie-backports/main all Contents (deb).diff/Index [63.6 kB]
Get:10 http://deb.debian.org/debian trixie-backports/main arm64 Contents (deb).diff/Index [63.5 kB]
Get:11 http://deb.debian.org/debian trixie-backports/main arm64 Packages T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [17.6 kB]
Get:12 http://deb.debian.org/debian trixie-backports/main all Contents (deb) T-2025-12-31-1402.47-F-2025-12-28-0205.37.pdiff [245 kB]
Get:13 http://deb.debian.org/debian trixie-backports/main arm64 Contents (deb) T-2025-12-31-0829.39-F-2025-12-29-0207.06.pdiff [399 kB]
Fetched 1,059 kB in 10s (104 kB/s)
Posted (edited)
I do not know how to fix that key / verify signature issue. It might be there because of earlier diskfull. I only know I needed new keyrings, listed in the armbian list files when I did the in-place upgrade from bookworm to trixie. There is a formal method for that I think, might be here on forum. I however did copy various things from a new Armbian Trixie image. E.g. new file is now:
-rw-rw-r-- 1 root root 2297 Aug 31 22:15 /usr/share/keyrings/armbian-archive-keyring.gpg
~# sha256sum /usr/share/keyrings/armbian-archive-keyring.gpg
9d0ab1676008004f1ee0bfc0f99a6043544d8bb6df3d949f9bd30066246f9095  /usr/share/keyrings/armbian-archive-keyring.gpg
For Docker problem: I don't use Docker, I have no clue why that file keeps growing.
Edited by eselarm
