Lane Mitcham Posted January 3 Posted January 3 I have a Orange Pi Zero 2W and want to install a headless ( minimal ) OS. I have tried Armbian 25.5.1. I have an Ubuntu box and I have attempted to write to the SD card using Armbian ImagerImager, by selecting an image from the app as well as downloading an image to use. In both instances, I get a FLASH failure. See the attached image for the diag link. Can anyone give me some insight? 0 Quote
Lane Mitcham Posted January 3 Author Posted January 3 By the way, the "tag" says "solved", but that is not true. A tag was required for submission and "solved" was the only selection available in the drop down and the text box was not editable. 0 Quote
Werner Posted January 3 Posted January 3 Please report here https://github.com/armbian/imager/issues 0 Quote
Solution Lane Mitcham Posted 1 hour ago Author Solution Posted 1 hour ago The issue was bad SD media. Replaced the SD card and the image was written successfully. Side note. Armbian 25.5.1 does not create 2 partitions, it was designed to create only one partition. That was confusing because most instructions for installation were still referring to 2 partitions until I stumbled on a ChatGPT answer. 0 Quote
