cobric Posted January 19 Posted January 19 Armbianmonitor: https://paste.armbian.com/ajigudifor Hi, As I can see on latest kernel for beta/trunk Armbian: https://imola.armbian.com/beta/pool/main/l/linux-6.18.6/linux-image-current-meson64_26.2.0-trunk.281_arm64__6.18.6-Sb6fe-D8ec8-Pe0be-C7d3eH1ff9-HK01ba-Ve377-Bc630-R448a.deb There is no module ip_tables (should be under /lib/modules/6.18.6-current-meson64/kernel/net/ipv4/netfilter/), so iptables does not work: "modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.18.6-current-meson64" Is this intentional? Thank you! 0 Quote
Werner Posted January 20 Posted January 20 Should be there. https://github.com/armbian/build/blob/00b6e17abfd859893a39f6445715a3327fed150a/config/kernel/linux-meson64-edge.config#L355 https://cateee.net/lkddb/web-lkddb/IP_NF_IPTABLES.html 0 Quote
