DogancanYr Posted January 29 Posted January 29 I installed pihole and unbound with Armbian's ready-made config installation, but I can't access the interface of the pihole. 0 Quote
Igor Posted January 29 Posted January 29 2 hours ago, DogancanYr said: I installed pihole and unbound with Armbian's ready-made config installation, but I can't access the interface of the pihole. Did you used most up2date armbian-config? Few days ago some critical bugs were fixed - i tested it several times and it worked ... 0 Quote
Igor Posted January 29 Posted January 29 Test automation doesn't detect any issues https://github.com/armbian/configng/actions/runs/21465331853 and since I had freshly build Armbian Trixie on Nanopi R6S (same arch) I run install: Spoiler 2026-01-29 22:35:43.339 started, version pi-hole-v2.92test21 cachesize 10000 2026-01-29 22:35:43.339 DNS service limited to local subnets 2026-01-29 22:35:43.339 compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN2 DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth DNSSEC loop-detect inotify dumpfile 2026-01-29 22:35:43.339 using nameserver 172.18.0.2#5335 2026-01-29 22:35:43.339 using only locally-known addresses for onion 2026-01-29 22:35:43.339 using only locally-known addresses for bind 2026-01-29 22:35:43.339 using only locally-known addresses for invalid 2026-01-29 22:35:43.339 using only locally-known addresses for test 2026-01-29 22:35:43.339 using only locally-known addresses for pi.hole 2026-01-29 22:35:43.339 using only locally-known addresses for lan 2026-01-29 22:35:43.339 using only locally-known addresses for internal 2026-01-29 22:35:43.339 using only locally-known addresses for home.arpa 2026-01-29 22:35:43.339 read /etc/hosts - 10 names 2026-01-29 22:35:43.339 read /etc/pihole/hosts/custom.list - 0 names 2026-01-29 22:36:02.383 query[SRV] _http._tcp.apt.armbian.com from 172.18.0.1 2026-01-29 22:36:02.392 forwarded _http._tcp.apt.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.392 query[SRV] _https._tcp.github.armbian.com from 172.18.0.1 2026-01-29 22:36:02.392 forwarded _https._tcp.github.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.392 query[SRV] _http._tcp.deb.debian.org from 172.18.0.1 2026-01-29 22:36:02.393 forwarded _http._tcp.deb.debian.org to 172.18.0.2#5335 2026-01-29 22:36:02.393 query[SRV] _http._tcp.security.debian.org from 172.18.0.1 2026-01-29 22:36:02.393 forwarded _http._tcp.security.debian.org to 172.18.0.2#5335 2026-01-29 22:36:02.477 reply _http._tcp.apt.armbian.com is NXDOMAIN 2026-01-29 22:36:02.478 query[A] apt.armbian.com from 172.18.0.1 2026-01-29 22:36:02.479 forwarded apt.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.479 query[AAAA] apt.armbian.com from 172.18.0.1 2026-01-29 22:36:02.479 forwarded apt.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.479 reply apt.armbian.com is 152.53.81.238 2026-01-29 22:36:02.481 reply _http._tcp.deb.debian.org is <SRV> 2026-01-29 22:36:02.481 reply _http._tcp.security.debian.org is <SRV> 2026-01-29 22:36:02.482 query[A] debian.map.fastlydns.net from 172.18.0.1 2026-01-29 22:36:02.483 forwarded debian.map.fastlydns.net to 172.18.0.2#5335 2026-01-29 22:36:02.483 query[AAAA] debian.map.fastlydns.net from 172.18.0.1 2026-01-29 22:36:02.483 forwarded debian.map.fastlydns.net to 172.18.0.2#5335 2026-01-29 22:36:02.483 query[A] debian.map.fastlydns.net from 172.18.0.1 2026-01-29 22:36:02.483 query[AAAA] debian.map.fastlydns.net from 172.18.0.1 2026-01-29 22:36:02.501 reply apt.armbian.com is 2a0a:4cc0:2000:34a5::1 2026-01-29 22:36:02.509 reply _https._tcp.github.armbian.com is NXDOMAIN 2026-01-29 22:36:02.511 query[A] github.armbian.com from 172.18.0.1 2026-01-29 22:36:02.511 forwarded github.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.511 query[AAAA] github.armbian.com from 172.18.0.1 2026-01-29 22:36:02.511 forwarded github.armbian.com to 172.18.0.2#5335 2026-01-29 22:36:02.530 reply debian.map.fastlydns.net is 199.232.18.132 2026-01-29 22:36:02.538 reply debian.map.fastlydns.net is 2a04:4e42:41::644 2026-01-29 22:36:02.683 reply github.armbian.com is <CNAME> 2026-01-29 22:36:02.684 reply armbian.github.io is 2606:50c0:8003::153 2026-01-29 22:36:02.684 reply armbian.github.io is 2606:50c0:8000::153 2026-01-29 22:36:02.684 reply armbian.github.io is 2606:50c0:8001::153 2026-01-29 22:36:02.684 reply armbian.github.io is 2606:50c0:8002::153 2026-01-29 22:36:02.699 reply github.armbian.com is <CNAME> 2026-01-29 22:36:02.699 reply armbian.github.io is 185.199.110.153 2026-01-29 22:36:02.699 reply armbian.github.io is 185.199.111.153 2026-01-29 22:36:02.699 reply armbian.github.io is 185.199.108.153 2026-01-29 22:36:02.699 reply armbian.github.io is 185.199.109.153 2026-01-29 22:36:02.730 query[SRV] _http._tcp.armbian.systemonachip.net from 172.18.0.1 2026-01-29 22:36:02.730 forwarded _http._tcp.armbian.systemonachip.net to 172.18.0.2#5335 2026-01-29 22:36:03.351 query[PTR] 1.0.18.172.in-addr.arpa from 127.0.0.1 2026-01-29 22:36:03.361 config 172.18.0.1 is NXDOMAIN 2026-01-29 22:36:03.363 query[PTR] 2.0.18.172.in-addr.arpa from 127.0.0.1 2026-01-29 22:36:03.364 config 172.18.0.2 is NXDOMAIN 2026-01-29 22:36:03.384 reply _http._tcp.armbian.systemonachip.net is NXDOMAIN 2026-01-29 22:36:03.385 query[A] armbian.systemonachip.net from 172.18.0.1 2026-01-29 22:36:03.385 forwarded armbian.systemonachip.net to 172.18.0.2#5335 2026-01-29 22:36:03.385 query[AAAA] armbian.systemonachip.net from 172.18.0.1 2026-01-29 22:36:03.386 forwarded armbian.systemonachip.net to 172.18.0.2#5335 2026-01-29 22:36:03.464 reply armbian.systemonachip.net is 2a0d:f302:103:5674::2 2026-01-29 22:36:03.527 reply armbian.systemonachip.net is 46.102.157.202 2026-01-29 22:36:04.368 query[PTR] 1.0.0.127.in-addr.arpa from 127.0.0.1 2026-01-29 22:36:04.368 /etc/hosts 127.0.0.1 is localhost 2026-01-29 22:36:08.766 query[A] pi.hole from 127.0.0.1 2026-01-29 22:36:08.766 Pi-hole hostname pi.hole is 127.0.0.1 2026-01-29 22:36:39.010 query[A] pi.hole from 127.0.0.1 2026-01-29 22:36:39.010 Pi-hole hostname pi.hole is 127.0.0.1 2026-01-29 22:37:09.283 query[A] pi.hole from 127.0.0.1 2026-01-29 22:37:09.283 Pi-hole hostname pi.hole is 127.0.0.1 Spoiler 2026-01-29 22:35:42.878 INFO PID of FTL process: 195 2026-01-29 22:35:42.880 INFO listening on 0.0.0.0 port 53 2026-01-29 22:35:42.880 INFO listening on :: port 53 2026-01-29 22:35:42.882 INFO PID of FTL process: 195 2026-01-29 22:35:42.882 WARNING No database file found, creating new (empty) database 2026-01-29 22:35:42.928 INFO Database version is 1 2026-01-29 22:35:42.928 INFO Updating long-term database to version 2 2026-01-29 22:35:42.942 INFO Updating long-term database to version 3 2026-01-29 22:35:42.954 INFO Updating long-term database to version 4 2026-01-29 22:35:42.962 INFO Updating long-term database to version 5 2026-01-29 22:35:42.981 INFO Updating long-term database to version 6 2026-01-29 22:35:42.989 INFO Updating long-term database to version 7 2026-01-29 22:35:42.997 INFO Updating long-term database to version 8 2026-01-29 22:35:43.017 INFO Updating long-term database to version 9 2026-01-29 22:35:43.027 INFO Updating long-term database to version 10 2026-01-29 22:35:43.044 INFO Updating long-term database to version 11 2026-01-29 22:35:43.058 INFO Updating long-term database to version 12 2026-01-29 22:35:43.069 INFO Updating long-term database to version 13 2026-01-29 22:35:43.077 INFO Updating long-term database to version 14 2026-01-29 22:35:43.085 INFO Updating long-term database to version 15 2026-01-29 22:35:43.099 INFO Updating long-term database to version 16 2026-01-29 22:35:43.107 INFO Updating long-term database to version 17 2026-01-29 22:35:43.118 INFO Updating long-term database to version 18 2026-01-29 22:35:43.126 INFO Updating long-term database to version 19 2026-01-29 22:35:43.134 INFO Updating long-term database to version 20 2026-01-29 22:35:43.154 INFO Updating long-term database to version 21 2026-01-29 22:35:43.163 INFO Database successfully initialized 2026-01-29 22:35:43.178 INFO Imported 0 queries from the on-disk database (it has 0 rows) 2026-01-29 22:35:43.178 INFO Parsing queries in database 2026-01-29 22:35:43.178 INFO Imported 0 queries from the long-term database 2026-01-29 22:35:43.178 INFO -> Total DNS queries: 0 2026-01-29 22:35:43.178 INFO -> Cached DNS queries: 0 2026-01-29 22:35:43.178 INFO -> Forwarded DNS queries: 0 2026-01-29 22:35:43.178 INFO -> Blocked DNS queries: 0 2026-01-29 22:35:43.178 INFO -> Unknown DNS queries: 0 2026-01-29 22:35:43.178 INFO -> Unique domains: 0 2026-01-29 22:35:43.178 INFO -> Unique clients: 0 2026-01-29 22:35:43.178 INFO -> DNS cache records: 0 2026-01-29 22:35:43.179 INFO -> Known forward destinations: 0 2026-01-29 22:35:43.329 WARNING Insufficient permissions to set system time (CAP_SYS_TIME required), NTP client not available 2026-01-29 22:35:43.329 INFO NTP server listening on 0.0.0.0:123 (IPv4) 2026-01-29 22:35:43.329 INFO NTP server listening on :::123 (IPv6) 2026-01-29 22:35:43.329 INFO FTL is running as user pihole (UID 1000) 2026-01-29 22:35:43.333 INFO Created SSL/TLS certificate for pi.hole at /etc/pihole/tls.pem 2026-01-29 22:35:43.333 INFO Reading certificate from /etc/pihole/tls.pem ... 2026-01-29 22:35:43.333 INFO Using SSL/TLS certificate file /etc/pihole/tls.pem 2026-01-29 22:35:43.333 INFO Web server ports: 2026-01-29 22:35:43.333 INFO - 0.0.0.0:80 (HTTP, IPv4, optional, OK) 2026-01-29 22:35:43.333 INFO - 0.0.0.0:443 (HTTPS, IPv4, optional, OK) 2026-01-29 22:35:43.333 INFO - [::]:80 (HTTP, IPv6, optional, OK) 2026-01-29 22:35:43.333 INFO - [::]:443 (HTTPS, IPv6, optional, OK) 2026-01-29 22:35:43.333 INFO Restored 0 API sessions from the database 2026-01-29 22:35:43.339 INFO Blocking status is enabled 2026-01-29 22:35:43.433 INFO Compiled 0 allow and 0 deny regex for 0 client in 0.1 msec 2026-01-29 22:35:44.330 INFO Reloading config due to pihole.toml change 2026-01-29 22:35:44.332 INFO 2 FTLCONF environment variables found (1 used, 0 invalid, 1 ignored) 2026-01-29 22:35:44.332 INFO [✓] FTLCONF_dns_upstreams is used 2026-01-29 22:35:44.333 WARNING [?] FTLCONF_LOCAL_IPV4 is unknown, did you mean any of these? 2026-01-29 22:35:44.333 WARNING - FTLCONF_debug_all 2026-01-29 22:35:44.337 INFO Wrote config file: 2026-01-29 22:35:44.337 INFO - 162 total entries 2026-01-29 22:35:44.337 INFO - 159 entries are default 2026-01-29 22:35:44.337 INFO - 3 entries are modified 2026-01-29 22:35:44.337 INFO - 1 entry is forced through environment Works like charm. Make sure to do apt update + apt upgrade before you start. 0 Quote
DogancanYr Posted January 30 Author Posted January 30 I downloaded image today using Armbian Imager, and it asked me to run something like armbian-update. I installed the system afterward, but it didn’t work. 0 Quote
