Berat Uslu Posted November 29, 2017 Share Posted November 29, 2017 Hi, I am using orange pi lite. and loaded debian desktop.. it says it connected to wifi network. But I am trying to browse internet with chromium. It can't reach to the internet. it cant upload since there is no internet connection so I took pictures of reult of command armbianmonitor -U as much as I could. Here are the screen shots. https://ibb.co/jMyjKbhttps://ibb.co/kPK8ebhttps://ibb.co/hRndebhttps://ibb.co/cdsdebhttps://ibb.co/ihXiCwhttps://ibb.co/f6RRXw and I dont know how to fix. this Can someone help me? Thank you. Link to comment Share on other sites More sharing options...
Igor Posted November 29, 2017 Share Posted November 29, 2017 How did you connect to the internet? https://docs.armbian.com/User-Guide_Getting-Started/#how-to-connect-to-wireless Link to comment Share on other sites More sharing options...
Berat Uslu Posted November 29, 2017 Author Share Posted November 29, 2017 I connected using GUI? at top right corner... Link to comment Share on other sites More sharing options...
Berat Uslu Posted November 29, 2017 Author Share Posted November 29, 2017 I am still having same issue... Link to comment Share on other sites More sharing options...
guidol Posted November 29, 2017 Share Posted November 29, 2017 45 minutes ago, Berat Uslu said: I connected using GUI? at top right corner... I got also problem with the GUI-Network-connection in Pixel Desktop on Raspberry. Please try to use nmtui-connect or nmtui in the Shell/Console Check if you got the right /etc/network/interfaces which is managed by the network-manager:https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration Link to comment Share on other sites More sharing options...
Berat Uslu Posted November 29, 2017 Author Share Posted November 29, 2017 Hi Guidol, I tried nmtui-connect command, problem still remains. I am in new in the linux area.. which things should I check if it is right? Link to comment Share on other sites More sharing options...
guidol Posted November 29, 2017 Share Posted November 29, 2017 5 minutes ago, Berat Uslu said: Hi Guidol, I tried nmtui-connect command, problem still remains. I am in new in the linux area.. which things should I check if it is right? check if you can "ping 8.8.8.8" this is the Google-DNS-Server and show us the content of your /etc/network/interfaces Do you use DHCP for the IP (from the router) or di you use a static IP? Link to comment Share on other sites More sharing options...
Berat Uslu Posted November 29, 2017 Author Share Posted November 29, 2017 8 minutes ago, guidol said: check if you can "ping 8.8.8.8" this is the Google-DNS-Server and show us the content of your /etc/network/interfaces Do you use DHCP for the IP (from the router) or di you use a static IP? my IP is not static from my internet provider... Here is results:http://ibb.co/eZh09bhttp://ibb.co/bEndvG thank you. Link to comment Share on other sites More sharing options...
Berat Uslu Posted November 29, 2017 Author Share Posted November 29, 2017 43 minutes ago, guidol said: I got also problem with the GUI-Network-connection in Pixel Desktop on Raspberry. Please try to use nmtui-connect or nmtui in the Shell/Console Check if you got the right /etc/network/interfaces which is managed by the network-manager:https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-change-network-configuration This answer solved my issue.. https://unix.stackexchange.com/questions/55881/debian-cannot-access-internet-despite-being-connected Thank you very much guys... Link to comment Share on other sites More sharing options...
guidol Posted November 29, 2017 Share Posted November 29, 2017 7 minutes ago, Berat Uslu said: my IP is not static from my internet provider... Here is results:http://ibb.co/eZh09bhttp://ibb.co/bEndvG thank you. the IP from the Internet provider hasnt to be static Your Orange Pi seems to get his IP via DHCP from the router/DSL-Modem, but is missing the DNS-Server entry, because you can ping to the internet (8.8.8.8) but the Orange Pi doesnt know the name of the Google-IP. Normally the router/DSL-Modem also submit the IP of the DNS-Server via DHCP to your computer/Orange PI. Do you have other computers working via DHCP while connected to your router/DSL-Modem? For a first test you could try to add a DNS-Server to your connection. First try to find the name of your connection with : nmcli con show -a then add dns-servers to the connection: nmcli con mod [the_name_of_your_connection] ipv4.dns “8.8.8.8 8.8.4.4” https://www.tecmint.com/configure-network-connections-using-nmcli-tool-in-linux/ Link to comment Share on other sites More sharing options...
