Meestor_X Posted February 13 Posted February 13 I noticed that the Cubie a5e would reboot when anything that draws moderate power (>100mA) was connected to the USB3 port. Thought it was my power supply or USB cable, but after changing that out and doing some testing, I have determined that the reboot problem doesn't happen with the Radxa Bullseye image, only with the Armbian Trixie. I haven't had a chance to test older Armbian builds to see if it broke somewhere along the way, but that's what I'll do next. Armbian boot (26.2.0 trunk 385): U-Boot SPL 2026.01_armbian-2026.01-S127a-P96c6-H560c-Va7f1-B2eb2-R448a (Feb 03 2026 - 12:13:55 +0000) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.13.0(debug):armbian NOTICE: BL31: Built : 12:13:32, Feb 3 2026 NOTICE: BL31: Detected Allwinner A523 SoC (1890) NOTICE: BL31: Found U-Boot DTB at 0xa0c06a8, model: Radxa Cubie A5E INFO: Configuring SPC Controller INFO: BL31: Platform setup done INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: BL31: Initializing runtime services INFO: BL31: cortex_a55: CPU workaround for erratum 1530923 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 ns16550_serial serial@2500000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2026.01_armbian-2026.01-S127a-P96c6-H560c-Va7f1-B2eb2-R448a (Feb 03 2026 - 12:13:55 +0000) Allwinner Technology CPU: Allwinner A523 (SUN55I) Model: Radxa Cubie A5E DRAM: 2 GiB sunxi_set_gate: (CLK#35) unhandled Core: 88 devices, 25 uclasses, devicetree: separate WDT: Not starting watchdog@2050000 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1... In: serial@2500000 Out: serial@2500000 Err: serial@2500000 Net: eth0: ethernet@4500000 starting USB... sun4i_usb_phy phy@4100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 USB OHCI 1.0 USB EHCI 1.00 USB OHCI 1.0 Bus usb@4101000: 1 USB Device(s) found Bus usb@4101400: 1 USB Device(s) found Bus usb@4200000: 1 USB Device(s) found Bus usb@4200400: 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 PCIe: Acquiring resources... PCIe: All resources acquired. Starting power-on sequence... PCIe: Toggling external device reset (PERST#)... PCIe: Hardware power-on sequence successful. PCIe: Disabling DBI write protection... PCIe: DBI region: 0x04800000-0x04c80000 PCIe: IO region: 0x21000000-0x22000000 PCIe: MEM region: 0x22000000-0x30000000 PCIe: CFG region: 0x20000000-0x21000000 PCIe: Lanes: 1, Max Speed: Gen2 Link Status: 0x00000004 RDLH_LINK_UP: 0 SMLH_LINK_UP: 0 LINK_SPEED: 0 LINK_WIDTH: 0 Link Status: 0x00000004 RDLH_LINK_UP: 0 SMLH_LINK_UP: 0 LINK_SPEED: 0 LINK_WIDTH: 0 Link Status: 0x00000017 RDLH_LINK_UP: 1 SMLH_LINK_UP: 1 LINK_SPEED: 0 LINK_WIDTH: 0 pcie link up success PCIe: Link active at Gen2 Device 0: Vendor: 0x1e0f Rev: 10410105 Prod: X06PD8L0QUM1 Type: Hard Disk Capacity: 244198.3 MB = 238.4 GB (500118192 x 512) ... is now current device Scanning nvme 0:1... Found U-Boot script /boot.scr 4641 bytes read in 0 ms ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from nvme 263 bytes read in 0 ms Load fdt: /dtb/allwinner/sun55i-a527-cubie-a5e.dtb 37110 bytes read in 1 ms (35.4 MiB/s) Working FDT set to 4fa00000 Failed to load '/dtb/allwinner/overlay/sun55i-a527-fixup.scr' 16552556 bytes read in 55 ms (287 MiB/s) 39950848 bytes read in 102 ms (373.5 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42900000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16552492 Bytes = 15.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 49036000, end 49fff22c ... OK Loading Device Tree to 0000000048fc4000, end 0000000049035fff ... OK Working FDT set to 48fc4000 Starting kernel ... Armbian_community 26.2.0-trunk.385 Trixie ttyS0 radxa-cubie-a5e login: Radxa Bookworm Boot: [207]HELLO! BOOT0 is starting! [210]BOOT0 commit : 33d8db429a-dirty [214]periph0 has been enabled [218]set pll end [219]PL gpio voltage : 3.3V [224]PMU: AXP2202 [229]PMU: AXP1530 [234]power mode:33, sys_vol:920 [239]vaild para:1 select dram para0 [242]dram_para[0]:0x4b0 [245]dram_para[1]:0x8 [247]dram_para[2]:0x7070707 [250]dram_para[3]:0xd0d0d0d [253]dram_para[4]:0xe0e [256]dram_para[5]:0x84848484 [259]dram_para[6]:0x310a [262]dram_para[7]:0x10001000 [265]dram_para[8]:0x0 [267]dram_para[9]:0x34 [270]dram_para[10]:0x1b [272]dram_para[11]:0x33 [275]dram_para[12]:0x3 [277]dram_para[13]:0x0 [280]dram_para[14]:0x0 [282]dram_para[15]:0x4 [285]dram_para[16]:0x72 [287]dram_para[17]:0x0 [290]dram_para[18]:0xe [292]dram_para[19]:0x0 [295]dram_para[20]:0x0 [297]dram_para[21]:0x26 [300]dram_para[22]:0x80808080 [303]dram_para[23]:0x6060606 [306]dram_para[24]:0x1f0b0503 [309]dram_para[25]:0x0 [312]dram_para[26]:0x3a000000 [315]dram_para[27]:0x802f3333 [318]dram_para[28]:0xc0c0bbbf [321]dram_para[29]:0x35352f31 [325]dram_para[30]:0xc64 [327]dram_para[31]:0x48484848 [331]board init ok [353]enable_jtag [355]card no is 0 [357]sdcard 0 line count 4 [360][mmc]: mmc driver ver 2023-03-24 16:23 [370][mmc]: Wrong media type 0x0 [374][mmc]: ***Try SD card 0*** [395][mmc]: HSSDR52/SDR25 4 bit [398][mmc]: 50000000 Hz [401][mmc]: 60906 MB [403][mmc]: ***SD/MMC 0 init OK!!!*** [414]DRAM BOOT DRIVE INFO: V0.67 [419]DRAM_VCC set to 1100 mv [545]DRAM retraining ten [671]DRAM retraining ten [689][AUTO DEBUG]32bit,1 ranks training success! [718]Soft Training Version: T2.0 [7773][SOFT TRAINING] CLK=1200M Stable memtest pass [7778]DRAM CLK =1200 MHZ [7781]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [7792]phy_dfs_clk1 = 800M [8078]phy_dfs_clk2 = 400M [8169]phy_dfs_clk3 = 150M [8290]phy_dfs_clk0 = 1200M [8293]DRAM MDFS VERSION INFO: V0.660 [8298]DRAM MDFS time =38892 ns [8301]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, tpr13 = 6465 [8329]DRAM simple test OK. [8332]dram size =2048 [8339]nsi init 2023-2-23 [8343]error:bad magic. [8463]Loading boot-pkg Succeed(index=1). [8467]Entry_name = u-boot [8476]Entry_name = monitor [8480]Entry_name = scp [8484]Entry_name = dtb [8487]mmc not para [8489]Jump to second Boot. NOTICE: BL31: OP-TEE 32bit detected NOTICE: BL31: U-BOOT 32bit detected NOTICE: BL31: v2.5(debug):a6e1826c1 NOTICE: BL31: Built : 10:10:43, Mar 28 2025 NOTICE: BL31: No DTB found. nsi init ok 2022-11-08 ERROR: Error initializing runtime service opteed_fast U-Boot 2018.07-11-boot-aw2501-g4f803d1684e-dirty (Dec 05 2025 - 10:08:58 +0000) Allwinner Technology [08.641]CPU: Allwinner Family [08.644]Model: Radxa Cubie A5E I2C: ready [08.655]DRAM: 2 GiB [08.659]Relocation Offset is: 75e60000 [08.721]secure enable bit: 0 [08.725]PMU: AXP2202 [08.753][AXP2202] comm status : 0x0 = 0x20, 0x1 = 0x90 [08.758][AXP2202] onoff status: 0x20 = 0x4, 0x21 = 0x0 [08.763][AXP2202] reboot/charge status: 0xf0 = 0x0 [08.768]PMU: AXP1530 [08.771]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=600Mhz [08.777]gic: sec monitor mode SPI ALL: ready [08.782]flash init start [08.785]workmode = 0,storage type = 1 [08.788][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00 -- uboot2018:2025-03-28 10:03:00 [08.796][mmc]: get sdc_type fail and use default host:tm1. [08.802][mmc]: can't find node "mmc0",will add new node [08.807][mmc]: fdt err returned <no error> [08.811][mmc]: Using default timing para [08.814][mmc]: SUNXI SDMMC Controller Version:0x50500 [08.843][mmc]: card_caps:0x3000000a [08.846][mmc]: host_caps:0x3000003f [08.851]sunxi flash init ok get value error [08.860]Loading Environment from SUNXI_FLASH... OK [08.867]No ethernet found. [08.877]Fail to get de's irq! [08.915]NOT support bridge yet [08.918]Warn: no find panel or bridge [08.921]hdmi@5520000 disconnected [08.924]drm hdmi get mode: 1920x1080@60Hz hdmi@5520000: use force output detailed mode clock 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 0 [09.134]the secure storage item0 copy0 magic is bad [09.148]the secure storage item0 copy1 magic is bad [09.152]usb burn from boot delay time 0 weak:otg_phy_config [09.163]usb prepare ok [09.466]overtime [09.471]do_burn_from_boot usb : no usb exist cann't get the boot_base from the env [09.494]update part info [09.498]update bootcmd pcie link up success PCIe speed of Gen2 [09.908]change working_fdt 0xbbe0fe18 to 0xbbddfe18 get value error [09.914][mmc]: get sunxi-mmc0 string failed [09.918]The storage not support sample function [09.924]## error: update_fdt_dram_para_from_bootpara : FDT_ERR_NOTFOUND ret 0 [09.935]chip id : 0x0000ff10 0x00004824 0x0000d710 0x00001d96 [09.940]chip id : 0x0000ff10 0x00004824 0x0000d710 0x00001d96 [09.946]Could not find nodeoffset for used ext pmu:reg-axp1530 [09.951]update dts curr_device:0 Device: SUNXI SD/MMC Manufacturer ID: 3 OEM: 5344 Name: SR64G Bus Speed: 50000000 Mode : SD High Speed (50MHz) Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 59.5 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes Hit any key to stop autoboot: 0 starting USB... USB0: start sunxi USB-DRD... config usb clk ok sunxi USB-DRD init ok... USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found USB1: start sunxi USB1-Host... config usb clk ok sunxi USB1-Host init ok... USB EHCI 1.00 scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** mmc0 is current device Scanning mmc 0:2... Scanning mmc 0:3... Found /boot/extlinux/extlinux.conf Retrieving file: /boot/extlinux/extlinux.conf ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000) 1323 bytes read in 7 ms (184.6 KiB/s) U-Boot menu 1: Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501 2: Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501 (rescue target) Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.15.147-13-aw2501 Retrieving file: /boot/initrd.img-5.15.147-13-aw2501 ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000) 7060674 bytes read in 300 ms (22.4 MiB/s) Retrieving file: /boot/vmlinuz-5.15.147-13-aw2501 ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000) 20992512 bytes read in 877 ms (22.8 MiB/s) append: root=UUID=9645203c-b680-44b6-8b18-068d9e110402 console=ttyAS0,115200n8 rootwait clk_ignore_unused mac_addr=08:ef:6c:c7:8b:ad mac1_addr=08:ef:6c:c7:8b:ac quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off Retrieving file: /usr/lib/linux-image-5.15.147-13-aw2501/allwinner/sun55i-a527-cubie-a5e.dtb ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000) 161015 bytes read in 18 ms (8.5 MiB/s) get value error [16.446]The storage not support sample function ret 0 [16.563]update dts stop sunxi USB-DRD ok... stop sunxi USB1-Host ok... Loading Ramdisk to 49944000, end 49fffcc2 ... OK ERROR: reserving fdt memory region failed (addr=bbed0000 size=7e9000) [16.598]Starting kernel ... [16.601]total: 16601 ms [16.603][mmc]: MMC Device 2 not found [16.606][mmc]: mmc 2 not find, so not exit NOTICE: [SCP] :wait arisc ready.... NOTICE: [SCP] :arisc version: [364dad9bcd34230512f015ab5c6cefa12bd238d0] NOTICE: [SCP] :arisc startup ready NOTICE: [SCP] :arisc startup notify message feedback NOTICE: [SCP] :sunxi-arisc driver is starting NOTICE: BL3-1: Next image address = 0x40200000 NOTICE: BL3-1: Next image spsr = 0x3c5 [ 0.071969] AW BSP version: caee29fcb3, 2025-12-09 07:23:49, RadxaOS SDK [ 0.140107] sunxi:twi_sunxi-2502000.twi0:[ERR]: pinctrl_get failed [ 0.140127] sunxi:twi_sunxi-2502000.twi0:[ERR]: TWI failed to get resource [ 0.143734] sunxi:axp2101-6-0036:[ERR]: Unable to match OF ID [ 0.310164] sunxi:ccu_ddr:[ERR]: dram_clk:1200 [ 0.310191] sunxi:ccu_ddr:[ERR]: dram_div:0x1f0b0503 [ 0.310832] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin [ 0.310842] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin [ 0.310886] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin [ 0.310892] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin [ 0.311482] sunxi:sunxi_uart-uart0:[ERR]: uart0 error to get fifo size property [ 0.386566] NSI_PMU 2020000.nsi-controller: no topo process for clk path type:0 [ 0.394816] no topo process for topo type:0 [ 0.402846] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get mbus clock [ 0.411011] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get store clock [ 0.419251] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: Could not get msi_lite clock [ 0.457791] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get mbus clock [ 0.466069] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get store clock [ 0.474428] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: Could not get msi_lite clock [ 0.475236] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.492239] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.501531] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.510880] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.520159] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.529448] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.538076] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get mbus clock [ 0.538726] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.546202] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get store clock [ 0.562758] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: Could not get msi_lite clock [ 0.572128] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.581414] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.590691] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.600035] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.609310] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.617707] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 0.627037] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 0.635533] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.644823] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.654111] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.663385] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.672711] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.682003] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.691285] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.700598] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.709898] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.719191] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: smc 1 p2 err, cmd 1, RTO !! [ 0.727648] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:set phase failed or over retry times [ 0.737523] sunxi:sunxi_mmc_host-4022000.sdmmc:[ERR]: retry:give up [ 0.744833] sunxi:sunxi_mmc_host-4020000.sdmmc:[ERR]: sdc0 :the host don't support tuning in kernel [ 1.235336] sunxi:sunxi_sidefuse init success! [ 1.241281] inno-combphy 4f00000.phy: get select3v3-supply fail [ 1.740355] sunxi-rc-recv 2005000.irrx: sunxi_irrx_resource_get: get ir protocol failed [ 1.771768] sunxi:axp2202_battery:[ERR]: axp2202-battery device is not configed [ 1.794813] sunxi-rfkill soc@3000000:rfkill: get gpio chip_en failed [ 1.804693] [NAND][NE] Not found valid nand node on dts [ 3.128108] cma: cma_alloc: reserved: alloc failed, req-size: 512 pages, ret: -12 [ 4.777883] sunxi:VE:[ERR]: 409 map_max_ve_freq_by_vf_sun55iw3(): can not match dvfs[0x1] and vol[900 mv], use default ve_freq [ 4.815646] cma: cma_alloc: reserved: alloc failed, req-size: 512 pages, ret: -12 [ 4.827791] sunxipart: failed to parse sunxi_gpt! [ 5.002596] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed [ 5.046546] sunxi:sound-codec-hdmi:[ERR]: 442 sunxi_codec_dev_probe(): register codec-hdmi success [ 5.064198] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed [ 5.084859] debugfs: Directory '7114000.i2s2_plat' with parent 'sndhdmi' already present! [ 5.094216] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 5.105028] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 5.175761] axp2202-bldo1: Restricting voltage, 3300000-1800000uV [ 5.182730] sunxi-rfkill soc@3000000:rfkill: wlan power[0] (axp2202-bldo1) set voltage failed [ 5.192433] sunxi-rfkill soc@3000000:rfkill: set power failed [ 5.250133] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !! [ 5.258714] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !! [ 5.267263] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !! [ 5.275819] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 7, RTO !! [ 5.310636] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 5.320383] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 2 p1 err, cmd 52, RTO !! [ 5.625825] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1404>: bus down [ 6.762994] ieee80211 phy0: [ 6.762994] ******************************************************* [ 6.762994] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES ** [ 6.762994] ******************************************************* Debian GNU/Linux 11 radxa-cubie-a5e ttyAS0 radxa-cubie-a5e login: 0 Quote
Igor Posted February 13 Posted February 13 3 hours ago, Meestor_X said: Radxa Bullseye image, only with the Armbian Trixie Radxa images comes with proprietary vendor kernel v5.15, which we won't integrate for this hardware - Armbian is only made with mainline derived v6.18.y / v6.19.y kernel, which is far from completion. Those SW stacks are fundamentally different. We can produce a Bullseye image, but with a kernel 6.18.y only ... which means identical hardware support as on Armbian Trixie. In general https://docs.armbian.com/User-Guide_FAQ/#why-things-stop-working 0 Quote
Meestor_X Posted February 13 Author Posted February 13 (edited) Just tested trunk 244, (Armbian_community_26.2.0-trunk.244_Radxa-cubie-a5e_trixie_edge_6.18.5_minimal.img.xz) and it doesn't have this reboot issue. However, trunk 244 doesn't support the PCIe, USB3 or WiFi/BT so something must have changed when those devices started to be supported recently. I take that back, it does still have the rebooting issue. I'll keep digging. Edited February 13 by Meestor_X 0 Quote
Meestor_X Posted February 16 Author Posted February 16 Ok, in case anyone's got any ideas about how to fix this, I'm happy to help if I can, but kernel repairs are a bit out of my league... It seems to reboot for different reasons - when it doesn't like something connected to the USB port, when doing a lot of disk I/O, etc. Here's a couple of the error logs from the terminal: INFO: task sgdisk:1567 blocked for more than 120 seconds. Tainted: G O 6.18.10-edge-sunxi64 #1 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. task:sgdisk state:D stack:0 pid:1567 tgid:1567 ppid:1566 task_flags:0x400000 flags:0x00000018 Call trace: __switch_to+0xcc/0x180 (T) __schedule+0x348/0xaf8 schedule+0x38/0x110 io_schedule+0x40/0x60 folio_wait_bit_common+0x15c/0x390 folio_wait_bit+0x1c/0x30 folio_wait_writeback+0x4c/0xb8 __filemap_fdatawait_range+0x70/0xb0 filemap_fdatawait_keep_errors+0x24/0x58 sync_bdevs+0xb4/0x1a8 ksys_sync+0x64/0x98 __arm64_sys_sync+0x14/0x28 invoke_syscall.constprop.0+0x54/0xe8 do_el0_svc+0x44/0xc8 el0_svc+0x38/0x140 el0t_64_sync_handler+0x98/0xe0 el0t_64_sync+0x170/0x178 Kernel panic - not syncing: hung_task: blocked tasks CPU: 6 UID: 0 PID: 61 Comm: khungtaskd Tainted: G O 6.18.10-edge-sunxi64 #1 PREEMPT Tainted: [O]=OOT_MODULE Hardware name: Radxa Cubie A5E (DT) Call trace: show_stack+0x1c/0x30 (C) dump_stack_lvl+0x30/0x80 dump_stack+0x14/0x20 vpanic+0x2d4/0x308 panic+0x50/0x58 watchdog+0x278/0x718 kthread+0x134/0x1f8 ret_from_fork+0x10/0x20 SMP: stopping secondary CPUs Kernel Offset: disabled CPU features: 0x080000,00008000,48006281,0400701b Memory Limit: none ---[ end Kernel panic - not syncing: hung_task: blocked tasks ]--- INFO: task systemd-udevd:285 blocked for more than 120 seconds. Tainted: G O 6.18.10-edge-sunxi64 #1 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. task:systemd-udevd state:D stack:0 pid:285 tgid:285 ppid:1 task_flags:0x400100 flags:0x00000809 Call trace: __switch_to+0xcc/0x180 (T) __schedule+0x348/0xaf8 schedule+0x38/0x110 io_schedule+0x40/0x60 folio_wait_bit_common+0x15c/0x390 folio_wait_bit+0x1c/0x30 folio_wait_writeback+0x4c/0xb8 __filemap_fdatawait_range+0x70/0xb0 filemap_write_and_wait_range+0x90/0xc0 sync_blockdev+0x24/0x40 bdev_disk_changed+0x64/0x5c8 blkdev_get_whole+0xa4/0xf8 bdev_open+0x278/0x3b0 bdev_file_open_by_dev+0xdc/0x148 disk_scan_partitions+0x6c/0x150 blkdev_ioctl+0x664/0xfc0 __arm64_sys_ioctl+0x470/0xaa0 invoke_syscall.constprop.0+0x54/0xe8 do_el0_svc+0xa4/0xc8 el0_svc+0x38/0x140 el0t_64_sync_handler+0x98/0xe0 el0t_64_sync+0x170/0x178 INFO: task sgdisk:1465 blocked for more than 120 seconds. Tainted: G O 6.18.10-edge-sunxi64 #1 "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. task:sgdisk state:D stack:0 pid:1465 tgid:1465 ppid:1464 task_flags:0x400000 flags:0x00000008 Call trace: __switch_to+0xcc/0x180 (T) __schedule+0x348/0xaf8 schedule+0x38/0x110 io_schedule+0x40/0x60 folio_wait_bit_common+0x15c/0x390 folio_wait_bit+0x1c/0x30 folio_wait_writeback+0x4c/0xb8 __filemap_fdatawait_range+0x70/0xb0 filemap_write_and_wait_range+0x90/0xc0 bdev_release+0x19c/0x1b0 blkdev_release+0x18/0x30 __fput+0xd0/0x2e8 fput_close_sync+0x44/0x108 __arm64_sys_close+0x3c/0x88 invoke_syscall.constprop.0+0x54/0xe8 do_el0_svc+0x44/0xc8 el0_svc+0x38/0x140 el0t_64_sync_handler+0x98/0xe0 el0t_64_sync+0x170/0x178 Kernel panic - not syncing: hung_task: blocked tasks CPU: 1 UID: 0 PID: 61 Comm: khungtaskd Tainted: G O 6.18.10-edge-sunxi64 #1 PREEMPT Tainted: [O]=OOT_MODULE Hardware name: Radxa Cubie A5E (DT) Call trace: show_stack+0x1c/0x30 (C) dump_stack_lvl+0x30/0x80 dump_stack+0x14/0x20 vpanic+0x2d4/0x308 panic+0x50/0x58 watchdog+0x278/0x718 kthread+0x134/0x1f8 ret_from_fork+0x10/0x20 SMP: stopping secondary CPUs Kernel Offset: disabled CPU features: 0x080000,00008000,48006281,0400701b Memory Limit: none ---[ end Kernel panic - not syncing: hung_task: blocked tasks ]--- 0 Quote
Meestor_X Posted February 28 Author Posted February 28 (edited) While attempting, using AI, to see if there were DTS changes that could help this (spoiler: there aren't), it came up with some DTB changes that it claims need to be made for the board's stability. Maybe someone who understands these things can see if they got it right? Also, does the new allwinner update for armbian help/fix any of the cubie's USB/Power issues? https://github.com/armbian/build/pull/9381 a5e-armbian-DTS.patch Edited February 28 by Meestor_X 0 Quote
Meestor_X Posted March 2 Author Posted March 2 Testing the latest build: apt update && apt upgrade -y Hit:1 http://deb.debian.org/debian trixie InRelease Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Get:3 http://security.debian.org trixie-security InRelease [43.4 kB] Get:4 https://github.armbian.com/configng stable InRelease [5,467 B] Get:5 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB] Err:2 http://deb.debian.org/debian trixie-updates InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Err:3 http://security.debian.org trixie-security InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Err:4 https://github.armbian.com/configng stable InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Err:5 http://deb.debian.org/debian trixie-backports InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Get:6 http://fi.mirror.armbian.de/beta trixie InRelease [39.4 kB] Err:6 http://fi.mirror.armbian.de/beta trixie InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Fetched 190 kB in 1s (143 kB/s) All packages are up to date. Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://deb.debian.org/debian trixie-updates InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://security.debian.org trixie-security InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://github.armbian.com/configng stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://deb.debian.org/debian trixie-backports InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: http://fi.mirror.armbian.de/beta trixie InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Warning: Failed to fetch https://github.armbian.com/configng/dists/stable/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T16:02:28Z Warning: Failed to fetch http://beta.armbian.com/dists/trixie/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5, which is needed to verify signature. Verifying signature: Not live until 2026-03-02T08:25:38Z Warning: Failed to fetch http://deb.debian.org/debian/dists/trixie-updates/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:41Z Verifying signature: Not live until 2026-03-02T13:39:55Z Warning: Failed to fetch http://deb.debian.org/debian/dists/trixie-backports/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T13:39:27Z Verifying signature: Not live until 2026-03-02T13:39:49Z Warning: Failed to fetch http://security.debian.org/dists/trixie-security/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Verifying signature: Not live until 2026-03-02T02:15:55Z Verifying signature: Not live until 2026-03-02T02:15:55Z Warning: Some index files failed to download. They have been ignored, or old ones used instead. Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0 root@radxa-cubie-a5e:~# armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... https://paste.armbian.com/zefutefuzi Please post the URL in the forum where you've been asked for. https://paste.armbian.com/zefutefuzi 0 Quote
