Armbian boots from SD Card only manually via U-Boot, autoboot fails I installed it to eMMC(Amlogic S805X / gxl_p241_v1)
Hello everyone,
I successfully installed Armbian to eMMC on an Amlogic S805X (gxl_p241 / p241 board).
The system boots correctly when I manually start it from U-Boot, but autoboot fails every time.
I believe my bootloader / U-Boot environment is not properly configured. During flashing, I only selected the DTB, and I am not sure how the bootloader variables should be set for eMMC boot.
if it didnt work ,how to manually install u-boot
U-Boot log
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... init_part() 282: PART_TYPE_DOS
1 Storage Device(s) found
fail in cmd [fatsize usb 0 factory_update_param.aml], rcode 1
File factory_update_param.aml not exist in Upan??
get upgrade version failed
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
gxl_p241_v1#
Posted (edited)
here is the full log
dtb/amlogic/meson-gxl-s805x-p241.dtb
copied -u-boot-s905x-s912 u-boot.ext
then renamed it as u-boot.ext
manually booted from sd card , then installed to emmc
sudo /root/install-aml.sh
previously i could save bootcmd as env , after this ,i couldnot save env ,from u-boot
now it gives this error
gxl_p241_v1#saveenv
Saving Environment to aml-storage...
_find_partition_by_name()-198: do not find match in table env
get partition info failed !!
gxl_p241_v1## This saves all environment variables to eMMC/SD
gxl_p241_v1#saveenv
is there any way to manually erase the default vendor , u-boot , and install armbian one ?
Armbian_20.10_Arm-64_focal_current_5.9.0
this is the image i succesfully booted ,
i tried to boot this image
Armbian_community_26.2.0-trunk.385_Aml-s9xx-box_trixie_current_6.18.8_minimal
it gives this error
reading zImage
** Unable to read file zImage **
reading dtb/amlogic/meson-gxl-s805x-p241.dtb
26728 bytes read in 57 ms (457 KiB/s)
[rsvmem] get fdtaddr NULL!
rsvmem - reserve memory
Usage:
rsvmem check                   - check reserved memory
rsvmem dump                    - dump reserved memory
rsvmem check failed
Bad Linux ARM64 Image magic!
gxl_p241_v1#
vendor u-boot ,bootcmd
u-boot default bootcmd
gxl_p241_v1#printenv bootcmd
bootcmd=run storeboot
gxl_p241_v1#printenv storeboot
storeboot=get_system_as_root_mode;echo system_mode: ${system_mode};if test ${system_mode} = 1; then setenv fs_type ro rootwait skip_initramfs;run storeargs;fi;get_valid_slot;get_avb_mode;echo active_slot: ${active_slot};if test ${active_slot} != normal; then setenv bootargs ${bootargs} androidboot.slot_suffix=${active_slot};fi;if test ${avb2} = 0; then if test ${active_slot} = _a; then setenv bootargs ${bootargs} root=/dev/mmcblk0p23;else if test ${active_slot} = _b; then setenv bootargs ${bootargs} root=/dev/mmcblk0p24;fi;fi;fi;if imgread kernel ${boot_part} ${loadaddr}; then bootm ${loadaddr}; fi;run update
LOG After i installed armbin (Armbian_20.10_Arm-64_focal_current_5.9.0)to emmc , reboot gives this error
[  OK  ] Reached target Reboot.
[  650.054096] watchdog: watchdog0: watchdog did not stop!
[  650.541411] reboot: Restarting system
bl31 reboot reason: 0xd
bl31 reboot reason: 0x0
system cmd  1.
GXL:BL1:9ac50e:bb16dc;FEAT:BFFC39BE:100;POC:3;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;1.0;1.0;CHK:0;
TE: 241336
BL2 Built : 10:47:34, Jan 14 2019. gxl g152d217 - guotai.shen@droid11-sz
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 7
CPU clk: 984MHz
DDR enable rdbi
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0 16bit @ 912MHz
bist_test rank: 0 1b 00 37 27 0f 3f 1c 01 38 2b 11 45 27 27 27 27 27 27 27 27 27 27 27 27 693   - PASS
Rank0: 1024MB-2T-13
AddrBus test pass!
Set ddr ssc: ppm1000-
eMMC boot @ 1
sw8 s
emmc switch 3 ok
BL2: rpmb counter: 0x00000020
emmc switch 1 ok
OTP_ARB=00000001
Load FIP HDR from eMMC, src: 0x0000c200, des: 0x01700000, size: 0x00004000, part: 1
Load BL3x from eMMC, src: 0x00010200, des: 0x01704000, size: 0x000f4000, part: 1
NOTICE:  BL3-1: v1.0(release):3bc3888
NOTICE:  BL3-1: Built : 11:28:51, May 10 2019
[BL31]: GXL CPU setup!
NOTICE:  BL3-1: GXL secure boot!
NOTICE:  BL3-1: BL33 decompress pass
mpu_config_enable:system pre init ok
dmc sec lock
MVN_1=0x01010100
MVN_2=0x01010000
[Image: gxl_v1.1.3375-8f9c8a7 2019-01-24 10:45:03 guotai.shen@droid11-sz]
OPS=0x34
21 0d 34 00 25 ae dc 97 5b 00 83 fe 04 b3 53 02
[0.856523 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-2: ATOS-V2.4-238-g14a47cb #1 Tue Dec  3 07:25:46 UTC 2019 arm
INFO:    BL3-2: Chip: GXL Rev: D (21:D - 30:2)
INFO:    BL3-2: crypto engine DMA
INFO:    BL3-2: secure time TEE
INFO:    BL3-2: CONFIG_DEVICE_SECURE 0xb200000e
U-Boot 2015.01-g186a540 (Mar 14 2020 - 17:11:46)
DRAM:  1 GiB
Relocation Offset is: 36e86000
register usb cfg[0][1] = 0000000037f51910
[CANVAS]canvas init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000033e866b0
aml_priv->desc_buf = 0x0000000033e889f0
SDIO Port B: 0, SDIO Port 😄 1
co-phase 0x2, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
co-phase 0x2, tx-dly 0, clock 40000000
[mmc_startup] mmc refix success
[mmc_init] mmc init success
 check_valid_dts() 248: Decrypt dtb: Sig Check -2
get_partition_from_dts() 71: ret -249
get_partition_from_dts() 74: ret -249
get_ptbl_from_dtb()-269: get partition table from dts faild
mmc_device_init()-1251: get partition table from dtb failed
get_ptbl_rsv()-491: magic faild MPT, ▒׋
mmc_device_init()-1278: dtb&rsv are not exist, no LPT source
Using default environment
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
itest - return true/false on integer compare
Usage:
itest [.b, .w, .l, .s] [*]value1 <op> [*]value2
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-2755: calc 79d92d6, store f26b0ab5
update_dtb_info()-2863: cpy 1 is not valid
_verify_dtb_checksum()-2755: calc ab3aca1f, store f6004a13
update_dtb_info()-2863: cpy 0 is not valid
dtb_read()-2972: total valid 0
emmc - EMMC sub system
Usage:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
[store]decrypt dtb: Sig Check -2
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 2
vpu: set clk: 200000000Hz, readback: 200000000Hz(0x501)
vpu: vpu_clk_gate_init_off finish
vpp: vpp_init
hpd_state=0
vpp: vpp_matrix_update: 2
cvbs performance type = 6, table = 0
cvbs_config_hdmipll_gxl
cvbs_set_vid2_clk
Net:   dwmac.c9410000[KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000
MACADDR:02:5b:97:dc:ae:25(from chipid)
Warning: dwmac.c9410000 MAC addresses don't match:
Address in SROM is         4a:f1:62:3d:0c:33
Address in environment is  02:5b:97:dc:ae:25
CONFIG_AVB2: avb2
Start read misc partition datas!
_find_partition_by_name()-198: do not find match in table misc
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store init flag
store read name addr off|partition size
    read 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
    write 'size' bytes starting at offset 'off'
store rom_write add off size.
        write uboot to the boot device
store erase boot/data:
        erase the area which is uboot or data
store erase partition <partition_name>:
        erase the area which partition in u-boot
store erase dtb
store erase key
store disprotect key
store rom_protect on/off
store scrub off|partition size
        scrub the area from offset and size
store dtb iread/read/write addr <size>
        read/write dtb, size is optional
store key read/write addr <size>
        read/write key, size is optional
store mbr addr
   update mbr/partition table by dtb
[burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store  read misc 0x33e75090  0x0  0x820]
failed to store read misc.
info->magic =
info->version_major = 0
info->version_minor = 0
info->slots[0].priority = 0
info->slots[0].tries_remaining = 0
info->slots[0].successful_boot = 0
info->slots[1].priority = 0
info->slots[1].tries_remaining = 0
info->slots[1].successful_boot = 0
info->crc32 = 0
Magic  is incorrect.
boot-info is invalid. Resetting.
save boot-info
info->magic =
info->version_major = 1
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->crc32 = -1075449479
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_write_ops,L110:cmd [store  write misc 0x33e75090  0x0  0x820] failed active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=0
reboot_mode:::: cold_boot
[OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[OSD]VPP_OFIFO_SIZE:0xfff00fff
[CANVAS]addr=0x3d800000 width=3840, height=2160
_find_partition_by_name()-198: do not find match in table logo
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store  read logo 0x1080000  0x0  0x2000]
Err imgread(L523):Fail to read 0x2000B from part[logo] at offset 0
There is no valid bmp file at the given address
[OSD]osd_hw.free_dst_data: 0,719,0,575
gpio: pin GPIOAO_2 (gpio 102) value is 1
Command: bcb uboot-command
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
[burnup]Err:store_read_ops,L63:cmd failed, ret=1, [store  read misc 0x33e75080  0x0  0x440]
bcb - bcb
Usage:
bcb
This command will run some commands which saved in misc
partition by mark to decide whether execute command!
Command format:
  bcb bcb_mark
Example:
  /dev/block/misc partiton is saved some contents:
  uboot-command
  N/A
  setenv aa 11;setenv bb 22;setenv cc 33;saveenv;
So you can execute command: bcb uboot-command
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
CONFIG_SYSTEM_AS_ROOT: systemroot
system_mode: 1
Cannot find dev.
Usage:
store init flag
store erase dtb
store erase key
store mbr addr
info->magic =
Edited by Bug Hunter
Given where you are, my only suggestion is to restore the box to a clean android firmware (so the uboot environment is restored to a clean state).  Then restart with a current build (don't use the 6 year old build that you found somewhere).  The two versions aren't compatible.
Then get things running cleanly from SD card first, and then if you still want move the install to emmc.
it gives this error
reading zImage
Usage:
rsvmem check failed
gxl_p241_v1#
Yes it errors because your uboot environment is screwed up by everything you have previously done.  That is why I said you need to reinstall an original android firmware to set things back to a clean state before proceeding.
Posted (edited)
this is the u-boot command i gave ,previosly loaded armbian ,kernel 5.9 , same command give ,ftdaddr null ,but os loads ,
for kernel version 6.18 doesnt load , it abort
 booti ${loadaddr} - ${dtb_mem_addr}
this is the error message im getting
for booti ${loadaddr} - ${dtb_mem_addr}, other commands works perfectly
42334720 bytes read in 2967 ms (13.6 MiB/s)
reading dtb/amlogic/meson-gxl-s805x-p241.dtb 40339 bytes read in 58 ms (678.7 KiB/s)
Usage:
rsvmem check failed
"Synchronous Abort" handler, esr 0x96000210
