HDMI audio multichannel wrong mapping (in 6.18.12-current-rockchip64)
Posted (edited)
Does anybody know how one could correct multichannel HDMI audio mapping in the current-rockchip64 build or kernel?
When I run
speaker-test -c6 -D plughw:0,0
on
(kernel) 6.1.115-vendor-rk35xx
(dtb) dtb-6.1.115-vendor-rk35xx
Everything is mapped correctly and I hear audio from all the correct channels.
When I run the same command on
(kernel) 6.18.12-current-rockchip64
(dtb) dtb-6.18.12-current-rockchip64
I get no audio on center and rear right channels (others are working).
Is this a mistake or error in the DTB file of dtb-6.18.12-current-rockchip64 (rk3588s-nanopi-r6s.dtb) ?
How can we correct this?
Edited by DeVILRuNNeR
added specific dtb file ref
  • DeVILRuNNeR changed the title to HDMI audio multichannel wrong mapping (in 6.18.12-current-rockchip64)
Some logs that might help in resolving:
cat /proc/asound/card0/eld*
monitor_name            SONY AVAMP
connection_type         HDMI
eld_version             [0x2] CEA-861D or below
edid_version            [0x3] CEA-861-B, C or D
manufacture_id          0xd94d
product_id              0x9301
port_id                 0x0
support_hdcp            0
support_ai              1
audio_sync_delay        0
speakers                [0x5f] FL/FR LFE FC RL/RR RC RLC/RRC
sad_count               12
sad0_coding_type        [0xc] MLP (Dolby TrueHD)
sad0_channels           2
sad0_rates              [0x1ec0] 44100 48000 88200 96000 176400 192000
sad1_coding_type        [0xc] MLP (Dolby TrueHD)
sad1_channels           6
sad1_rates              [0x1ec0] 44100 48000 88200 96000 176400 192000
sad2_coding_type        [0xc] MLP (Dolby TrueHD)
sad2_channels           8
sad2_rates              [0x6c0] 44100 48000 88200 96000
sad3_coding_type        [0xb] DTS-HD
sad3_channels           2
sad3_rates              [0x1ec0] 44100 48000 88200 96000 176400 192000
sad4_coding_type        [0xb] DTS-HD
sad4_channels           6
sad4_rates              [0x1ec0] 44100 48000 88200 96000 176400 192000
sad5_coding_type        [0xb] DTS-HD
sad5_channels           8
sad5_rates              [0x6c0] 44100 48000 88200 96000
sad6_coding_type        [0x1] LPCM
sad6_channels           2
sad6_rates              [0x1ee0] 32000 44100 48000 88200 96000 176400 192000
sad6_bits               [0xe] 16 20 24
sad7_coding_type        [0x1] LPCM
sad7_channels           6
sad7_rates              [0x1ee0] 32000 44100 48000 88200 96000 176400 192000
sad7_bits               [0xe] 16 20 24
sad8_coding_type        [0x1] LPCM
sad8_channels           8
sad8_rates              [0x1ee0] 32000 44100 48000 88200 96000 176400 192000
sad8_bits               [0xe] 16 20 24
sad9_coding_type        [0x2] AC-3
sad9_channels           6
sad9_rates              [0xe0] 32000 44100 48000
sad9_max_bitrate        680000
sad10_coding_type       [0x7] DTS
sad10_channels          6
sad10_rates             [0x6e0] 32000 44100 48000 88200 96000
sad10_max_bitrate       1536000
sad11_coding_type       [0xa] E-AC-3/DD+ (Dolby Digital Plus)
sad11_channels          8
sad11_rates             [0xc0] 44100 48000
dmesg | grep -i hdmi
[    0.024452] /vop@fdd90000: Fixed dependency cycle(s) with /hdmi@fde80000
[    0.024468] /hdmi@fde80000: Fixed dependency cycle(s) with /vop@fdd90000
[    0.030657] /hdmi@fde80000: Fixed dependency cycle(s) with /hdmi-con
[    0.030674] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fde80000
[    1.328504] dwhdmiqp-rockchip fde80000.hdmi: registered DesignWare HDMI QP I2C bus driver
[    1.329303] rockchip-drm display-subsystem: bound fde80000.hdmi (ops rockchip_drm_fini [rockchipdrm])
[77523.181767] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0
[77523.184450] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC error (-19): at snd_soc_dai_prepare() on i2s-hifi
[77529.747875] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0
[77529.749599] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC error (-19): at snd_soc_dai_prepare() on i2s-hifi
[84820.893274] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0
[84947.092875] dwhdmiqp-rockchip fde80000.hdmi: registered DesignWare HDMI QP I2C bus driver
[84947.100550] rockchip-drm display-subsystem: bound fde80000.hdmi (ops rockchip_drm_fini [rockchipdrm])
Posted (edited)
I just tried LibreELEC 13 testing builds as they are also running kernel 6.18.
Audio seems to work there and I can hear all channels or speakers.
I guess LibreELEC includes HDMI audio support patches for RK3588/S and NanoPi R6S that Armbian hasn’t incorporated yet ?
The ALSA rockchip-i2s-tdm driver needs to support more than 8 TDM slots or support the HDMI multi-TDM mapping for 5.1 / 7.1.
LibreELEC patches
You should also consider the bootloader (type and version), in principle you do not need the dtb- package as the dtb files are also in the kernel package (enough when doing own extlinux).
U-Boot philosophy is to provide just enough so that the kernel/initrd/DTB can load and started. Audio is not part of that I think. LE certainly used other bootloader and as you already showed has more non-upstreamed patches.
See my experience:
Posted (edited)
Just tried stock DietPI & Armbian builds using both current-rockchip64 and edge-rockchip64 utilizing U-Boot - thus completely eliminating the EDK2 UEFI factor.
None handle multichannel audio correctly so I guess there is something still not mature enough in mainline/upstream for this.
kernel-rk35xx-vendor:6.1.115 works perfectly even with EDK2 UEFI.
Perhaps the Armbian devs need to take a look at what LibreELEC is doing as they managed to get it working in their mainline/upstream kernels.
