hanni76 Posted December 3, 2017 Posted December 3, 2017 Hello, all images for OrangePI PC (next) produced since yesterday give the following output: ----------------------------------- U-Boot SPL 2017.11-armbian (Dec 03 2017 - 17:13:28) DRAM: 1024 MiB Trying to boot from MMC1 Uncompressing Linux... done, booting the kernel. Loading, please wait... starting version 232 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. ------------------------------- An old image is booting fine. Any ideas? Thanks
hanni76 Posted December 3, 2017 Author Posted December 3, 2017 I found that UUID specified in armbianEnv.txt is wrong (???). I have no idea why this happened... One reason to come to my mind is that I mounted a Samba share to "armbian/build/output/images". I am going to try a new build without it. It seems like the problem didn't exist couple of days ago. -------------- ALERT! UUID=4dc850bc-ea4c-436a-8a3f-57793795e7a4 does not exist. Dropping to a shell! -------------- The image was created in Virtualbox. I never seen this before when I was making builds on the "hardware" host. I have attached serial port log. minicom.log
hanni76 Posted December 3, 2017 Author Posted December 3, 2017 Here is the build log when image was created: ------------------- [ o.k. ] Preparing image file for rootfs [ orangepipc stretch ] [ o.k. ] Current rootfs size [ 942 MiB ] [ o.k. ] Creating blank image for rootfs [ 1456 MiB ] 1.42GiB [70.7MiB/s] [================================================================================================================>] 100% [ o.k. ] Creating partitions [ root: ext4 ] [ .... ] Creating rootfs [ ext4 ] [ .... ] Copying files to root directory 885.87M 99% 37.06MB/s 0:00:22 (xfr#30842, to-chk=0/38646) sent 888.22M bytes received 620.71K bytes 37.82M bytes/sec total size is 890.87M speedup is 1.00 [ .... ] Copying files to /boot directory 24.57M 99% 133.73MB/s 0:00:00 (xfr#154, to-chk=0/161) sent 24.59M bytes received 2.97K bytes 49.18M bytes/sec total size is 24.57M speedup is 1.00 [ o.k. ] Free space: [ SD card ] Filesystem Size Used Avail Use% Mounted on udev 2.0G 0 2.0G 0% /dev tmpfs 396M 5.9M 390M 2% /run /dev/sda1 57G 17G 38G 32% / tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup //192.168.3.50/smb-toolchains 170G 92G 69G 58% /home/sergey/Projects/armbian/build/cache/toolchains //192.168.3.50/smb-qt5-build 170G 92G 69G 58% /home/sergey/Projects/qt5-build //192.168.3.50/smb-boards 170G 92G 69G 58% /home/sergey/Projects/boards tmpfs 396M 0 396M 0% /run/user/1000 tmpfs 2.6G 942M 1.7G 36% /home/sergey/Projects/armbian/build/.tmp/rootfs-next-orangepipc-stretch-no /dev/loop0p1 1.4G 957M 396M 71% /home/sergey/Projects/armbian/build/.tmp/mount-next-orangepipc-stretch-no [ o.k. ] Writing U-boot bootloader [ /dev/loop0 ] [ o.k. ] Done building [ /home/sergey/Projects/armbian/build/output/images/Armbian_5.36_Orangepipc_Debian_stretch_next_4.14.3.img ] [ o.k. ] Runtime [ 26 min ] ----------------------------------------------------------------------------------------------- One interesting detail: /dev/loop0 is not unmounted in the end and is still visible in blkid.
Igor Posted December 4, 2017 Posted December 4, 2017 8 hours ago, hanni76 said: It seems like the problem didn't exist couple of days ago. I can't confirm or deny if we have some problems since we changed few things and I haven't really made an image in the last 24h.
hanni76 Posted December 4, 2017 Author Posted December 4, 2017 26 minutes ago, Igor said: I can't confirm or deny if we have some problems since we changed few things and I haven't really made an image in the last 24h. Any idea why that UUID didn't match or didn't exist at all? When I check SD card on host Ubuntu it looks ok.
hanni76 Posted December 4, 2017 Author Posted December 4, 2017 Here is log file from "hardware" host: ------------------------ [ o.k. ] Free space: [ SD card ] Filesystem Size Used Avail Use% Mounted on udev 5,9G 0 5,9G 0% /dev tmpfs 1,2G 27M 1,2G 3% /run /dev/sda4 156G 22G 126G 15% / tmpfs 5,9G 171M 5,7G 3% /dev/shm tmpfs 5,0M 8,0K 5,0M 1% /run/lock tmpfs 5,9G 0 5,9G 0% /sys/fs/cgroup /dev/sda5 170G 97G 64G 61% /home/sergey/Projects /dev/sda6 92G 68M 87G 1% /home/sergey/Public /dev/sda7 105G 60M 100G 1% /home/sergey/Projects2 tmpfs 1,2G 100K 1,2G 1% /run/user/1000 tmpfs 7,8G 314M 7,5G 4% /home/sergey/Projects/armbian/build/.tmp/rootfs-next-orangepipc-stretch-no /dev/loop0p1 547M 320M 205M 61% /home/sergey/Projects/armbian/build/.tmp/mount-next-orangepipc-stretch-no
hanni76 Posted December 4, 2017 Author Posted December 4, 2017 Hardware host, Ubuntu 16.04, produces working images. So the problem exists only in Virtualbox. IMAGES (without any customization) CREATED IN VIRTUALBOX DO NOT BOOT. i.e. Virtualbox can't be considered as a reliable platform for building Armbian images. At least until I find a reason why this happens.
hanni76 Posted December 5, 2017 Author Posted December 5, 2017 Ok, the problem is Stretch release only. Stretch built on "hardware" host does not have any issue.
hanni76 Posted December 22, 2017 Author Posted December 22, 2017 Finally resolved the issue. It was caused by an issue in custom device tree file which made linux boot fail silent.
