dev-null Posted March 16 Posted March 16 (edited) Just a warning for everyone, the new kernel update (6.18.xx I think?) absolutely wrecks the system (atleast it does on Ubuntu Noble). It doesn't boot at all anymore I needed to recover an old kernel from an old backup I had and overwrite the current kernel from rescue mode/petitboot. Kernel 6.12.xx seems to work fine(ish) Just a heads up because I don't know enough to pinpoint the exact cause. p.s. for me the kernel means the files in /boot not sure if I used proper terminology Edited March 16 by dev-null 0 Quote
dev-null Posted March 16 Author Posted March 16 (edited) @Werner Which logs would be usefull? I have a full image from the broken state. Kern.log is empty (0 bytes) syslog only has log from the last shutdown and ends there dmesg is from last startup before the system broke Edited March 16 by dev-null 0 Quote
dev-null Posted March 16 Author Posted March 16 I don't have a device for that. Which one would you recommend getting? I might try it out later when I get time (not soon so if anyone else is able to post logs?) 0 Quote
Werner Posted March 16 Posted March 16 FT232R, CH340 or CP2104 are known to work nicely. Search for any usb uart adapter built around one of these. Don't get CP2102 because if you ever get a rockchip board it would be useless. 1 Quote
Werner Posted March 16 Posted March 16 My n2 works fine btw. https://paste.armbian.com/cocivagayi 0 Quote
